I have been having problems with the windows on an Astra Twin Top.
A replacement Switch appeared to solve the problem, but when you open both front doors the window goes down an inch or so as it should, but doesnt automatically return when door closes.
You can manually push it back up when open by using the switch.
Is there a simple solution or is something malfunctioning.
I have tried disconnecting the battery, but to no avail.
As you've disconnected the battery, have you programmed the windows for one touch operation again afterwards?
Fully open window, then release and hold finger on open button for a couple of seconds. Then close window and release and hold finger on closed button for a couple of seconds. Repeat for each window.
Thanks Big Dave,
Worked a treat.
Now functioning properly which is a joy in rthisd rather wet part of the UK.
