Hello,
i have this code keeps coming up and it coming up with 2 problems one saying
Identifier: 0x0103
Hardware number:12222040
Motor type: Z16XEP
Part Number:12230740
Software version number: 01AB673C
Programming Date: FFFFFFFF
Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
System description: DELCO0100
Type approval number: D04004
ECU Software version number: 10
Alpha code: TB
Hardware manufacturer system name: MT35E
Software version: P1003A10
ECU variant coding: 0x000004C5
Total number of fault codes: 1
P1113 - Port Deactivation Position Sensor Circuit Low Voltage
(06) - Present
but when i check it with the code look up from http://www.astraownersclub.com/vb/s...List-of-Fault-codes-and-how-to-check-for-them it comes up with IAT Open/Close
i took it to the garage and they have no idea.
i brought the iat sensor just in case i put new airflow meter on.
i saw that if it is a twinport,then it is the inlet manifold. but i checked and i been told mine is not a twinport and it does not say it on the bootlid.
i even did the peddle test and came up with 111306,
i am so confused can anyone help.
many thanks:)
Just digging up an old thread here, did you get this sorted or does anyone know much about this code as my 2006 1.6 has this code when I do the pedal test.
Thanks.
Well I got it sorted. I bought Op-Com and checked the voltage for the deactivation sensor and it was at 0.1V so I removed the top screw for the vac pump, slackened the bottom then using Op-com a moved the pump towards the air filter until it read 0.5v, I then tightened the bottom screw and left the top one out as it won't fit back. Quick reset of the codes and away I went. No more lights. Took about 5 minutes!
I'll be doing the timing belt tomorrow so maybe ill look at securing it a bit more.
But what a difference in performance though. Like a completely different car!
