i have a 1.9 150 5 door sri and saw a design 5 door that was breaking, managed to get ahold of the front and rear door looms, rear window switchs, rear motors and already have the door cards. also have a new drivers door switch on the way. is there anything else needed to get these to work ? i have checked i have the 25amp fuse in rec no 23.
the reason i ask is because i searched on here and some people said it needed to be tech2'd, but also i noticed when changing the rear looms the part that actually connects to the rear door from the sill part - only had 1 pin in the rear loom (my old 1) and the new rear loom has 2 pins. But the part that connects at the sill only has 1 pin in it ?
hope you's understand what i mean, basicly is it jus the front and rear door looms needed or also the part that connects the rear to the front at the sill, to wherever that part actually goes to.
