1 - 11 of 11 Posts
Happy new year everyone!
I've been having lots of problems with my car such as bad fuel consumption, hesitation when putting the car under load, struggling to start the vehicle and even occasionally stalling out after eventually starting.
I decided to try doing a pedal test, thought nothing of it as mechanic told me his device picked up 0 errors therefore he wouldn't fix however the car has picked up 6 in total.
Im just worried as to how much its going to cost and would like some advice on what to do with the car. Since picking it up in april for £1000 im forking out a lot of money in fixing it up so its worrying there is more issues.
Heres a list of the codes I got:
P0597: Thermostat Heater Control Circuit Open
P0130: O2 Sensor Circuit Malfunction Bank 1 Sensor 1
P0136: O2 Sensor Circuit Malfunction Bank 1 Sensor 2
P0365: Camshaft Position Sensor 'B' Circuit Bank 1
P0340: Camshaft Position Sensor 'A' Circuit Malfunction
P0621: Generator Lamp L Control Circuit Malfunction
Am I looking at spending a lot on this/is it even worth it or is it looking to cost not too much?
Hi
I wonder if you have a blown fuse in the engine fuse box, possibly fuse 26.
Here is a link
There is a section for the 18xer engine. You don't have to donate to the link site, just open it up a 2nd time to see it.
Hi mate
just got around to looking at this thread again. I've went online to get some replacement fuses and was wondering if the Astra H uses Standard Blade Fuses or Mini Blade Fuses.
33043
33044
Cheers Davo!
And to answer your question Chris im honestly not sure. Don't know how to read the codes very well ill post the full ECN numbers here though and you might be able to help!
  • 034004
  • 062103
  • 036504
  • 013601
  • 013001
  • 059704
Update:
I purchased an OBDII scanner from Amazon, I've cleared the codes and only these codes have re-appeared:
-P0365: Camshaft Position Sensor 'B' Circuit (Bank 1)
-P0340: Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor)
-P0597: Thermostat Heater Control Circuit Open
I just need the car running normal ASAP so I've dropped it into my local garage where I've taken the car for services and any little bits that have been done to it. I'll let you all know how I get on with it and what the fix is!!
Yep checked the fuses and all was good.
Took it to my local mechanic last week and have been changing sensors out one by one. The O2 came up but that was knocked out once the Cam sensors were changed.
The thermostat error was that the wiring connector on the housing had corroded. The mechanic fitted one back in april so he replaced that today for me free of charge. All the codes are gone now!!
Luckily it has only cost me around £150 to sort it all so i'm very pleased :)
Unfortunately the car still doesn't start first time and can occasionally idle a bit rough however now these sensors are replaced and the thermostat is replaced the car actually drives perfect and my fuel economy has shot back up.
Theres no errors anymore so I'm not gonna spend any more trying to find why it doesn't start.
If anyone on the thread has an idea why its doing it then fire away in the replies :)
Record a view of what is happening - and post it on here.
1.8 engines are normally quite reliable - and dont really struggle to start.
Try unplugging the MAF, and see if that helps it start...
1 - 11 of 11 Posts
