Dear All,
I have an Astra G 2003 Model 1.7 Diesel and have been experiencing some problems.
Car with AC on (Fan on 2) 13.5V
Car with AC on (Fan on 4) 13.4V
Car with AC on And lights on 13.29V
Car with AC on Lights on and bright on 13.00 - 13.10V
As I said the electrician still says there is something wrong. Does anyone know the proper voltage of the alternator at the stages as above?
Can anyone help??
Best Regards,
Keith
- First I noticed that the car took long to start after using the AC and Lights
- Then one fine morning the battery went flat and couldn't start
- After using the jump leads to start the card i checked the voltages with volts meter and were dropping to 11.8V
- Hence I changed the alternator with a new one and went for a bigger one from 70 Amp to 100 Amp.
- The voltage has improved but the electrician still says there is something wrong. Voltages are as follows:-
Can anyone help??
Best Regards,
Keith
