I could really do with some advice on this.
i picked up a 2.0turbo astra H estate the other day. basically when i applied the brakes the pedal goes hard put the car doesnt stop too well. so today i fitted new brembo front discs and pads, bled the system and it is still acting the same.
i have done the brake servo test, by pumping the brake pedal while the engine is off, i then turn it on and the pedal does sink about 2".
now another thing i have noticed, when i pull off my drive and set off down the road, i hear a click as though one of the pedals have banged up. its hard to tell if this is from the footwell or in the engine bay? just wondered if this is a contributing factor to my problem.
what i have read so far is that the brake servo is faulty? is this my case even though the pedal drops on the brake test? i have checked the pipe from the servo to the inlet manifold and it doesnt appear to be leaking.?
any advice would be great.
