Hello!
I have a problem with light switch or something like that.
Firstly, when car is turned off, I can switch between parking lights and regular lights, but it won't turn on instrument/dashboard lights and lights behind radio and there (don't know exact word for that), but the lights behind the light switch goes on like it has to. When car is turned on, there is only one mode, regular lights, even if I switch it every where, it does nothing. I change bulbs from instrument, still nothing, changed light switch, what works 100%, still nothing. I changed some dodgy fuses, still nothing. Also number plate light does not work aswell, changed the bulb, nothing, but I'm not sure if it's related to that or not.
Also dimmer does not work on light switch (obviously), but the height thing on lights work.
Car is 1998 Astra G 1.6 8v
I hope someone has had the same problem, any ideas?
Does your A/C unit, cigarrete lighter and centre console display turn on? Should light on in ambar/yellow color if everything is OEM
