Hi all.
I have an Astra J estate 2011, auto box and just wanted to check what you thought of my Aircon observations.
Fan speed set to number 4. Outside temp 28oC inside vent temp 7.5oC.
Regards
Paul
If you want maximum cooling from the AC system, then switch on the recirculate button so that you're not trying to cool warm air that's being drawn in from outside.
IIRC, you should be getting something like 5 deg C at the centre vent with the fan set at a normal speed. When you start turning up the fan speed, you also start to lose some of the cooling effect.
Hi Big Dave, thanks for the information, what number is normal speed?
