Hi Guys, im new to this forum hence this is my first post, and i'm hoping someone could help me
My Astra keeps going into limp mode every couple of weeks which is strange. The initial diagnostic from Vauxhall was throttle position sensor fault so i had the throttle pedal replaced. Still went into limp mode so i had a new throttle body installed, same again, finally i had a new ECU installed.....still happening!!
Vauxhall's latest diagnostic came up with an alternator fault code??
Because the car goes into limp mode rarely makes me think it could be a connection problem, like wiring or plug pins?
I was using a DTUK Eco3 box but taken it off for the moment. The latest fault code, using the brake/throttle method is ECN 062202.
Any help would be appreciated, thanks.
