Anyone know if you can access the wind screen washer bottle (to clean the filter) without removing the bumper ? The car has spotlights fitted so no access through the trim. Cheers for help !
There isn't a filter unless its built into the bottle. To remove bottle you need to remove the top V grille as there is a 10mm nut behind it.
There's a handy gap between the bumper and the arch liner to get your arm up. Easier with the car up in the air though as otherwise you have to do it all lying on the ground.
The filter is part of the rubber top hat bush that seals the pump to the bottle.
