07 Astravan Sportive Auto 1.9 Diesel - Random Intermittent Cutting Out Problem
Starting from cold it fires the first time every time; the engine runs sweetly and has always been fully and properly serviced. In the past couple of months, the engine randomly and intermittently cuts out when driving and idling which only seems to occur once the engine has reached normal operating temperature and generally at speeds around 0-40mph. I have had 4 diagnostic checks (snap-on diagnostic reader) done and no faults are being displayed.at all. Around 2500 miles ago the turbo was changed and all was fine up until approx 500 miles ago, I've since renewed the EGR valve but still this frustrating fault persists! When it's running there is no loss of power and the turbo appears to be working fine; it ALWAYS restarts after a cut-out and may run 1 mile or 50 miles before it does it again. There is no engine management light illuminated either just before it cuts out or after a restart. Any suggestions to rectify with faithfully received and readily applied?
