Hi all, first of all i hope you all had a wonderful Christmas..! Secondly, i would appreciate your help if possible please guys. I have an astra H 1.3cdti 2008 109k (Z13 DTH). Around 2 weeks ago the car just cut out on me randomly, i was doing around 10mph at the time just setting off on a round about and the car just turned off. I tried re-starting it straight away but nothing was happening, i could hear the starter motor turning but no luck firing up. Eventually after 2 mins the car started up fine but in limp mode so i managed to get it home. I then did a quick re-start and the car was running perfectly. Then again yesterday i was setting off from traffic lights after a 15 mile journey and i managed to drive around 6 meters and again the car conked out. Wouldn't start for a good 5/6 mins, then eventually started and was perfect again. I put the laptop onto the car using opcm software and it came back with P0400-61 which is the EGR Valve which i have blocked off and the second error was: P1191-67 Rail Pressure Range/Performance. Does anyone know if this is the rail pressure regulator at the end of the fuel rail problem or if it's something else? car was serviced around 9 months ago with all the filters including the fuel filter by the garage. I can hear the fuel pump turning on and humming when i turned the ignition on when i had the problem. Any help would be very much appreciated. Should i start off changing the fuel filter? Then the fuel regulator? Also do i need to de-pressurise the system first then change it? Thank you very much for your help in advance guys. Thanks
