any guides on here (have searched and cant find one)
anybody feel they would like to give me instructions on how to?
cheers
It's fairly straight forward to do.
1) Remove rear lamps. Reach in through the flaps in the corners of the boot and undo the little nuts (2 per side) and unplug the wire. The lamps then pull out from the outside.
2) Take off number plate, this gives you access to two screws.
3) Two further screws each side in the rear wheel arch.
4) Pop out number plate lights and disconnect wires.
5) Pull at edges of bumper to unclip from guide rails on quarter panel under lamps.
6) Refit in reverse (Y)
