1 - 12 of 12 Posts
Hi all, I've a 2013 astra that's had the headlights replaced off a 2015 petrol vxr as mine is a vxr rep. they plug in ok and the daytime running lights work and also the indercators work fine. I have no headlights or dipped beam can anyone tell me do I need to have them coded to the car please? I'm in Northampton
Are the light exactly the same? Or were your originals halogen and new 1s xenon?
thank you for your reply I can't be 100% to be honest as the original lights were taking by cmg when the car was recovered for some unknown reason. I believe that maybe the case though. dose the year make a difference as the new ones are off a proper petrol vxr 15 plate? they plug in as I said mate, day time running lights & indercators work so im at a loss with it
Hi all, I've a 2013 astra that's had the headlights replaced off a 2015 petrol vxr as mine is a vxr rep. they plug in ok and the daytime running lights work and also the indicators work fine. I have no headlights or dipped beam can anyone tell me do I need to have them coded to the car please? I'm in Northampton
thank you for your reply I can't be 100% to be honest as the original lights were taking by cmg when the car was recovered for some unknown reason. I believe that maybe the case though. dose the year make a difference as the new ones are off a proper petrol vxr 15 plate? they plug in as I said mate, day time running lights & indicator work so im at a loss with it
The plug will fit but if it was halogen headlights, the plug won’t be set up for xenon
ok mate so is it a case of a rewire or what do I need to do please?
Probably extra pins and reprogrammming, Iv done it on a few H’s but not on a J tho
Discussion Starter · #8 ·
where abouts are you based mate could you have a go for me can you do the programme too?
Iirc the programming on the Astra h is different to the j, I’m in Glasgow , but there’s a few good specialists about
Discussion Starter · #10 ·
thank you for your help bud is it an expensive fix can you recommend anyone sorry for all the questions
Il have a check about tomorrow, where are you based?
1 - 12 of 12 Posts
