Hi,
Angel eyes headlights the passenger side sits a bit high, is there any fix for it? Has anyone managed to get them sit properly?
AON - Administrator
What do you mean it sits high? The light unit sits high in comparison to the bumper? The light unit appears tilted? The lamp inside the unit looks visibly higher than the corresponding lamp in the other unit? The light unit is fine but the projected light is higher that the opposing side?
Assuming it isn't simply what you've mentioned in the other thread, the light unit should be adjustable. First make sure it is correctly located and fastened to the car. Make sure the bulb is correctly located within the unit. Then look for adjustment screws, usually quite large and often with Allen key heads, on the outside of the unit. Using online guides on how to correct beam patterns adjust the screws accordingly.
Cheap headlights rarely sit right, they are what they are........cheap
