Hi guys,
My son's Astra H keeps cutting out, the car will start again immediately no probs and could be ok again for a few hrs or even days but then this problem will repeat.
We have replaced the crankshaft sensor as we read this could be the cause of the problem, but the fault remains.
Normally, this would only happen when idling, however, today this happened whilst the car was in motion, albeit, this happened whilst the clutch was pressed and in the process of a gear change.
I have placed an opcom on the car and cleared the fault code list, but the following errors returned when the fault happened again:
Control Unit: 2006_Astra-H_Engine_Z 17 DTH
Total number of fault codes: 5
P1895 - Limp home - Limited Performance
(54) - Not present
P0500 - Vehicle Speed Signal Range/Performance
(74) - Not present
P2147 - Injector 1 or 4 Malfunction
(OF) - Not present
P2150 - Injector 2 or 3 Malfunction
(OF) - Not present
P0268 - Cylinder 3 Injector Circuit High
(OF) - Not present
My son has also mentioned that the car has never entered limp mode even though the fault code list stated otherwise, performance has never been lost.
Any ideas please on what would be worth investigating to resolve this issue please?
(54) - Not present
(74) - Not present
(OF) - Not present
(OF) - Not present
(OF) - Not present
