1 - 8 of 8 Posts
I installed an after market double din sterio quite a while back on my astra H, however i cant change the time on the astra screen display which shows the mpg etc it didnt really bug me as the sterio displays the time, but passengers started saying 'why you got the wrong time' and i feel silly saying 'i cant change it after i changed my sterio' LOL
so guys how would i change the time??? or who would i go to in the London region? and how much??
THANKS!!!:thumbs:
If you have the original headunit you could put it back in temporarily. I think there is someway to do it if you have the connects2 steering wheel adapter but can't remember how to do it.
Edit for Connects2 adapter if you have it: Press the bottom button on the left control for 2 seconds “system” will show in display, scroll volume button till you get to clock, use up/down button to change time; when you have the right time use volume to move onto date and the time will be set, press bottom left button again to exit.
Thanks to Planetse from a different thread
You'll have to put your old head unit back in temporarily to change the time. Then switch back to your new head unit.
With 2 X time changes in the UK each year, thats how often you'll be doing it unless youre prepared to live with it.........
or use a matching oem pair (Y)
you can set the time on it using steering wheel controls or you can use tech2 or opcom to set it
Or he can buy a compatible lead which may also allow the steering wheel controls to work. Doesnt work with every head unit on the market though so he'd have to check compatibility
1 - 8 of 8 Posts
