1 - 2 of 2 Posts
Hi,
I have been having issues with my Z17DTL on my Astra 53 registereed on 01/12/2003.
It appears to cruise ok but occasionally you get the odd clank noise and it jults a little bit when requesting more power and dies. Roll to a stop and then it restarts fine but you hear the clanking noise more often for a while.
I have OP-COM and have had the following codes:
System Type: ENGINE SYSTEM DIAGNOSTIC & INFORMATION
Name: Z17DTL - EDC 15C7 - 1.7L - 59 (80)
DTC: P0204,Cylinder 4 Injector Circuit High
DTC: P0202,Cylinder 2 Injector Circuit High
DTC: P0203,Cylinder 3 Injector Circuit High
Removing the Turbo pipe from throttle housing is looks like this:
https://drive.google.com/file/d/0B0mqMzgW1uCOZ3Q0TUFJSUtrREdwNk96cVJsMk9BbVZNeU9B/view?usp=sharing
https://drive.google.com/file/d/0B0mqMzgW1uCOLWM3UndDcTk3TmNwSDFhaVJLSDJKWXYxeUVN/view?usp=sharing
https://drive.google.com/file/d/0B0mqMzgW1uCObDRXRnZVUERjLVRaazNLbVh1dTRRbXpNY1VN/view?usp=sharing
Hey I've got the exact same car as you with the same fault codes coming up! Mine wont start now tho you have any luck fixing the problem??
1 - 2 of 2 Posts
