1 - 7 of 7 Posts
Hey All!
My engine oil switch light is due a replacement with the intermittent light on the dash.
When going to replace it with the normal I've noticed that I had a 1 pin oil switch rather than the standard (I'd purchased below).
Is this a standard switch for the Mk5? If so anywhere I could purchase one? Lol
Thanks for your help!
Automotive tire Water Motor vehicle Automotive exhaust Gas
Hand Finger Cable Gadget Nail
You don't say which engine this is and there are a few in the mk5,however if the replacement sensor is a single pin then someone has lopped off the original connector and put a lucar connector on it to fit a pattern part switch
  • Like
Reactions: deeloughran
certainly doesn;t look like a factory part or connection, the new parts is the one it should be, no idea why they would have used a differnt sensors given they cost peanuts in the first place even for ac delco sensors.
Are there any scrappies/recyclers in your area ?
Discussion Starter · #7 ·
Thought may have to go down this route lol yeh there's a few....I'm needing the oil pressure sensor from one of the looms (they'll know better than me...I could at least point to it lol)
1 - 7 of 7 Posts
