1 - 20 of 47 Posts
Banned
Right I know this has prob been covered but i cant find it
Been looking for a 1.9 150 but have noticed loads of 120's, I heard if they are both 16v's I can get the 150 software loaded onto the 120
Is this 100% correct. I would then add the tuning box, would i see the same results as a 150
cheers
Yeah but only early models would have the 16v lump in
The 150 is a better engine than the 120 8v
But the 8v doesnt have the dreaded swirl flaps!
you are right and wrong.
There are a very small amount of 1.9 16v 120bhp engines about. However, this is a very limited amount.
The majority of the 1.9 120 bhp engines are infact 8v.
Hope this helps (Y)
if its the 120 16v engine your best bet is a re-map you will hit 200bhp no messing
altho in about 06 the switched to a v8 head in the 120 and this is totally diffrent altho with a tuning box you will hit about 160bhp + and road tests confirm its just as quick 0-80 as a 150 running at 200bhp :D
Banned
the 120 seems to be a lot cheaper, i just wanted to check if the only difference was the map
is the oil filler is on the right on the 16v? 8v on the left?
Yes bud, This is the 16v engine with the Yello oil cap on the right.... Its on the left on the 8v engine...... (Y)
Hope this helps....
Banned
cheers guys
ive seen a 150 for £6500 with 65k on the clock. good price??
looks nice in pics so just waiting on my log book coming back to get the cash :)
cheers guys
If its an XP with a few extras then it a V Good price if not then its about right.... (Y)
Banned
Discussion Starter #15
its a design with climate and better screen
no xp. standard wheels, but i like the auto stuff. will haggle tho
Hope this helps. You can clearly see the rod Super-Dan is on about. This sometimes comes off the swirl valve caps & results in a new inlet manifold being required.
1 - 20 of 47 Posts
