1 - 1 of 1 Posts
Hi, i m a newbie with a electrical problem @ the turbo boost solenoid, the turbo doesnt come in at all , after checking out the solenoid i have found that it is getting vacuum in but the solenoid does not open to allow vacuum to the turbo waste gate allowing it to close, checked the solenoid and it powers up ok so my problem is the electrical supply to the solenoid , only code showing is p0571 which refers to brake switch and as it is multi wire to the switch i was wondering if one of the wires has anything to do with this fault.
Cheers
1 - 1 of 1 Posts
