1 - 20 of 41 Posts
This thread will list the main pieces of technical data that people need when modding or buying accessories for their Astra Js. As bits of info come up in other threads I'll try to add them here, but if anyone has anything else they think should be added you can reply to this thread and I'll add the info into the top post(s) so that all the data is neatly accessible without trawling the whole thread.
Wheels, tyres and brakes
For Astra J 5-door hatchback, Sports Tourer and 4-door notchback with 1.4, 1.6, 1.4T and 1.3CDTi engines (J67 braking system):
PCD 5x105 (distance between neighbouring bolts is 61.7mm), centre bore 56.6mm
16" wheels: 6½J x 16 offset 39, tyre 205/60R16
17" wheels: 7J x 17 offset 42, tyre 215/50R17
18" wheels: 7½J x 18 offset 42, tyre 225/45R18
19" wheels: 8J x 19 offset 46, tyre 235/40R19
Space-saver spare: 4J x 16 offset ?? (BNX), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 39, tyre 205/60R16, other options possible.
Front brake discs: 276mm
Rear brake discs: 268mm
For Astra J 5-door hatchback, Sports Tourer and 4-door notchback with 1.6T, 1.6CDTi, 1.7CDTi and 2.0CDTi (inc Bi-Turbo) engines (J60 braking system):
PCD 5x115 (distance between neighbouring bolts is 67.6mm), centre bore 70.1mm
16" wheels: 6½J x 16 offset 41, tyre 215/60R16
17" wheels: 7J x 17 offset 44, tyre 225/50R17
18" wheels: 8J x 18 offset 46, tyre 235/45R18
Space-saver spare: 4J x 16 offset ?? (FTW), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 41, tyre 205/60R16, other options possible.
Front brake discs: 300mm
Rear brake discs: 292mm
For Astra J GTC all engines:
18" wheels: 7½J x 18 offset 41, tyre 235/50R18
19" wheels: 8J x 19 offset 36, tyre 235/45R19
20" wheels: 8½J x 20 offset 41, tyre 245/40R20
Space-saver spare: 4J x 17 offset ?? (MAP), tyre 125/70R17
Standard winter wheels are 7Jx17 offset 41, tyre 225/55R17, other options possible.
Front brake discs: 321mm (except VXR: 355mm)
Rear brake discs: 292mm (except VXR: 314mm)
If you are considering changing your wheel or tyre size, this calculator is helpful:
http://www.willtheyfit.com/
http://www.tyretraders.com/Tyres_Calculator.html
Engine and Gearbox Combinations
5 Door
GTC
Auto
Petrol
1.4L
F17WR
F17WR
1.4L Turbo
M32WR
M32WR
AF40
1.6L
F17CR
6T40
1.6L Turbo
M32WR
M32WR
6T45
1.6L SIDI Turbo
M32WR
M32WR
6T45
2.0L Turbo (VXR)
F40CR
Diesel
1.3L
F17ER
1.7L
M32WR
M32WR
2.0L
F40WR
F40WR
AF40
2.0L Bi-Turbo
F40WR
F40WR
<tbody>
</tbody>
WR = Wide Ratio
CR = Close Ratio
ER = Economy Ratio
Discussion Starter #2 (Edited)
VIN Decode (Thanks to @robclarke for this information)
Example W0LPE6ED5A8123456
Digit(s)
1st – 3rd World Manufacturers Code
• W0L = Adam Opel AG / Ltd
• W0L = Vauxhall Motors Limited
• WJR = Irmscher GmbH
• W0SV = Opel Special Vehicles GmnH
• XUF = GM Auto LLC (only for Russia)
• XWF = Avtotor (only for Russia)
4th Platform
• G = Insignia
• P = Astra J
• S = Meriva-B
5th Body Trim Level
• C = Expression
• D = Exclusiv
• E = SE/Elite
• F = Sri
6th Body Shape
• 2 = 2-door Sedan, Hatchback (GM code 08)
• 5 = 4-door Saloon (GM code 69)
• 6 = 4-door Sedan, Hatchback (GM code 68)
• 8 = 4-door combination, Estate (GM code 35)
7th Restraint system
• C = Front airbags
• D = Seatbelts with pretensioners, front and side airbags (front)
• E = Seatbelts with pretensioners, airbags front, side (front) and roof
8th Engine (not all variants are available)
• A = A13DTE (LSF, 70 kW)
• B = A14XER (LDD, 74 kW)
• C = A14NET (LUJ, 103 kW)
• D = A16XER (LDE, 85 kW)
• E = A16XNT (LGE, 110 kW)
• F = A17DTR (LPL, 92 kW)
• G = A17DTJ (LPV, 74 kW) - engine number starts with "A17DTR"
• H = A17DTS (LUD, 96 kW)
• J = A16LET (LLU, 132 kW)
• K = A17DTC (LUE, 81 kW)
• L = A20DTL (LBQ, 81 kW)
• M = A20DT (LBR, 96 kW)
• N = A20DTH (LBS 118/121 kW)
• P = Z20DTJ (LBX, 96 kW)
• R = A20DTR (LBY, 143 kW)
• S = A20NFT (LHU, 206 kW)
• T = A14XEL (LDD & PL5, 64 kW) - engine number starts with "A14XER"
• U = A14NEL (LUJ & PL5, 88 kW) - engine number starts with "A14NET"
• W = A17DTE (LKR, 96 kW)
• X = A17DTF (LKR & PL1, 96 kW)
• Y = A17DTN (LUE & PL5, 74 kW)
• Z = A16XHT (LVP, 125 kW)
• 1 = A18XER (2H0, 103 kW)
• 2 = A18XEL (2H0 & PL5, 85 kW)
• 3 = B16DTH (LVL 100 kW)
• 4 = 2.0 petrol (LHU, 162 kW)
• 5 = A16SHT (LWC, 147 kW)
• 6 = B16DTL (LVM, 81 kW)
9th Check digit (after calculation scheme)
10th Model Year (MY)
• A = 2010
• B = 2011
• C = 2012
• D = 2013
• E = 2014
11th Factory, place of build
• 0 = Kaliningrad (Russia; if manufacturers XWF) (Astra, Zafira Tourer)
• 1 = Rüsselsheim (Germany) (Astra, Zafira Tourer)
• 2 = Bochum (Germany) (Zafira Tourer)
• 3 = St. Petersburg (Russia; if manufacturers XUF) (Astra)
• 8 = Ellesmere Port (Great Britain) (Astra)
• G = Gliwice (Poland) (Astra)
12th – 17th Ongoing vehicle number (any model year, beginning 000001)
Paint Codes (Thanks to @Stickman for starting this off. Members please notify me of new paint codes as they emerge.)
Your paint code is on a sticker on the passenger side B-pillar as shown in this thread.
English Name (German name) - Type - Opel Code/GM Code
Black Sapphire (Saphirschwarz) - Pearlescent - 20R/GBG
Carbon Flash (Graphitschwarz) - Metallic - 22C/GAR
Flaming Yellow (GTC) (Sunny Melon) - Brilliant - 40Q/AJU
Fresco (Frescoblau) - Metallic - 22M/GOL
Fresh Mint (Fresh Mint) - Metallic - 30Q/GOK
Iceberg (Eisbergblau) - Pearlescent - 21Y/GEP
Linen Beige (???) - ??? - 55U/???
Macadamia (Is this Mahagonibraun?) - Pearlescent - ???/???
Metro Blue (Metro) - Metallic - 168/GBI
Misty Lake (???) - ??? - ???/GCW
Myth Green (Seegrasgrün) - Pearlescent - 30K/GAY
Olympic White (Schneeweiß) - Solid - 40R/GAZ
Pannacotta (Pannacotta) - Pearlescent - 167/GBF
Power Red (Powerrot) - Solid - 50B/GBH
Royal Blue (Royalblau) - Solid - 20Z/GEK
Seashell (Mineralweiß) - Metallic - 187/GWA
Silky Shadow (???) - Metallic - ???/???
Silver Lake (Silbersee) - Metallic - 179/GEV
Sovereign Silver (Argonsilber) - Metallic - 176/GAN
Summit White (???) - Solid - ???/???
Technical Grey (Karbongrau) - Metallic - 177/GAL
Velvet Red (???) - ??? - ???/GCS
Waterworld (Ozeanblau) - Pearlescent - 22A/GEU
??? (Mahagonibraun) - Perleffekt - 41C/GOP
??? (Azurblau) - Metallic - ???/???
Sculpture Bronze (Noblesse / Sienna Braun) - Metallic - 41E
??? (Silbergrau) - Metallic - ???/???
Discussion Starter #4 (Edited)
Fuses Please note: there may be variations by model year
Engine Compartment Fuse box:
1 Engine control module
2 Lambda probe
3 Fuel injection, ignition system
4 Fuel injection, ignition system
5 –
6 Mirror heating
7 Fan control
8 Lambda probe, engine
9 Rear window sensor
10 Battery sensor
11 Trunk release
12 Adaptive forward lighting module
13 –
14 Rear window wiper
15 Engine control module
16 Starter
17 Transmission control module
18 Heated rear window
19 Front power windows
20 Rear power windows
21 ABS
22 Left high beam (Halogen)
23 Headlamp washer system
24 Right low beam (Xenon)
25 Left low beam (Xenon)
26 Fog lights
27 Diesel fuel heating
28 –
29 Electrical parking brake
30 ABS
31 –
32 Airbag
33 Adaptive forward lighting
34 –
35 Power windows
36 –
37 Canister vent solenoid
38 Vacuum pump
39 Fuel system control module
40 Windscreen washer, Rear window washer system
41 Right high beam (Halogen)
42 Radiator fan
43 Windscreen wiper
44 –
45 Radiator fan
46 –
47 Horn
48 Radiator fan
49 Fuel pump
50 Headlamp levelling
51 Air shutter
52 Auxiliary heater, diesel engine
53 Transmission control module, Engine control module
54 Wiring monitoring
Glovebox fuse panel:
1 Displays
2 Exterior lights
3 Exterior lights
4 Radio
5 Infotainment system, instrument
6 Power outlet front 20A
7 Power outlet rear seat 20A
8 Left low beam
9 Right low beam
10 Door locks
11 Interior fan
12 –
13 –
14 Diagnostic connector
15 Airbag
16 –
17 Air conditioning system
18 Prefuse: radio, Infotainment, displays
19 Brake lights, tail lights, interior lights
20 –
21 –
22 Ignition switch
23 Body control unit
24 Body control unit
25 –
26 Power outlet load compartment (if no load compartment fuse box) (Sports tourer only)
Rear electrical centre
1 Trailer module
2 Trailer outlet
3 Parking assist
4 –
5 –
6 –
7 10A Seat heating control module, seat lumbar control module - passenger
8 Anti-theft alarm system
9 –
10 –
11 Trailer module, Trailer socket
12 –
13 Trailer outlet
14 –
15 7.5A Inside rear view mirror, rain sensor, vehicle direction camera
16 5A Inside rear view mirror
17 20A Accessary power receptacle - cargo (Estate with rear body fuse block)
18 –
19 Steering wheel heating
20 Sunroof
21 Seat heating
22 –
23 –
24 –
25 –
26 30A Feed for fuses F3, F8 and F32
27 –
28 –
29 –
30 –
31 Amplifier, Subwoofer
32 Active damping system, Lane departure warning
Discussion Starter #5 (Edited)
Option / Equipment Codes
RPO - Description
01A - TRIM COLOUR SEAT - JET BLACK
01W - TRIM COLOUR SEAT - OCEAN
01Y - TRIM COLOUR SEAT - SONIC BLUE
1AB - TRIM COLOUR DR PANEL - JET BLACK
1AW - TRIM COLOUR DR PANEL - OCEAN
1AX - TRIM COLOUR DR PANEL - SPICE RED
2BP - MOULDING DOOR INTR - ONE LAYER PAINT DARK PEARL
2BQ - MOULDING DOOR INTR - DUAL LAYER PAINT SILVER DUST
2CG - MOULDING DOOR INTR - DUAL FOIL LIQUID PALLADIUM/DARK MATRIX
2CL - MOULDING DOOR INTR - DUAL FOIL PIANO BLACK & LIQUID PALLADIUM
4A0 - INTERIOR TRIM - JET BLACK/SPICE RED
4AA - INTERIOR TRIM - JET BLACK
4AZ - INTERIOR TRIM - JET BLACK/OCEAN
9C1 - SALES PACKAGE - POLICE VEHICLE
A51 - SEAT - FRT BKT, CUSTOM
A53 - ADJUSTER PASS ST - MANUAL, 6 WAY
A64 - SEAT RR - SPLIT, FOLDING, 40/60
A69 - RESTRAINT - SEAT BELT TENSIONER, FRT, VAR. 2
ADL - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS, SINGLE STAGE
AE4 - SEAT - FRT BKT, SPORT
AEF - WINDOW - POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AER - WINDOW - POWER OPERATED, RR DRS, EXPRESS UP/DOWN
AF8 - LOCK CONTROL - SIDE DOOR, ANTI THEFT PROTECTION
AFA - INTERIOR TRIM CONFIG - #1
AG5 - ADJUSTER PASS ST - MANUAL, 2 WAY
AH3 - ADJUSTER FRT ST - MANUAL, 4 WAY, DRIVER
AH4 - ADJUSTER FRT ST - MANUAL, 6 WAY, DRIVER
AHC - CONTROL - SEAT, MANUAL CUSHION EXTN, DRIVER
AHF - CONTROL - SEAT, MANUAL CUSHION EXTN, PASS
AHN - RESTRAINT PROVISIONS - CATCH
AHS - RESTRAINT - HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT, ACTIVE
AJC - RESTRAINT - HEAD, FRT SEAT, UP/DOWN ADJUSTMENT
AJF - RESTRAINT - HEAD, FRT SEAT, UP/DOWN ADJUSTMENT, ACTIVE
AJG - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS, FRT & SEAT SIDE, SINGLE STAGE
AKN - WINDOW TYPE - TINTED
AKO - WINDOW TYPE - PRIVACY
AKW - WINDSCREEN TYPE - TINTED
AL9 - CONTROL - SEAT, POWER LUMBAR, DRIVER
AQP - RESTRAINT - HEAD, RR SEAT, CENTRE
ASV - EQUIPMENT - SENSOR AIR MOISTURE & W/S TEMP
AT9 - CONTROL - SEAT, POWER LUMBAR, PASS
AWO - RESTRAINT SYSTEM RR - SEAT BELT, REAR, 3 POINT, CTR
AXG - WINDOW - POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ - VEHICLE TYPE - PASSENGER CAR
AYC - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS FRT, SEAT SIDE, ROOF SIDE, SINGLE STAGE
B6U - FLOOR - LUGGAGE, ADJUSTABLE
B50 - COVERING - FLOOR MAT, FRT & RR, AUX - DELUXE
B72 - PLATE - DOOR SILL CVR
B75 - TRIM EQUIPMENT - LUGG COMPT LINING
BA8 - COMPARTMENT - STOWAGE, FRT SEAT, PASS
BAH - EQUIPMENT - SECURITY SYSTEM, IMMOBILIZATION, STEP TWO
BF7 - COMPARTMENT - STOWAGE, FRT SEAT, LEFT
BFG - SEO COLOR CODE #2 - NEUTRAL WA5236
C1R - ORNAMENTATION INTR - I/P PAD, JET BLACK
C1S - ORNAMENTATION INTR - I/P PAD, SPICE RED
C1T - ORNAMENTATION INTR - I/P PAD, OCEAN
C25 - WIPER SYSTEM - RR WINDOW, INTERMITTENT
C32 - HEATER - HEATING/DEFROSTER SYSTEM, REINFORCED, ELECTRIC
C42 - HVAC SYSTEM - HEATER, OUTSIDE AIR, DELUXE
C49 - DEFOGGER - RR WINDOW, ELECTRIC
C67 - HVAC SYSTEM - AIR CONDITIONER FRT, ELECTRONIC CONTROLS
C95 - LAMP - INTR, ROOF, COURTESY & DUAL READING
C99 - SWITCH - INFL RST I/P MDL MAN SUPPRESSION
C9B - LAMP - INTR, AMBIENT, DOOR
C9D - LAMP - INTR, AMBIENT, CONSOLE
CE1 - WIPER SYSTEM - WINDSCREEN, PULSE, MOISTURE SENSITIVE
CE4 - WASHER - HEADLAMP, HIGH PRESSURE
CF5 - ROOF - SUN, GLASS, SLIDING, ELEC
CJ2 - HVAC SYSTEM - AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CJ6 - COUNTRY - IRELAND
CJ8 - COUNTRY - BULGARIA
CJ9 - COUNTRY - ROMANIA
CK2 - COUNTRY - YEMEN
CK4 - COUNTRY - GREECE
CK7 - COUNTRY - SINGAPORE
CL4 - COUNTRY - UZBEKISTAN
CL9 - COUNTRY - HONG KONG
CR2 - COUNTRY - SLOVENIA
CR4 - COUNTRY - DUBAI
CR5 - COUNTRY - CROATIA
CR6 - COUNTRY - POLAND
CR7 - COUNTRY - HUNGARY
CR8 - COUNTRY - EGYPT
CR9 - COUNTRY - MOROCCO
CS0 - COUNTRY - CZECH REPUBLIC
CS1 - COUNTRY - TUNISIA
CT0 - COUNTRY - SLOVAKIA
CT1 - COUNTRY - BELGIUM
CT2 - COUNTRY - AUSTRIA
CT3 - COUNTRY - GERMANY
CT4 - COUNTRY - LUXEMBOURG
CT5 - COUNTRY - NETHERLANDS
CT6 - COUNTRY - ITALY
CT7 - COUNTRY - DENMARK
CT8 - COUNTRY - PORTUGAL
CT9 - COUNTRY - SPAIN
CU0 - COUNTRY - UKRAINE
CU1 - COUNTRY - NORWAY
CU2 - COUNTRY - FINLAND
CU3 - COUNTRY - FRANCE
CU4 - COUNTRY - SWEDEN
CU5 - COUNTRY - SWITZERLAND
CU6 - COUNTRY - TAIWAN
CU9 - COUNTRY - UNITED KINGDOM
CV0 - COUNTRY - ALBANIA
CV1 - COUNTRY - ICELAND
CV4 - COUNTRY - ISRAEL
CV9 - COUNTRY - TURKEY
CW0 - COUNTRY - ARMENIA
CX0 - COUNTRY - AZERBAIJAN
CX9 - COUNTRY - LEBANON
CY2 - COUNTRY - JORDAN
CY5 - COUNTRY - SERBIA
CY9 - COUNTRY - ESTONIA
CZ3 - COUNTRY - RUSSIA
CZ5 - COUNTRY - SOUTH AFRICA
CZ6 - COUNTRY - KAZAKHSTAN
CZ8 - COUNTRY - MACEDONIA
D2G - COUNTRY - ALGERIA
D2I - COUNTRY - LITHUANIA
D2S - COUNTRY - KYRGYZSTAN
D31 - MIRROR I/S R/V - TILT
D3C - COUNTRY - BOSNIA-HERZEGOVINA
D3G - COUNTRY - CAPE VERDE ISLANDS
D3H - COUNTRY - BELARUS
D3N - COUNTRY - YUGOSLAVIA
D3O - COUNTRY - MOLDOVA
D3S - COUNTRY - QATAR
D3T - COUNTRY - TURKMENISTAN
D3Z - COUNTRY - ANDORRA
D4A - COUNTRY - LATVIA
D4C - COUNTRY - BAHRAIN
D5M - COUNTRY - TAJIKISTAN
D6I - MIRROR I/S FRT VAN - SUNSHADE, DRIVER, W/MIRROR, COVER, ILLUM, PASS, W/MIRROR, COVER, ILLUM
D75 - HANDLE O/S DOOR - BODY COLOUR
D8G - CARRIER PKG - RR MOUNTED, 2 PLACE BICYCLE
DA2 - ARM REST - RR SEAT, STORAGE, PASS THROUGH
DBU - CONSOLE - FRT COMPT, FLOOR, ARM REST SLIDING
DD8 - MIRROR I/S R/V - LT SENSITIVE
DLU - MIRROR I/S FRT VAN - SUNSHADE, DRIVER, W/O MIRROR, PASS, W/MIRROR & COVER
DP6 - MIRROR PROVISIONS - HOUSING, PAINTED
DT4 - ASHTRAY - CIGARETTE LIGHTER
DVA - CLUSTER COLOUR - INST, BLACK, BLACK RINGS W/SILVER TOP
DVN - CLUSTER COLOUR - INST, BLACK, TRANSLUCENT RINGS
DWE - MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, MANFOLD, CNVX/PASS
DWF - MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, PWRFOLD, CNVX/PASS
E17 - BUMPER - 2.5 MPH
E3C - COVER - EXHAUST, REAR PIPE
E6F - COUNTRY - GEORGIA
E6H - COUNTRY - OMAN
E6R - COUNTRY - GREENLAND
E7C - COUNTRY - LIBYA
E7E - COUNTRY - MADAGASCAR
E7J - COUNTRY - MAURITIUS
E7M - COUNTRY - MONTENEGRO
EA1 - POCKET - FRONT SEAT BACK, LH
EA2 - POCKET - FRONT SEAT BACK, RH
EBW - TRIM SEAT - CLOTH, CORDOBA
EBX - TRIM SEAT - CLOTH, SCENE MODIFIED
EBY - TRIM SEAT - CLOTH, LACE
EBZ - TRIM SEAT - CLOTH, RIBBON
ECC - TRIM SEAT - LEATHER, PERFORATED MONDIAL
ELL - PLANT CODE - ELLESMERE PORT, ENGLAND
EMB - TRIM SEAT - CLOTH, TRACK
F45 - CHASSIS - CONTINUOUSLY VARIABLE REAL TIME DAMPING
F82 - RATIO - TRANSAXLE FINAL DRIVE 3.23
FBD - TRIM DOOR - CLOTH, ATLANTIS
FCS - TRIM DOOR - URETHANE, MONDIAL
FM9 - RATIO - TRANSAXLE FINAL DRIVE 3.20
FP9 - RATIO - TRANSAXLE FINAL DRIVE 3.55
FV1 - RATIO - TRANSAXLE FINAL DRIVE 3.72
FV2 - RATIO - TRANSAXLE FINAL DRIVE 4.18
FV5 - RATIO - TRANSAXLE FINAL DRIVE 4.19
FW6 - RATIO - TRANSAXLE FINAL DRIVE 3.42
FX1 - RATIO - TRANSAXLE FINAL DRIVE 3.94
FX3 - RIDE AND HANDLING - AUTOMATIC ELECTRONIC CONTROLLED
FX6 - RATIO - TRANSAXLE FINAL DRIVE 3.87
FXB - RATIO - TRANSAXLE FINAL DRIVE 3.65
FXH - RATIO - TRANSAXLE FINAL DRIVE 3.53
GAL - PRIMARY COLOUR - EXTERIOR, TECHNICAL GREY, MET.2
GAZ - PRIMARY COLOUR - EXTERIOR, OLYMPIC WHITE (G) 8624
GBG - PRIMARY COLOUR - EXTERIOR, BLACK SAPPHIRE, MICA (G)
GCS - PRIMARY COLOUR - EXTERIOR, VELVET RED MET (G)
GCW - PRIMARY COLOUR - EXTERIOR, MISTY LAKE MET (G)
GEK - PRIMARY COLOUR - EXTERIOR, ROYAL BLUE (G)
GEU - PRIMARY COLOUR - EXTERIOR, WATERWORLD BLUE MET (G)
GKE - PRIMARY COLOUR - LINEN BEIGE MET
GNA - CHASSIS EQUIP FRONT - STRUT ASM
GNG - CHASSIS EQUIP REAR - REAR AXLE, COMPOUND CRANK, ADDITIONAL WATT AGE
GOK - PRIMARY COLOUR - EXTERIOR, SILKY SHADOW, MET (G)
GOL - PRIMARY COLOUR - EXTERIOR, FRESKO, MET (G)
GSI - MODEL CONVERSION - SPORT GSI
GWP - PLANT CODE - GLIWICE, POLAND
GZ3 - FUEL TANK FILLER - NECK, UNRESTRICTED
HCZ - PARTS PKG - MISCELLANEOUS CHASSIS
HLE - MERCHANDISED PKG - PERFORMANCE CONVERSION
IK9 - CAMPAIGN PKG - CAMPAIGN "ECOFLEX"
J60 - BRAKE SYSTEM - POWER, FRT & RR DISC, ABS, 16"
J67 - BRAKE SYSTEM - POWER, FRT & RR DISC, ABS, 15"
J71 - BRAKE PARKING - POWER OPERATED
JF5 - PEDALS - SPORTY, ALLOY
JP2 - PEDALS - DOUBLE, DRIVING SCHOOL
K07 - HEATER - RADIATOR, COOLANT, FUEL FIRED, TIMER
K34 - CRUISE CONTROL - AUTOMATIC, ELECTRONIC
K3K - BATTERY - LBN1, FLA, 12V, 50AH, 375 ENCCA
K3L - BATTERY - LBN2, FLA, 12V, 60AH, 438 ENCCA
K3N - BATTERY - LBN3, FLA, 12V, 70AH, 512 ENCCA
K3S - BATTERY - LBN4, FLA, 12V, 75AH, 720 ENCCA
K48 - EQUIPMENT - PACKAGE, EXTREME DUST
K60 - ALTERNATOR - 100 AMP
KA1 - HEATER - SEAT, FRT
KB5 - CONTROL - ECM GRADE BRAKING
KC5 - RECEPTACLE - ELECTRICAL, ACCESSORY
KC7 - RECEPTACLE - ELECTRICAL, RR SEAT
KCL - HEATER - DUCT, RR PASS (2ND POSN)
KG8 - GENERATOR - 130 AMP
KG9 - ALTERNATOR - 140 AMP
KL9 - ENG CONTROL - STOP/START SYS
KRP - PROVISIONS - INFOTAINMENT UNIT DELETE
KTA - AUDIO INTERFACE
KTM - KEY - PRIMARY FOLDABLE, ADDITIONAL RIGID
LBS - ENGINE - DIESEL, 4 CYL, 2.0L, L4, CPI, TURBO, HO, DOHC, 121KW
LBY - ENGINE - DIESEL, 4 CYL, 2.0L, L4, CRI, TWIN TURBO, DOHC, 140 KW,
LDD - ENGINE - PETROL, 4 CYL, 1.4L, MFI, DOHC, VARIABLE CAMSHAFT PHASING, FAM 0
LDE - ENGINE - PETROL, 4 CYL, 1.6L, MFI, DOHC, VVT, VARIABLE CAMSHAFT PHASING, VARIABLE INTAKE MODULE (VIM)
LHD - VEHICLE DRIVE - LEFTHAND DRIVE
LLU - ENGINE - PETROL, 4 CYL, 1.6L, MFI, DOHC, TURBO, PT-JV, 132KW
LPL - ENGINE - DIESEL, 4 CYL, 1.7L, L4, CRI, TURBO-HIGH, HO, DOHC
LPV - ENGINE - DIESEL, 4 CYL, 1.7L, L4, CRI, TURBO-HIGH, HO, DOHC81KW
LSF - ENGINE - DIESEL, 4 CYL, 1.3L, CRI, DOHC, TURBO-VGT
LUJ - ENGINE - PETROL, 4 CYL, L4, 1.4L, MFI, DOHC, TURBO HO, ALUM, GME
M26 - GEARBOX - MAN 5 SPD, OPEL, 65 MM, 1.96 2ND, 1.323 3RD, 0.946 4TH, 0.756 5TH, F17 (WR)
M36 - TRANSMISSION - AUTO 6 SPD, AISIN-WARNER, A6-F40, ELECTRONIC (ACTIVE SELECT)
M7Q - GEARBOX - MAN 5 SPD, 65 MM, 3.727 1ST, 2.136 2ND, 1.323 3RD, 0,892 4TH ,0.674 5TH, (F17 ER)
MDB - MOULDING B/S UPPER - BLACK
MDE - MOULDING B/S UPPER - BRIGHT, WINDOW ALL AROUND
MDG - GEARBOX - MAN 5 SPD, 180MM, 3.909 1ST, 0.892 5TH, F17
MDK - TRANSMISSION - AUTO 6 SPD, AISIN-WARNER, A6-AF40, ELECTRONIC, GEN2
MH7 - TRANSMISSION - AUTO 6 SPD, HMD, X23FHD
MH8 - TRANSMISSION - AUTO 6 SPD, HMD, X23F
MYJ - GEARBOX - MAN 6 SPD, (F40-6, FWD) 1ST 4.167, SIXTH 0.623
MZ0 - GEARBOX - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.74 6TH, (M32 WR)
MZ4 - GEARBOX - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.615 6TH, (M32 WR)
N34 - STEERING WHEEL - LEATHER, 3 SPOKES
N35 - STEERING WHEEL - LEATHER, 3 SPOKES, SPORT
N37 - STEERING COLUMN - TILT, TELESCOPING
N40 - STEERING - POWER, NON-VARIABLE RATIO
N45 - STEERING WHEEL - 3 SPOKES
N52 - STEERING WHEEL - 3 SPOKES, DELUXE
N55 - STEERING WHEEL - LEATHER, 3 SPOKES, SPORT, ERGONOMIC
NE9 - EMISSION SYSTEM - EEC 09
NJ0 - STEERING - POWER, NON-VARIABLE RATIO, ELECTRIC, REDUCED RACK TRAVEL
NJ1 - STEERING - POWER, NON-VARIABLE RATIO, ELECTRIC
P76 - TYRE & WHEEL - SPARE, SPACE SAVER, STEEL 16" (DO NOT USE AFTER M.Y. 2011)
PGQ - WHEEL - 17 X 7, ALUMINIUM, DESIGN 14 (TBD) GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWM - WHEEL - 16 X 6.5, STEEL, DESIGN2 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWP - WHEEL - 17 X 7, STEEL, DESIGN3 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWT - WHEEL - 17 X 7, STEEL, DESIGN5 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWX - WHEEL - 17 X 7, ALUMINIUM, DESIGN8 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PXS - WHEEL - 17 X 7, ALUMINIUM, DESIGN T.B.D, CAMPAIGN MY11 (DO NOT USE AFTER M.Y. 2011)
PZ4 - WHEEL - 18 X 7.5, J, ALUMINUM, POLISHED (DO NOT USE AFTER M.Y. 2011)
PZJ - WHEEL - 18 X 8, ALUMINIUM, DESIGN9 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZK - WHEEL - 18 X 8, ALUMINIUM, DESIGN10 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZS - WHEEL - 19 X 8, ALUMINIUM, DESIGN 12 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZT - WHEEL - 19 X 8, ALUMINIUM, DESIGN13 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZV - WHEEL - 18 X 7.5, ALUMINIUM, DESIGN15 (TBD), GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZW - WHEEL - 18 X 7.5, ALUMINIUM, DESIGN16 (TBD), GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
Q1X - TYRE ALL - 205/55R16 SL 91H BW HW3
Q5Q - TYRE ALL - 225/45R17 SL 91V BW HW3
QAJ - TYRE ALL - 215/50R17-91V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QDR - TYRE ALL - 225/45R18-91V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGRAMS)
QOG - TYRE ALL - 205/60R16-92H BW R/ST TL AL3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QQ5 - TYRE & WHEEL - SPARE, FULL SIZE, STEEL - (DO NOT USE AFTER MY 2011)
QQI - TYRE ALL - 215/60R16 SL 95V BW HW3
QQT - TYRE ALL - 215/60R16 SL 95H BW AL3
QRO - TYRE ALL - 235/45R18-94W BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QUH - TYRE ALL - 225/50R17-94V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QVF - TYRE ALL - 205/60R16-92H BW R/ST TL HW3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QXX - TYRE ALL - 235/40R19-92W BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QYA - TYRE ALL - 225/50R17-94V BW R/ST TL AL3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QZQ - TYRE ALL - 215/60R16-95H BW R/ST TL HW3 (LOW ROLL RESISTANCE) (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QZZ - TYRE ALL - 225/50R17-94V BW R/ST TL HW4 (LOW ROLL RESISTANCE) (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
RHD - VEHICLE DRIVE - RIGHTHAND DRIVE
RT4 - WHEEL - 18 X 8.0, J, ALUMINIUM, DESIGN 1
SF4 - ACCESSORY - WHEEL COVERS - ALTERNATE DESIGN
SFE - ACCESSORY - WHEEL LOCKS
SFO - ACCESSORY - WINTER WHEEL PACKAGE, 16" STEEL
T39 - LAMP - INDICATOR, AUX
T3N - LAMP SYSTEM - DAYTIME RUNNING, SEPARATE CAVITY
T3U - LAMP - FRT FOG
T43 - SPOILER - RR
T4A - HEADLAMPS - HALOGEN
T4F - HEADLAMPS - HIGH INTENSITY DISCHARGE
T74 - HEADLAMPS CONTROL - AUTOMATIC, DELAY
T79 - LAMP - FOG, RR
T94 - HEADLAMPS CONTROL - LH RULE OF THE ROAD
T95 - HEADLAMP CONTROL - BEAM, DIRECTIONAL (AFL)
TBT - PLANT CODE - ST.PETERSBURG, RUSSIA
TQ5 - SENSOR - HEADLAMP HIGH BEAM AUTO CONTROL
TR0 - LAMP - INTR, ROOF, RR, COURTESY & DUAL READING
TR6 - HEADLAMPS CONTROL - LEVELING SYSTEM, MANUAL
TR7 - HEADLAMP CONTROL - LEVELLING SYSTEM, AUTOMATIC, STATIC
TS6 - LAMP - STOP, HIGH LEVEL
TTW - HEADLAMPS CONTROL - AUTOMATIC ON-OFF, TUNNEL DETECTION
TTX - RADIO EQUIPMENT - AUX CONNECTOR (LINE IN)
U04 - HORN - SINGLE NOTE
U07 - HORN - FANFARE
U18 - SPEEDOMETER - INST, KILO
U65 - SPEAKER SYSTEM - 7, PREMIUM
U66 - SPEAKER SYSTEM - 7, CUSTOM
U68 - DISPLAY - DRIVER INFO CENTRE
U74 - ANTENNA - RADIO - NONE
U91 - AERIAL - SHORT, ROOF, RADIO
UAG - INFOTAINMENT DISPLAY - GRAPHIC INFO DISPLAY (GID), VAR 1
UBT - DIGITAL AUDIO SYSTEM - BROADCAST, TEXT
UC3 - CONTROL - STEERING WHEEL, RADIO & PHONE, REDUNDANT CONTROLS
UCU - RADIO - AM/FM STEREO, SD NAV, CD-ROM, CAF, USB, RSA, TMC (GME VERSION)
UCW - RADIO - AM/FM STEREO, SD NAV, CD-ROM, CAF, USB, RSA, VOICE REC (GME VERSION)
UD5 - SENSOR INDICATOR - PARKING ASSIST
UD7 - SENSOR INDICATOR - REAR PARKING ASSIST
UDB - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (SEGMENTED)
UDC - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (ONE COLOUR GRAPHIC)
UDK - INFOTAINMENT DISPLAY - COLOUR INFO DISPLAY (CID) 7", QVGA
UEC - SENSOR INDICATOR - AUTOMATIC AIR RECIRCULATION
UFD - INFOTAINMENT DISPLAY - TIME, EXTERNAL TEMP, RADIO
UH0 - INDICATOR - SEAT BELT WARNING , LH
UH1 - INDICATOR - SEAT BELT WARNING , RH
UJN - TYRE PRESS INDICATOR - AUTO LEARN
UL5 - RADIO - (NONE)
ULS - LOCK CONTROL - STEERING COLUMN
UMN - SPEEDOMETER - INST, MILES & KILO, MILES ODOMETER
UPH - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, SMS
UPI - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, LOW SPEED, GMLAN
UPJ - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, SMS, EMBEDDED PHONE
UQ9 - SPEAKER SYSTEM - (- DELETE)
UQA - SPEAKER SYSTEM - PREMIUM AUDIO BRANDED WITH AMPLIFIER
URC - SWITCH - FLEXRIDE MODE SYSTEM
US3 - ANTENNA - DIVERSITY
UTJ - THEFT DETERENT - ELECTRICAL, UNAUTHORIZED ENTRY
UTR - ALARM, HORN - CONTENT THEFT DETERENT, SELF POWERED
UTT - THEFT DETERENT - BODY SECURITY CONTENT
UTU - SENSOR, VEHICLE - INCLINATION
UTV - SENSOR, VEHICLE - INTERIOR MOVEMENT
UVD - SWITCH - STEERING WHEEL, HEATED
UVT - CAMERA - LANE DEPARTURE WARNING, TRAFFIC SIGN RECOGNITION
UW4 - SPEAKER SYSTEM - 4, CUSTOM
UWI - TELEPHONE - MOBILE, CRADLE, ANTENNA & RECHARGE, FLOOR CONSOLE
UYB - RADIO - AM/FM STEREO, CD-ROM, CAF, RSA (GME/ME/TAIWAN VERSION)
UYI - RADIO - AM/FM STEREO, CDX-ROM, CAF, RSA, MUSIC NAVIGATOR (GME/ME/TAIWAN VERSION)
UZZ - RADIO - AM/FM STEREO, CD-ROM, CAF, RSA, MUSIC NAVIGATOR (GME/ME/TAIWAN VERSION)
V2O - PANEL CENTRE - ONE LAYER PAINT DARK PEARL
V3X - PANEL CENTRE - DUAL LAYER PAINT SILVER DUST
V4L - PANEL CENTRE - DUAL FOIL LIQUID PALLADIUM/DARK MATRIX
V5U - PANEL CENTRE - DUAL FOIL PIANO BLACK & LIQUID PALLADIUM
VFB - PROTECTOR - BODY, QTR OUTER PANEL DAMAGE
VGC - PROTECTOR - FILM, PAINT ETCH PREVENTIVE
VHY - PROTECTOR - BODY SHEET METAL, HIGH CORROSION PREVENTIVE
VK8 - HOLDER - EYEGLASSES
VNF - ISOLATOR - BATTERY
VPQ - VEHICLE PREPARATION - REMOVER, PROTECTIVE SHIPPING WAX
VQ9 - TRAILER HITCH - REMOVABLE HOOK, HEAVY DUTY
VY7 - KNOB - TRANS CONT LEVER, LEATHER
W72 - SALES PACKAGE - DRIVING SCHOOL
W2E - SEAT - FRT BKT, RECARO
W2V - ORNAMENTATION - LETTERING, VAR - DELETE
WBP - SALES PACKAGE - APPEARANCE
WTC - TYRE & WHEEL - INFLATOR KIT (DO NOT USE AFTER M.Y. 2011)
XFE - FUEL ECONOMY - EXTRA FUEL ECONOMY
XJ2 - CHASSIS - SPORT, LOWERED
XJ3 - CHASSIS - SPORT, LOWERED, MODIFIED
XL4 - CHASSIS - PROTECTION KIT, ENGINE COMPARTMENT
XL8 - FREQUENCIES RATING - 433 MHZ
XQ2 - EQUIPMENT - VAUXHALL
Y67 - DISPLAY - REMINDER PACKAGE
Z1V - EQUIPMENT - ADDITIONAL KEY
Z3S - CONVERSION NAME PLT - "ELITE"
ZP7 - SEATING ARRANGEMENT - 7 PASS
VIN Decode
Digit(s)
• W0SV = opel Special Vehicles GmnH
4th Platform
• G = Insignia
• P = Astra J
• S = Meriva-B
5th Body Trim Level
• C = Expression
• D = Exclusiv
• E = SE/Elite
• F = Sri
6th Body Shape
• C = Front airbags
• A = A13DTE (LSF)
• B = A14XEL (LDD)
• C = A14NEL (LUJ & PL5)
• D = A16XER (LDE)
• E = Z16XNT (LGE)
• F = A17DTR (LPL)
• G = A17DTJ (LPV)
• H = A17DTS (LUD)
• J = A16LET (LLU)
• K = A17DTC (LUE)
• L = A20DTL (LBQ)
• M = A20DT (LBR)
• N = A20DTH (LBS)
• P = Y/Z20DTJ (LBX)
• R = A20DTR (LBY)
• S = A20NFT
• T = A14XEL (LDD)
• U = A14NEL (LUJ)
• V = A17DTL (LPV)
• W = A17DTE (LKR)
• X = A17DTE (LKR)
• A = 2010
• B = 2011
• C = 2012
• D = 2013
• E = 2014
• 1 = Rüsselsheim, Germany
• 2 = Bochum, Germany
• 3 = St. Petersburg, Russia
• 8 = Ellesmere Port, United Kingdom
• G = Gliwice, Poland
We've got them in the other sub forums so thought I'd put the J ones in here (Y)
Olympic White - GAZ / 40R
Power Red - GBH
Technical Grey - GAL / 177
Sovereign Silver - GAN / 176
Carbon Flash - GAR / 22C
Metro - GBI
Velvet Red - GCS
Misty Lake - GCW
Waterworld - GEU / 22A
Silver Lake - GEV / 179
Linen Beige - GKE / 55U
Myth Green - GAY / 30K
Pannacotta - GBF / 167
Black Sapphire - GBG / 20R
Iceberg - GEP
So that we don't end up with too many stickies, I've brought Stickman's paint codes info into the top post of this reference thread and fleshed it out with some more info from brochures and the Opel Info site. If anyone has more paint info or can fill in missing bits of info in the top post, please let me know! :thumbs:
Fresh Blue or fresco is missing :) GEM / 22M
No it is there (in the top post where I added extra information, not in Stickman's original post)
Discussion Starter #12
Discussion Starter #14
Discussion Starter #15
As suggested in another thread, I have added a list of fuses. I've taken the info from my owner's manual to get us started - if anyone has additional info (amp ratings of the fuses, info about different options and specifications etc) please post anything you have here and I'll add the info into the top post.
fearing another :slap: but here are some more from the list on AOC :couch:
Rear electrical Centre
F7 -10A- Seat heating control module, seat lumbar control module - passenger
F14 -15A- Not used
F15 -7.5A- Inside rear view mirror, rain sensor, vehicle direction camera
F16 -5A- Inside rear view mirror
F17 -20A- Accessary power receptacle - cargo (Estate with rear body fuse block)
F26 -30A- Feed for fuses F3, F8 and F32
F27 -30A- Not used
Discussion Starter #17
Fixed that for you:
Here's some more info I found out entirely by myself without help from any inferior forums:
F14 -15A- Not used
F27 -30A- Not used
Info added to top post :thumbs:
In addition to the above F15 is also the fuse for the motors in the automatic adjustable wing mirrors. I guess this is a typo in the manual and should have read as "Outside rear view mirror"
1 - 20 of 41 Posts
