Evening
Having problems with my Astra, its currently not starting it's cranking over but won't fire, done the pedal test which returned the following but not sure if any of the codes it returned are the answer to my non starting issue,
codes
P0340
P0500
P0380
I have today removed all the EGR setup and cleaned as it was pretty bad, new battery as that was needed anyway.
Any help greatly appreciated, I live in Colchester, Essex if there is anyone local willing to lend a hand as I'm stumped.
Thank You
Richard
Hi
Thank you for reply, yes I have looked to see what codes mean but not quite sure what to do with the info as the glow plug code is quite vague, does it mean replace glow plugs? The other code is camshaft sensor, just really stuck with this and need to get the car running as its my partners,
thank you
Richard
