Hey all I have a 2010 Astra Saturday it start jolting went into limp mode well after 15 mins the problem had cleared and car drove normally Sunday I went to use it and it is now stalling whilst in idle so will die at traffic lights etc took it to a garage for a diagnostic check and the error code is po252 so far I’ve changed the fuel filter to fuel that out. Next I'm thinking fuel regulator. Anyone have any recommendations if it’s to costly It won’t be going back on the road and will like be sent to the scrappy any help is appreciated regards Matt
Presumably a diesel of some sort then ?
DTC P0252 Fuel Pressure Regulator Performance
The ECM detects an overtemperature at the output control driver of the fuel pressure regulator
or fuel pressure regulator stuck.
Hi yeah forgot to mention it’s a 1.7 cdti
