I noticed that my right headlight levels too high, very high actually, almost like the high beam. I connected with OP-COM, run the scan and ended up with no fault codes from AFL, tried the tests, lights move up and down, left and right as they should. Then I tried to push the back of car to check if the level sensor on rear axle works and it does. I thought maybe there is a way to re-calibrate the lights but I have not managed to find such option. Is it the hardware problem or it is solvable on the software level?
