Hello guys,
i have noticed there is this bluish smoke from the exhaust not very regularly but have experienced it twice this week. About medium thick bluish smoke, only visible when the vehicle is stationary like in traffic. It does not increase when the accelerator is stepped on. Kinda weird.
Then after driving awhile it just vanishes and reappears a few days later. Is something building up that i have to check before it gets worse?
Discussion Starter #2
guys i noticed some oil stains in the mornings, on the ground. discovered that the oil return tube from the turbo to the engine is bent, thus is leaking oil, when engine is running, unto the exhaust pipes and other parts of the engine body, burning the spilled oil in the process and causing alot of smoking.
is there a way these kind of pipes can be repaired or mended or welded without replacing because it very tight down there.
