Hi Guys,
I have a 1.6 Astra H SXI and Intermittently I have problems starting the vehicle..
SOMETIMES when turn the ignition, It seems to initially ingage, and then CLICK CLICK CLICK. I will remove the key from the barrel and its still CLICK CLICK CLICK.
When I try the key again, the car does not respond atall...
I have changed the CIM module
I have bench tested and tested on load the Starter Motor, its fine
My battery has plenty enough amp cranking power (tested by halfrauds and myself)
I have sent my ECU off to be tested and it came back no faults found
Tech2 reads no present issues, no EML on and drives normally
My mind is boggled what I could try next?
Astra_h_Mat
Astra_h_Mat
