Hi All,
First post here, hope I have it in the right spot.
I'm trying to disassemble the below connector. The entire cluster is not working due to a loose earth. When I push the wire into the back of the connector it makes a good connection, however, you can see the light bulb kinda dims and brightens suggesting that the connection is loose and probably needs to be re-terminated.
Does anyone have ideas of how this comes apart? I've tried to get it apart but it's solidly held together so I feel I could damage it if I was to "force" the connector apart.
Thanks,
James
There's a warranty special coverage (upon customer complaint only,not a recall)
for this earth pin problem for cars less than 5 years old/62000 miles,
it may be worth calling a dealer and complaining if you think your car meets the parameters.
