Hi everyone,
today i had a small coolant leak, at first i taught that it was coming from the pipe but then i realised that it is from the the nipple of this part
the problem is that this part I don't know what it is and what it does, one of its pipes goes to the cabin heater thats all i know
picture of it is below
thanks
Hi everyone,
thanks
Hi
That part appears to be the exhaust gas recirculation (egr) valve which is cooled by the water cooling system.
hi again,
thanks redman you are right :lol:
today I fixed the leak removed it and did some welding on the leak and so far so good.
I still looked on it on eBay and it is the egr valve.
thanks for the advise
Hopefully you will have sorted it, you can pick a new one up off eBay from around £70 if not. These egr valves often cause problems with a lot of cars when they become blocked and stick. Was it fairly clean inside?
