Problem with fault code p2279. When I start the van I get p2279 p fault come up. When I rev the engine over 3k revs it goes out. When I put my foot down sometimes the Eml comes on and I can’t rev past 3k unless I turn ignition off then on again. Have replaced manifold pressure sensor and wastegate solenoid motor but still no difference. Please help
Clean the map sensor, egr and check the boost control sensor, on a 1.7 the BCS is at the back of the engine
Might be worth while changing the pipes to and from the BCS as well, mine ran like that for 2 yrs before the garage finally found the problem
I replaced the boost sensor and map sensor, the black egr pipe is dirty, was maybe thinking about cleaning the inlet manifold out next
