Hi all, has anyone got a wiring diagram for the astra h van z13dth
Engine loom specifically the part round the back of the engine, I have a small earth wire not attached to anything it's on the part between the alternator and the starter motor the starter motor works and the alternator has a pulse/signal wire attached, by the way I bought the van as a non runner, the timing chain I just replaced and it still doesn't run, I'm clutching at straws now and just want to get her going!
Cheers people
have you tried checking it with a multimeter to see if its + or - ?
is the engine actually turning over?
is there fuel at the injectors?
No I haven't checked it with a multimeter, however I can do in the morning, the engine is turning over and yes there is fuel at the injectors, cheers
