Hi all,
So my wifes car 2014 astra J diesel estate 1.6ecoflex has a sticky caliper which im going to replace tomorrow (hopefully...) I know i will need to change pads and quite probably the discs as well. The disc did get very hot and has been driven for a while before she said anything to me. That said the disc shows no sign of burning or tarnishing or cracking. Should I change these out?
I was looking online for a procedure (wife will kill me if i dont get it all back together) and found this re the disc replacement. see link below.
which then links to a procedure for removing the caliper housing as shown below:
It seems to imply that i would need to replace the 2 bolts holding the caliper housing in place. Shown in step 6. Is this correct?
Or is there enough room to swap the disc out without disturbing the housing once caliper out of the way?
Any help would be much appreciated,
Best wishes,
New astra owner!
Vauxhall Workshop Manuals > Astra J > Brakes > Disc Brakes > Repair Instructions > Rear Brake Rotor Replacement
Astra J > Vauxhall Workshop Manuals > Brakes > Disc Brakes > Repair Instructions > Rear Brake Rotor Replacement
workshop-manuals.com
Vauxhall Workshop Manuals > Astra J > Brakes > Disc Brakes > Repair Instructions > Rear Brake Caliper Bracket Replacement
Astra J > Vauxhall Workshop Manuals > Brakes > Disc Brakes > Repair Instructions > Rear Brake Caliper Bracket Replacement
Best wishes,
New astra owner!
