I have done the search and found this thread
http://www.astraownersnetwork.co.uk...-Where-Why-and-How-Much&highlight=boost+guage
Now going from that thread I see the parts and there numbers that are needed to replace the manifold and so-forth
But when I did check on some of the numbers there where 2 options so I had added both neither cost much so better to have them than to not and need them
<tbody>
</tbody>
Im just looking into this atm need to save the near $700oz just for parts.
Is there anything else I need?
What other parts could I change while in there ?
Im hoping this may help in the mere 350miles per tank im getting atm but in saying that this current tank of fuel has lasted 5 weeks as I only live 4kms from work and thats with only two longish trips 70kms round so not to bad if u look at it that way
Any help would be great....also ive heard something about if im buying from overseas sometimes you can get away without pay VAT ? not sure how this works
Thansk
NZSHAKER
1 | x | Manifold | 55210201 |
1 | x | Manifold Gasket | 93179058 |
1 | x | Induction Manifold Gasket | 93179058 |
1 | x | EGR Gasket | 93181665 |
1 | x | Throttle Valve Body To Induction | 55205453 |
1 | x | Throttle Body to Induction Manifold Gasket | 55205453 |
1 | x | Swirl Actuator | 55205127 |
1 | x | Sealer/Locking compound | 90542117 |
1 | x | Actuator Arm | 93186274 |
1 | x | HP Fuel Pipe | 55215517 |
1 | x | HP Pump Pulley Nut | 93178824 |
1 | x | HP Pup Pulley Washer | 93178879 |
12 | x | Manifold Nuts | 93178880 |
<tbody>
</tbody>
Thansk
NZSHAKER
