1 - 2 of 2 Posts
Hi guys
Although I’ve used this forum for info for various bits and bobs for a while I have never posted so please be easy!
My drivers side door speaker hasn’t been working, so I took it out thinking the unit had gone, bought a new unit and it still doesn’t work. I have tested the cables and get 0.5v so nothing yes have normal sound on the near side.
The loom looks ok through the door looks in tact, and the cable looks to go down on the other side. Where do they go, I think I’ve found the fuse which is no good as the other is working.
any ideas?
Have you definatly cleaned connector contacts properly as that fixed mine also if you havnt owned car too long check previous owner hasn't messed with speaker balance as the previous owner had done that on mine instead of fixing
1 - 2 of 2 Posts
