Hi, i've got an astra h Sri 1.8.. On an 08 plate its z18xer engine. I've got error code p0365 pointing to the cam sensors. I had a loss of acceleration while I was travelling on a long journey and the check engine (spanner) light come on for the rest of the trip. I had it in the garage and he confirmed the code is stored. However it was present when it was on there computer. On a side not I've not had the loss of power or light since. I did have a hole in my exhaust and since I had it replace I've had no issues. I've also noticed my battery has a build up around the positive terminal and I've had problems with my ground on my amp for the stereo could this cause sensor problems? . Where do I start? Battery? Cam sensor? I can't seem to find the correct part for the cam sensors. All the sites I go on say they don't fit my vehicle. Any help would be appreciated.
Here where they are located. Inlet is the back of the engine, outlet is back of the engine. Being sensor B, its likely pointing the the outlet - however id change both just for peace of mind. Part number is
White Automotive tire Hood Product Motor vehicle
