I am currently struggling with the following electrical issues with my 56 plate Astra H Z17DTH:
The fault codes I cam currently getting from Opcom include:
U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
U2143 - CAN-Bus No Communication with SAS (Steering Angle Sensor)
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
The issues I currently have are as follows
- Both the air con and heater no longer function - the light for the air con no longer turns on. The same goes for the rear heated screen - however it does seem to work still even with the light not coming on. The blowers still work OK - however with no temperature variation.
- The ABS is no longer functioning - see above code
- I am unsure to why I am getting the ECM code
- When the steering wheel is turned - the stereo seems to cut out and the alternator seems to spike - is this either a bad ground or has the voltage regulation gone on the alternator?
Any help with any of the above issues would be much appreciated.
Thanks.
Have you tested the alternator and battery?
The battery is fine and the voltage is OK - however I am yet to test the voltage directly from the battery from the engine bay - I have only checked this through the hidden menus however I am unsure of the reliability of this and where the test point is.
Thanks.
