How to… Performance manifold into Mk4 Astra.
Parts:
Fitting kit
Gaskets - Not supplied with manifold. Can be purchased from Vauxhall or a local autofactor
Tools:
Hydraulic jack and axle stands but preferably proper ramps or a vehicle lift.
Socket set with star sockets and extender bars
Spanner set
Adjustable pliers/mole grips
Angle grinder
Safety goggles
Hacksaw
WD40
WARNING!
Ensure you have left the engine to cool sufficiently before starting as the components that you are removing become extremely hot extremely quickly even if the car has only been moved a short distance!!
Step1:
Check you have all tools required and all of the parts for the manifold and fitting kit. There’s nothing worse than getting half way through a job and realising that something is missing, especially when you’ve just cut your exhaust in half!!
You have been warned!!
Step 2:
Move the metal and rubber pipe out of the way by removing the three bolts on the front of the block with a star socket then lift the pipes up onto the rocker cover out of the way.
Remove the dipstick and the rubber hose going in to the rocker cover, on the right using adjustable pliers/mole grips.
Remove the four bolts securing the heat shield using a star socket. Mine are allen key bolts as they are aftermarket ones but the standard bolts are star bolts.
Step 3:
Remove the ten nuts holding your old manifold in place ensuring that the engine has been left to cool as the heat will cause the metal to expand and can cause trouble when removing them. Some will come off with the stud still inside and some will come off on their own this is normal so don’t panic. If they have gone slightly rust apply some WD40 and allow it to soak in for a few seconds.
The three lower circles that appear empty show the approximate location of the bolts under the manifold.
Step 4:
Apply some WD40 and remove the two bolts holding the bottom of the manifold in place.
Step 5:
After removing the old manifold lay it next to your shiny new one and appreciate the craftsmanship involved in it’s construction while seeing the shocking difference between the two!!
It’s easy to see why it improves exhaust flow when you see them like this!! Can you guess which is the new one??
Parts:
Fitting kit
Tools:
Spanner set
Angle grinder
Safety goggles
Hacksaw
WD40
WARNING!
Step1:
Step 2:
Step 3:
Step 4:
Step 5:
