hi guys i have recently brought a astra h 1.9cdti since then my engine light has came up. shorty after went off then came back up again. engine went sluggish for a little while and then regained its power. since returning home i went back out to start it and what happens is it runs very ruff smokes quite a lot and then cuts out. anybody have an idea of the issue this could be? thanks Jordan.
Really need the codes read, chances are the egr needs cleaned, probably the boost control solenoid or the pipes coming off it
Do a pedal test, hold brake and accelerator down, put key in and turn key until dash lights up, it should display a code!
sounds like egr valve! Common problem.
good luck
I second most likely the EGR valve at this point. If you have the tools, take a 10mm and 13mm to the EGR, and check whether it's caked. Most likely is.
