Status
Not open for further replies.
Astra H FAULT CODES
59K views 5 replies 1 participant last post by  Scrooge
#1 · (Edited by Moderator)
**** IMPORTANT READ THIS PART FIRST!! *****
REMOVE LAST 2 DIGITS FROM THE CODE READ FROM THE MILEOMETER DISPLAY, AND YOU WILL FIND YOUR CODE!
Example:
If you read ECN04005a from the mileometer display during the pedal test, remove the 5a from the end to give you code 0400.
Look down the list under your engine type, and find P0400 = EGR Valve Insufficient Flow Detected
There can be several codes listed under one fault code number. You cannot determine which code you have stored without using a fault code reader
Vehicle codes
B0132 Battery Voltage Low C-118
B0132 Battery Voltage High C-118
B0158 Outside Temperature Sensor Circuit Low Voltage DIS (Info Display) C-016
B0158 Outside Temperature Sensor Circuit Open or High Voltage DIS (Info Display) C-016
B0283 Rear Window Heating Circuit Malfunction Heating, Ventilation and Air Conditioning System B-016
B1000 Replace Electronic Control Unit (ECU) - Hardware Failure C-002
B1000 Replace Electronic Control Unit (ECU) - EEPROM Failure C-002
B1000 ECU Malfunction C-002
B1000 Replace Electronic Control Unit (ECU) C-002
B1001 Programming Error Hard- and Software B-003
B1001 Left Hand Drive/Right Hand Drive Configuration Error C-002
B1001 Electronic Control Unit (ECU) Not Programmed Hard- and Software B-003
B1001 Airbag Control Unit Not Locked Hard- and Software B-003
B1001 Electronic Control Unit (ECU) Not Calibrated Hard- and Software B-003
B1001 Variant Configuration Not Programmed Hard- and Software B-004
B1001 Variant Coding Not Programmed Hard- and Software B-004
B1001 Vehicle Identification Number Not Programmed Hard- and Software B-005
B1001 Electronic Control Unit Not Programmed (ECU) Hard- and Software B-003
B1001 Program Electronic Control Unit (ECU) Hard- and Software B-003
B1006 Replace Electronic Control Unit (ECU) C-002
B1009 Program Electronic Control Unit (ECU) Hard- and Software B-003
B1016 Vehicle Identification Number Not Programmed Hard- and Software B-005
B1019 Electronic Control Unit (ECU) In Delivery State Hard- and Software B-003
B1325 System Voltage High Voltage B-003
B1325 System Voltage Low Voltage B-003
B1375 Switched System Voltage (Ignition ON) Not Plausible with CAN Signal B-005
B1385 Terminal 15A Circuit Malfunction B-004
B1390 Comfort Closing Circuit Low Voltage Power Window Lifter C-009
B1395 Engine Running Signal Low Voltage EHPS (Electrohydraulic Power Steering) C-002
B1420 Power Supply Circuit Low Voltage C-119
B1420 Power Supply Circuit High Voltage C-119
B1421 Power Supply Signal Range/Performance C-119
B1428 Starter Relay Circuit Malfunction C-122
B1441 Switched System Voltage (Ignition ON) Circuit High Voltage C-120
B1441 Switched System Voltage (Ignition ON) Circuit Low Voltage C-120
B1451 Accessory Relay Circuit High Voltage C-109
B1451 Accessory Relay Circuit High Voltage or Open Circuit C-109
B1453 Switched System Voltage (Ignition ON) Circuit Low Voltage C-120
B1453 Switched System Voltage (Ignition ON) Circuit High Voltage C-120
B2961 Switch Position Ignition Key Circuit Malfunction C-002
B3601 Key Capture Relay Circuit Malfunction AF 17-4 Electronic 4-Speed Automatic Transmission C-005
B3644 Steering Wheel Remote Control Channel Up Switch Stuck EHU (Entertainment Head Unit) C-012
B3644 Steering Wheel Remote Control Channel Up Switch Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
B3645 Steering Wheel Channel Down Switch Stuck EHU (Entertainment Head Unit) C-012
B3645 Steering Wheel Remote Control Channel Down Switch Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
B3646 Steering Wheel Scroll Wheel Right Stuck EHU (Entertainment Head Unit) C-012
B3646 Steering Wheel Scroll Wheel Right Circuit Open EHU (Entertainment Head Unit) C-012
B3646 Steering Wheel Scroll Wheel Right Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
B3647 Steering Wheel Remote Control Voice Control Switch Stuck EHU (Entertainment Head Unit) C-012
B3647 Steering Wheel Remote Control Voice Control Switch Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
B3648 Steering Wheel Remote Control Phone Switch Stuck EHU (Entertainment Head Unit) C-012
B3648 Steering Wheel Remote Control Phone Switch Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
B3649 Steering Wheel Scroll Wheel Left Circuit Open EHU (Entertainment Head Unit) C-012
B3649 Steering Wheel Scroll Wheel Left Stuck EHU (Entertainment Head Unit) C-012
B3649 Steering Wheel Scroll Wheel Left Circuit Resistance Range/Performance EHU (Entertainment Head Unit) C-012
C0252 ECU in Delivery State or Defective ECU Hard- and Software B-003
C0550 Electronic Control Unit Not Programmed (ECU) Hard- and Software B-003
C0550 Wrong Variant Configuration Programmed or Defective ECU Hard- and Software B-003
C0550 Replace Electronic Control Unit (ECU) C-002
C0551 Variant Configuration Not Programmed Hard- and Software B-004
C0551 Program Electronic Control Unit (ECU) Hard- and Software B-003
C0551 Wrong Variant Configuration Programmed Hard- and Software B-004
C0551 Variant Coding Not Programmed Hard- and Software B-004
C0551 Vehicle Identification Number Not Programmed Hard- and Software B-005
C0569 System Configuration Wrong Hard- and Software B-003
C0800 System Voltage Low Voltage B-003
C0800 System Voltage High Voltage B-003
C0920 Electronic Control Unit (ECU) Not Programmed Hard- and Software B-003
C1523 System Voltage High Voltage C-108
C1523 System Voltage Low Voltage C-108
C1550 Replace Electronic Control Unit (ECU) C-002
P0110 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P0115 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P0505 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P0560 System Voltage High Voltage C-112
P0560 System Voltage Low Voltage C-112
P0560 System Voltage High Input C-113
P0560 System Voltage Out Of Range C-113
P0560 Battery Voltage Range/Performance C-112
P0560 System Voltage Too High C-113
P0560 System Voltage Malfunction C-113
P0560 System Voltage Low Input C-113
P0601 Replace Electronic Control Unit (ECU) C-002
P0601 Reprogram or Replace Electronic Control Unit (ECU) Hard- and Software B-003
P0602 Control Unit Not Programmed Hard- and Software B-003
P0602 Variant Configuration Not Programmed Hard- and Software B-004
P0602 Vehicle Identification Number Not Programmed Hard- and Software B-005
P0602 Control Unit Programming Error Hard- and Software B-003
P0602 Tyre circumference not programmed Hard- and Software B-003
P0602 Security Code Not Programmed Hard- and Software B-003
P0602 Program Electronic Control Unit (ECU) Hard- and Software B-003
P0602 Injector Quantity Adjustment Not Programmed Hard- and Software B-015
P0603 ECU EEPROM Error C-002
P0603 Replace Electronic Control Unit (ECU) C-002
P0604 Electronic Control Unit (ECU) Fault - Random Access Memory (RAM) C-002
P0604 Replace Electronic Control Unit (ECU) C-002
P0605 EPROM Failure C-002
P0605 Replace Electronic Control Unit (ECU) C-002
P0606 Replace Electronic Control Unit (ECU) C-002
P0606 Capacitor Voltage 1 Low Voltage C-004
P0606 Capacitor Voltage 1 High Voltage C-004
P0606 Electronic Control Unit (ECU) - Malfunction C-002
P0606 System Voltage High Input C-113
P0606 Control Unit Re-Initialisation C-004
P0610 Control Unit Programming Error Hard- and Software B-003
P0615 Starter Relay Circuit Malfunction C-122
P0615 Starter Relay Circuit High Voltage C-122
P0615 Starter Relay Circuit Low Voltage C-122
P0615 Starter Relay Circuit open C-122
P0615 Starter Relay Powerstage High Temperature C-122
P062F Control Unit Programming Error Hard- and Software B-003
P062F Small Injection Quantity Learning Failed Hard- and Software B-003
P062F Electronic Control Unit (ECU) - Malfunction C-002
P0631 Vehicle Identification Number Not Programmed Hard- and Software B-005
P0650 CAN-Bus No Communication with CIM (Steering Column Module) C-003
P0705 Replace Electronic Control Unit (ECU) C-002
P0725 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P0815 Steering Wheel Remote Control Shift Up Switch Stuck C-002
P0815 Steering Wheel Remote Control Shift Up Switch Circuit Resistance Range/Performance MTA (Easytronic) (F13-5MTA/F17-5MTA) B-030
P0816 Steering Wheel Remote Control Shift Down Switch Stuck C-002
P0816 Steering Wheel Remote Control Shift Down Switch Circuit Resistance Range/Performance MTA (Easytronic) (F13-5MTA/F17-5MTA) B-030
P1120 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P1560 Switched System Voltage (Ignition ON) Signal Malfunction (CAN) C-112
P1561 System Voltage High Voltage C-112
P1561 System Voltage Low Voltage C-112
P1562 Replace Electronic Control Unit (ECU) C-002
P1564 System Voltage Low Voltage C-112
P1600 Reprogram or Replace Electronic Control Unit (ECU) Hard- and Software B-003
P1600 Replace Electronic Control Unit (ECU) C-002
P1602 Reprogram or Replace Electronic Control Unit (ECU) Hard- and Software B-003
P1602 Control Unit Programming Error Hard- and Software B-003
P1602 Fuel Pump Fuel Quantity Adjustment Not Learned Hard- and Software B-003
P1602 Small Injection Quantity not Learned Hard- and Software B-003
P1602 Variant Configuration Not Programmed Hard- and Software B-003
P1602 Top Speed not Programmed Hard- and Software B-003
P1603 Replace Electronic Control Unit (ECU) C-002
P1604 Replace Electronic Control Unit (ECU) C-004
P1606 Replace Electronic Control Unit (ECU) C-002
P1622 Replace Electronic Control Unit (ECU) C-002
P165A Replace Electronic Control Unit (ECU) C-002
P1703 Brake Light Switch Signal CAN-Bus Malfunction C-003
P1711 Front Left Wheel Speed Sensor Signal Malfunction (CAN) C-003
P1712 Front Right Wheel Speed Sensor Signal Malfunction (CAN) C-003
P1739 Replace Electronic Control Unit (ECU) C-002
P1740 Replace Electronic Control Unit (ECU) C-002
P1895 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P1896 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
P2638 Replace Electronic Control Unit (ECU) C-002
U0001 CAN-Bus Maximum Configuration List not Programmed Hard- and Software B-003
U0009 CAN-Bus Node no Communication C-005
U0101 CAN-Bus no Communication with Transmission Control Module C-003
U0121 CAN-Bus no Communication with ABS/TC C-003
U0140 CAN-Bus No Communication with CIM (Steering Column Module) C-003
U2100 CAN-Bus (Mid Speed) Communication Malfunction C-005
U2100 No Communication with CAN-Bus (Mid Speed) C-005
U2100 CAN-Bus Malfunction C-005
U2100 CAN-Bus Communication Malfunction C-005
U2100 CAN Bus Communication Error C-005
U2100 No Communication with CAN-Bus (High Speed) C-005
U2100 No Communication with CAN-Bus (Low Speed) C-005
U2101 CAN-Bus Maximum Configuration List not Programmed Hard- and Software B-003
U2101 CAN-Bus (Mid Speed) Maximum Configuration List Not Programmed Hard- and Software B-003
U2101 CAN-Bus (High Speed) Maximum Configuration List Not Programmed Hard- and Software B-003
U2101 CAN-Bus (Low Speed) Maximum Configuration List Not Programmed Hard- and Software B-003
U2102 CAN-Bus (Mid Speed) Maximum Configuration List not Complete Hard- and Software B-003
U2103 CAN-Bus Reset Counter Overrun C-005
U2103 No Communication with CAN-Bus (High Speed) C-005
U2103 CAN-Bus Circuit Malfunction C-005
U2103 CAN-Bus Node no Communication C-005
U2103 No Communication with CAN-Bus (Low Speed) C-005
U2104 CAN-Bus (High Speed) Reset Counter Overrun C-005
U2104 CAN-Bus reset counter overrun C-005
U2104 CAN-Bus Reset Counter Overrun C-005
U2104 CAN-Bus (Mid Speed) Reset Counter Overrun C-005
U2105 CAN-Bus no Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
U2105 CAN-Bus No Communication with ECM (Engine Control Module) Vehicle Related Diagnostic Procedure B-019
U2106 CAN-Bus no Communication with Transmission Control Module C-003
U2106 CAN-Bus No Communication with TCM (Transmission Control Module) C-003
U2107 CAN-Bus No Communication with IPC (Instrument) C-003
U2108 CAN-Bus no Communication with ABS/TC C-003
U2108 CAN-Bus No Communication with ABS (Anti-Lock Brake System) C-003
U2108 Reprogram or Replace Electronic Control Unit (ECU) Hard- and Software B-003
U2110 CAN-Bus no Communication with ABS/ESP C-003
U2111 CAN-Bus No Communication with EPS (Electrical Power Steering) C-003
U2112 CAN-Bus No Communication with SADS (Semi Active Damping System) C-003
U2112 CAN-Bus No Communication with CDC(Continuous Damping Control) C-003
U2113 CAN-Bus No Communication with SDM (Sensing & Diagnostic Module, Airbag) C-003
U2113 CAN-Bus No Communication with SDM (Airbag) C-003
U2116 CAN-Bus No Communication with IPC (Instrument) C-003
U2116 CAN-BUS No Communication with IPC (Instrument) C-003
U2117 CAN-Bus no Communication with Info-Display C-121
U2117 CAN-Bus No Communication with DIS (Display) C-121
U2120 CAN-Bus No Communication with AHL (Headlamp Levelling Device) C-003
U2127 CAN-Bus No Communication with ECC (Electronic Climate Control) C-003
U2139 CAN-Bus No Communication with CIM (Steering Column Module) C-003
U2140 CAN-Bus No Communication with CIM (Steering Column Module) C-003
U2140 CAN-Bus No Communication with UEC (Underhood Electrical Centre) C-003
U2141 CAN-Bus No Communication with REC (Rear Electrical Centre) C-003
U2143 CAN-Bus No Communication with SAS (Steering Angle Sensor) C-003
U2144 CAN-BUS No Communication with ACC (Adaptive Cruise Control) C-003
U2145 CAN-Bus No Communication with PAS (Park Pilot) C-003
U2146 CAN-Bus No Communication with SLM (Shift Lever Module) C-003
U2147 CAN-Bus No Communication with AHS (Add On Heater) C-003
U2149 CAN-Bus No Communication with TPMS (Tyre Pressure Monitoring System) C-003
U2173 CAN-Bus No Communication with PEPS(Open&Start) C-003
U2174 CAN-Bus No Communication with EHS (Electrical Heater System) C-003
U2174 CAN-Bus No Communication with AHS (Add On Heater) C-003
U2181 CAN-Bus No Communication with Electrohydraulic Hardtop C-003
U2201 CAN-Bus No Communication with EHU (Entertainment Head Unit) C-003
U2202 CAN-Bus No Communication with CDC (CD-Changer) C-003
U2206 CAN-Bus No Communication with DIS (Display) C-003
U2207 CAN-Bus No Communication with UHP(Mobile Phone Portal) C-003
U2208 CAN-Bus No Communication with ECC (Electronic Climate Control) C-003
U2213 CAN-Bus No Communication with DAB (Digital Audio Broadcast) C-003
U2215 Replace Electronic Control
Engine Codes Z19DT Z19DTJ Z19DTH
P0001 Fuel Metering Solenoid Valve Circuit High Voltage C-021
P0001 Fuel Metering Solenoid Valve Circuit Low Voltage C-021
P0001 Rail Pressure Low Pressure B-029
P0001 Rail Pressure High Pressure B-029
P0001 Fuel Metering Solenoid Valve Circuit Open C-021
P0001 Fuel Metering Solenoid Valve Powerstage High Temperature C-021
P0002 Rail Pressure Control Range/Performance B-029
P0002 Fuel Metering Solenoid Valve Circuit Range/Performance B-029
P0003 Fuel Metering Solenoid Valve Circuit Low Voltage C-021
P0004 Fuel Metering Solenoid Valve Circuit High Voltage C-021
P0016 Crankshaft/Camshaft Correlation B-018
P0030 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-029
P0030 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-025
P0030 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-025
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-030
P0030 O2 Sensor Heater Powerstage High Temperature (Bank 1 Sensor 1) C-029
P0070 Ambient Air Temperature Sensor Malfunction B-016
P0070 Ambient Air Temperature Low Input B-016
P0070 Ambient Air Temperature High Input B-016
P0087 Rail Pressure Low Pressure B-029
P0088 Rail Pressure High Pressure B-029
P0090 Rail Pressure Control Solenoid Valve Circuit Range/Performance (Negative Deviation) B-043
P0090 Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation) B-043
P0100 Mass Or Volume Air Flow Circuit High Input B-032
P0100 Mass Or Volume Air Flow Circuit Low Input B-028
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance B-037
P0100 Mass Or Volume Air Flow Circuit Malfunction C-012
P0100 Intake Air Temperature Sensor Circuit High Input C-013
P0100 Intake Air Temperature Sensor Circuit Low Input C-013
P0100 Intake Air Temperature Sensor Circuit Malfunction C-013
P0105 Boost Pressure Sensor Circuit High Input C-011
P0105 Boost Pressure Sensor Circuit Low Input C-011
P0105 Boost Pressure Sensor Circuit, Signal not plausible with Mass Air Flow Sensor C-011
P0105 Barometric Pressure not plausible with Boost Pressure B-047
P0110 Intake Air Temperature Sensor Circuit High Input C-014
P0110 Intake Air Temperature Sensor Circuit Low Input C-014
P0110 Intake Air Temperature Voltage High C-014
P0110 Intake Air Temperature Voltage Low C-014
P0110 Charge Air Temperature Sensor High Input C-014
P0110 Charge Air Temperature Sensor Low Input C-014
P0115 Engine Coolant Temperature Circuit High Input Engine Cooling C-001
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling C-001
P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling C-001
P0115 Engine Coolant Temperature Incorrect Signal Engine Cooling C-001
P0115 Engine Coolant Temperature not Plausible with Engine Oil Temperature Engine Cooling C-001
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) B-030
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) B-030
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-028
P0130 O2 Sensor - System Too Rich (Bank 1) B-030
P0130 O2 Sensor - System Too Lean (Bank 1) B-030
P0130 O2 Sensor Circuit (Bank 1 Sensor 1) C-001
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-030
P0168 Fuel Reduction caused by High Fuel Temperature B-049
P0180 Fuel Temperature Sensor Circuit High Input C-015
P0180 Fuel Temperature Sensor Circuit Low Input C-015
P0190 Rail Pressure Sensor High Voltage C-020
P0190 Rail Pressure Sensor Low Voltage C-020
P0190 Rail Pressure Range/Performance C-020
P0201 Cylinder 1 Injector Circuit Low B-034
P0201 Cylinder 1 Injector Circuit Open B-034
P0201 Cylinder 1 Injector Short Circuit B-034
P0201 Cylinder 1 - Injector Circuit Malfunction B-034
P0202 Cylinder 2 Injector Circuit Low B-034
P0202 Cylinder 2 Injector Circuit Open B-034
P0202 Cylinder 2 Injector Short Circuit B-034
P0202 Cylinder 2 - Injector Circuit Malfunction B-034
P0203 Cylinder 3 Injector Circuit Low B-034
P0203 Cylinder 3 Injector Short Circuit B-034
P0203 Cylinder 3 Injector Circuit Open B-034
P0203 Cylinder 3 - Injector Circuit Malfunction B-034
P0204 Cylinder 4 Injector Circuit Low B-034
P0204 Cylinder 4 Injector Short Circuit B-034
P0204 Cylinder 4 Injector Circuit Open B-034
P0204 Cylinder 4 - Injector Circuit Malfunction B-034
P0217 Engine Overtemperature Condition Engine Cooling B-007
P0219 Engine Overspeed Condition C-009
P0230 Fuel Pump Primary Circuit High C-004
P0230 Fuel Pump Primary Circuit Low B-027
P0230 Fuel Pump Primary Circuit Open B-027
P0230 Fuel Pump Circuit High Temperature C-004
P0234 Boost Pressure Control Circuit Negative Deviation B-045
P0234 Boost Pressure Control Circuit Positive Deviation B-045
P0243 Boost Pressure Valve High Voltage C-016
P0243 Boost Pressure Valve Low Voltage B-021
P0243 Boost Pressure Valve Circuit Open B-021
P0243 Boost Pressure Valve Powerstage High Temperature C-016
P0262 Cylinder 1 Injector Circuit High C-023
P0265 Cylinder 2 Injector Circuit High C-024
P0268 Cylinder 3 Injector Circuit High C-025
P0271 Cylinder 4 Injector Circuit High C-026
P0335 Crankshaft Position Sensor "A" Circuit Range/Performance B-048
P0335 Crankshaft Position Sensor "A" Circuit Open C-009
P0340 Camshaft Position Sensor Circuit Open C-010
P0340 Camshaft Position Sensor Circuit Range/Performance B-018
P0380 Glow Device Circuit High Voltage C-033
P0380 Glow Device Circuit Low Voltage B-020
P0380 Glow Device Circuit Open Circuit C-033
P0380 Glow Device General Error C-033
P0380 Glow Device Powerstage High Temperature C-033
P0400 Exhaust Gas Recirculation Circuit High Voltage C-017
P0400 Exhaust Gas Recirculation Circuit Low Voltage B-023
P0400 Exhaust Gas Recirculation Circuit Open B-023
P0400 Exhaust Gas Recirculation Valve Powerstage High Temperature C-017
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-044
P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-036
P0425 Exhaust Gas Temperature Sensor High Voltage (Bank 1 Sensor 1) C-030
P0425 Exhaust Gas Temperature Sensor Low Voltage (Bank 1 Sensor 1) C-030
P0425 Exhaust Gas Temperature Sensor 1 High Temperature C-030
P0425 Exhaust Gas Temperature Sensor 1 Low Temperature C-030
P0425 Exhaust Gas Temperature Sensor 1 Temperature not Plausible C-030
P042A Exhaust Gas Temperature Sensor 2 High Voltage C-031
P042A Exhaust Gas Temperature Sensor 2 Low Voltage C-031
P042A Exhaust Gas Temperature Sensor 2 High Temperature C-031
P042A Exhaust Gas Temperature Sensor 2 Low Temperature C-031
P042A Exhaust Gas Temperature Sensor 1 + 2 not Plausible C-031
P0460 Fuel Level Sensor Circuit Range/Performance IPC (Instrument) B-013
P0500 Vehicle Speed Signal Range/Performance B-051
P0500 Vehicle Speed Sensor Circuit Incorrect Signal B-051
P0500 Vehicle Speed Signal Malfunction (CAN) B-051
P0500 Vehicle Speed Signal not plausible with Engine Speed and Injection Mass B-050
P0520 Engine Oil Pressure Sensor/Switch Circuit Open IPC (Instrument) C-018
P0530 A/C Pressure Sensor Circuit Low Input Heating, Ventilation and Air Conditioning System C-009
P0530 A/C Pressure Sensor Circuit High Input Heating, Ventilation and Air Conditioning System C-009
P0530 A/C Pressure Sensor Malfunction Heating, Ventilation and Air Conditioning System C-009
P0571 Brake Light Switch Circuit Incorrect Signal Exterior Lighting/Turn Indicator System B-014
P0571 Brake Light Switch Circuit High Input Exterior Lighting/Turn Indicator System B-014
P0571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0620 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0622 Generator Field "F" Control Circuit Malfunction IPC (Instrument) C-021
P0638 Electronic Throttle Control High Voltage C-019
P0638 Electronic Throttle Control Low Voltage B-022
P0638 Electronic Throttle Control Circuit open B-022
P0638 Electronic Throttle Control Powerstage High Temperature C-019
P0641 5V Reference Circuit 1 High Voltage C-005
P0641 5V Reference Circuit 1 Low Voltage C-005
P0645 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Circuit Open Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Powerstage High Temperature Heating, Ventilation and Air Conditioning System B-017
P0651 5V Reference Circuit 2 High Voltage C-006
P0651 5V Reference Circuit 2 Low Voltage C-006
P0660 Swirl Level Control Solenoid Valve High Voltage C-018
P0660 Swirl Level Control Solenoid Valve Low Voltage B-024
P0660 Swirl Level Control Solenoid Valve Circuit Open B-024
P0660 Swirl Level Control Solenoid Powerstage High Temperature C-018
P0697 5V Reference Circuit 3 High Voltage C-007
P0697 5V Reference Circuit 3 Low Voltage C-007
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P0703 Brake Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-010
P0960 Rail Pressure Control Solenoid Valve Circuit High Voltage C-022
P0960 Rail Pressure Control Solenoid Valve Circuit Low Voltage C-022
P0960 Rail Pressure Control Solenoid Valve Circuit Open C-022
P0960 Rail Pressure Control Solenoid Valve Powerstage High Temperature C-022
P0961 Rail Pressure Control Solenoid Valve Range/Performance C-022
P1105 Barometric Pressure Sensor Circuit High Input C-002
P1105 Barometric Pressure Sensor Circuit Low Input C-002
P1105 Barometric Pressure not plausible with Boost Pressure B-047
P1109 Swirl Actuator Malfunction B-033
P1109 Swirl Actuator Supply Voltage Range/Performance B-033
P1109 Swirl Actuator Feedback Circuit High Voltage B-033
P1109 Swirl Actuator Feedback Circuit Low Voltage B-033
P1109 Swirl Actuator Feedback Signal Malfunction B-033
P1109 Swirl Actuator Feedback Signal Range/Performance B-033
P1109 Swirl Actuator Feedback Powerstage High Temperature B-033
P1110 Swirl Actuator High Voltage C-018
P1110 Swirl Actuator Low Voltage B-024
P1110 Swirl Actuator Circuit Open B-024
P1110 Swirl Actuator Powerstage High Temperature C-018
P1120 Accelerator Pedal Position Sensor 1 High Input C-008
P1120 Accelerator Pedal Position Sensor 1 Low Input C-008
P1120 Accelerator Pedal Position Sensor 1 Range/Performance C-008
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-008
P1122 Accelerator Pedal Position Sensor 2 High Input C-008
P1122 Accelerator Pedal Position Sensor 2 Low Input C-008
P1122 Accelerator Pedal Position Sensor 2 Range/Performance C-008
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-008
P1125 Throttle Actuator Supply Voltage Low Voltage C-019
P1125 Throttle Actuator Feedback Circuit Malfunction C-019
P1125 Throttle Actuator Malfunction C-019
P1125 Throttle Actuator Feedback Signal Range/Performance C-019
P1125 Throttle Actuator Feedback Powerstage High Temperature C-019
P1180 Fuel Filter Heater High Voltage C-035
P1180 Fuel Filter Heater Low Voltage B-019
P1180 Fuel Filter Heater Circuit Open C-035
P1180 Fuel Filter Heater Powerstage High Temperature C-035
P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Open Engine Cooling C-003
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling C-003
P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling C-003
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling C-003
P1483 Fan Control 3 Circuit High Voltage Engine Cooling B-004
P1483 Fan Control 3 Circuit Low Voltage Engine Cooling B-004
P1483 Fan Control 3 Circuit Open Engine Cooling C-003
P1483 Fan Control 3 Powerstage High Temperature Engine Cooling C-003
P1530 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Powerstage High Temperature Heating, Ventilation and Air Conditioning System B-017
P1530 A/C Relay Circuit Open Heating, Ventilation and Air Conditioning System B-017
P1560 System Voltage Malfunction Power Supply and Communication C-113
P1571 Brake Switch Circuit High Voltage Exterior Lighting/Turn Indicator System B-014
P1571 Brake Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P1610 Immobiliser Function not Programmed Immobiliser B-015
P1610 Immobiliser Malfunction Immobiliser B-009
P1611 Wrong Security Code Entered Immobiliser B-015
P1613 Immobiliser No Or Wrong Signal Immobiliser B-008
P1614 Immobiliser Wrong Signal Received Immobiliser B-008
P1614 Wrong Transponder Key Immobiliser B-006
P1615 ECM (Engine Control Module) Identification Failed Immobiliser B-006
P1616 CIM (Steering Column Module) Wrong Environment Identifier Immobiliser B-006
P1625 Main Relay opens too early B-048
P1625 Main Relay opens too late C-003
P1700 Service Vehicle Soon Request from Transmission Control Module AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P1810 Fuel-Injection Quantity Malfunction B-029
P1811 Torque Signal Malfunction (CAN) ABS/TC/ESP (Vehicle Dynamic System) B-018
P1813 Invalid Signal from TCM (Transmission Control Module) AF 40-6 Electronic 6-Speed Automatic Transmission B-029
P1815 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-009
P1895 Limp home - Limited Performance B-049
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 1) not plausible with Intake Air Temperature C-030
P1900 Exhaust Gas Temperature Sensor (Bank 1 Sensor 2) not plausible with Intake Air Temperature C-031
P1900 Particulate Filter Regeneration Cycle Interrupted Several Times B-031
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 1) C-030
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 1) C-030
P1900 Exhaust Gas Temperature Sensor High Temperature (Bank 1 Sensor 2) C-031
P1900 Exhaust Gas Temperature Sensor Low Temperature (Bank 1 Sensor 2) C-031
P1901 Particulate Filter Pressure Sensor High Voltage C-032
P1901 Particulate Filter Pressure Sensor Low Voltage C-032
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction B-031
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Low Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Pressure not Plausible with Barometric Pressure B-031
P1901 Particulate Filter Pressure Sensor High Pressure C-032
P1901 Particulate Filter Pressure Sensor Low Pressure B-031
P1902 Exhaust Gas Temperature Sensor High Voltage (Bank 1 Sensor 2) C-031
P1902 Exhaust Gas Temperature Sensor Low Voltage (Bank 1 Sensor 2) C-031
P2002 Particulate Filter Regeneration Not Completed B-031
P2075 Swirl Level Sensor Circuit Voltage Range/Performance B-024
P2075 Swirl Level Sensor Circuit Frequency Range/Performance C-018
P2075 Swirl Level Sensor Malfunction C-018
P2075 Swirl Level Sensor Circuit Open or High Voltage C-018
P2075 Swirl Level Sensor Circuit Low Voltage B-024
P2075 Swirl Level Sensor Circuit Range/Performance C-018
P2075 Swirl Level Control Solenoid Valve Stuck B-033
P2075 Swirl Level Control Solenoid Valve Frequency Range/Performance C-018
P2075 Swirl Level Control Solenoid Powerstage High Temperature C-018
P2146 Cylinder 1 + 4 Injector Circuit Voltage Range/Performance C-027
P2146 Cylinder 1 + 4 Injector Circuit Low Voltage C-027
P2146 Cylinder 1 + 4 Injector Circuit High Voltage C-027
P2146 Cylinder 1 + 4 Injector Circuit Open C-027
P2146 Injector 1 or 4 Circuit Open C-027
P2147 Injector 1 or 4 Short Circuit C-027
P2147 Injector 1 or 4 Malfunction C-027
P2149 Cylinder 2 + 3 Injector Circuit Voltage Range/Performance C-027
P2149 Cylinder 2 + 3 Injector Circuit Low Voltage C-027
P2149 Cylinder 2 + 3 Injector Circuit High Voltage C-027
P2149 Cylinder 2 + 3 Injector Circuit Open C-027
P2149 Injector 2 or 3 Circuit Open C-027
P2150 Injector 2 or 3 Short Circuit C-027
P2150 Injector 2 or 3 Malfunction C-027
P2226 Barometric Pressure Sensor Circuit High Input C-002
P2226 Barometric Pressure Sensor Circuit Low Input C-002
P2226 Barometric Pressure Sensor Circuit Malfunction C-002
P2226 Barometric Pressure Sensor Range/Performance C-002
P2237 O2 Sensor Pump Current Circuit High Voltage (Bank 1 Sensor 1) C-028
P2237 O2 Sensor Pump Current Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2237 O2 Sensor Pump Current Circuit Open (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit High Voltage (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Open (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit High Voltage (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit Low Voltage (Bank 1 Sensor 1) C-028
P2251 O2 Sensor Ground Circuit Open (Bank 1 Sensor 1) C-028
P2264 "Water In Fuel" Sensor Circuit Malfunction B-017
P2279 Intake Air System Leak Detected B-035
P242F Particulate Filter Pressure Sensor Range/Performance B-031
P2452 Particulate Filter Pressure Sensor High Voltage C-032
P2452 Particulate Filter Pressure Sensor Low Voltage C-032
P2452 Particulate Filter Pressure Sensor Pressure not Plausible with Barometric Pressure B-031
P2452 Particulate Filter Pressure Sensor Hose Line Malfunction B-031
U2139 Invalid Signal from CIM (Steering Column Module) C-001
Z17DTL Z17 DTH
P0001 Fuel Metering Solenoid Valve Circuit Open C-017
P0001 Fuel Metering Solenoid Valve Powerstage High Temperature C-017
P0002 Fuel Metering Solenoid Valve Circuit Range/Performance B-027
P0003 Fuel Metering Solenoid Valve Circuit Low Voltage C-017
P0004 Fuel Metering Solenoid Valve Circuit High Voltage C-017
P0016 Crankshaft/Camshaft Correlation B-032
P0070 Ambient Air Temperature Sensor Malfunction B-017
P0087 Rail Pressure Low Pressure B-027
P0088 Rail Pressure High Pressure B-027
P0100 Mass Or Volume Air Flow Circuit Malfunction C-011
P0100 Mass Or Volume Air Flow Circuit High Input B-020
P0100 Mass Or Volume Air Flow Circuit Low Input B-020
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance C-011
P0100 Intake Air Temperature Sensor Circuit Low Input C-010
P0100 Intake Air Temperature Sensor Circuit High Input C-010
P0100 Intake Air Temperature Sensor Circuit Malfunction C-010
P0105 Boost Pressure Sensor Circuit Low Input C-012
P0105 Boost Pressure Sensor Circuit High Input C-012
P0105 Barometric Pressure not plausible with Boost Pressure B-025
P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling B-010
P0115 Engine Coolant Temperature Circuit High Input Engine Cooling B-010
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling B-010
P0190 Rail Pressure Sensor Low Voltage C-016
P0190 Rail Pressure Sensor High Voltage C-016
P0201 Cylinder 1 Injector Circuit Open C-019
P0202 Cylinder 2 Injector Circuit Open C-020
P0203 Cylinder 3 Injector Circuit Open C-021
P0204 Cylinder 4 Injector Circuit Open C-022
P0219 Engine Overspeed Condition C-007
P0234 Boost Pressure Control Circuit Negative Deviation B-021
P0234 Boost Pressure Control Circuit Positive Deviation B-021
P0243 Boost Pressure Valve High Voltage C-013
P0243 Boost Pressure Valve Low Voltage C-013
P0243 Boost Pressure Valve Circuit Open C-013
P0243 Boost Pressure Valve Powerstage High Temperature C-013
P0262 Cylinder 1 Injector Circuit High C-019
P0265 Cylinder 2 Injector Circuit High C-020
P0268 Cylinder 3 Injector Circuit High C-021
P0271 Cylinder 4 Injector Circuit High C-022
P0335 Crankshaft Position Sensor "A" Circuit Range/Performance C-007
P0335 Crankshaft Position Sensor "A" Circuit Open C-007
P0340 Camshaft Position Sensor Circuit Range/Performance C-008
P0340 Camshaft Position Sensor Circuit Open C-008
P0380 Glow Device Circuit High Voltage B-035
P0380 Glow Device Circuit Low Voltage B-035
P0380 Glow Device Circuit Open Circuit B-035
P0380 Glow Device General Error B-035
P0380 Glow Device Powerstage High Temperature C-025
P0400 Exhaust Gas Recirculation Circuit High Voltage B-033
P0400 Exhaust Gas Recirculation Circuit Low Voltage B-033
P0400 Exhaust Gas Recirculation Circuit Open B-033
P0400 Exhaust Gas Recirculation Flow Insufficient Detected B-030
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-030
P0400 Exhaust Gas Recirculation Valve Powerstage High Temperature C-023
P0500 Vehicle Speed Signal not plausible with Engine Speed and Injection Mass B-031
P0500 Vehicle Speed Signal Range/Performance ABS/TC/ESP (Vehicle Dynamic System) B-011
P0622 Generator Field "F" Control Circuit Malfunction C-030
P0638 Electronic Throttle Control High Voltage C-014
P0638 Electronic Throttle Control Low Voltage C-014
P0638 Electronic Throttle Control Circuit open C-014
P0638 Electronic Throttle Control Powerstage High Temperature C-014
P0641 5V Reference Circuit 1 Low Voltage C-004
P0641 5V Reference Circuit 1 High Voltage C-004
P0651 5V Reference Circuit 2 Low Voltage C-005
P0651 5V Reference Circuit 2 High Voltage C-005
P0697 5V Reference Circuit 3 Low Voltage C-006
P0697 5V Reference Circuit 3 High Voltage C-006
P1105 Barometric Pressure Sensor Circuit Low Input C-001
P1105 Barometric Pressure Sensor Circuit High Input C-001
P1110 Swirl Actuator High Voltage B-034
P1110 Swirl Actuator Low Voltage B-034
P1110 Swirl Actuator Circuit Open B-034
P1110 Swirl Actuator Powerstage High Temperature C-015
P1120 Accelerator Pedal Position Sensor 1 High Input C-009
P1120 Accelerator Pedal Position Sensor 1 Range/Performance C-009
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-009
P1122 Accelerator Pedal Position Sensor 2 High Input C-009
P1122 Accelerator Pedal Position Sensor 2 Range/Performance C-009
P1122 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-009
P1125 Throttle Actuator Feedback Signal Range/Performance C-014
P1180 Fuel Filter Heater High Voltage C-026
P1180 Fuel Filter Heater Low Voltage B-036
P1180 Fuel Filter Heater Circuit Open B-036
P1180 Fuel Filter Heater Powerstage High Temperature C-026
P1400 Exhaust Gas Recirculation Circuit Low Voltage C-024
P1400 Exhaust Gas Recirculation Circuit High Voltage C-024
P1400 Exhaust Gas Recirculation Circuit Range/Performance C-024
P1400 Exhaust Gas Recirculation Valve Stuck C-024
P1481 Fan Control 1 Circuit Open Engine Cooling B-004
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling B-004
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling B-004
P1483 Fan Control 3 Circuit Open Engine Cooling B-004
P1483 Fan Control 3 Powerstage High Temperature Engine Cooling B-004
P1610 Immobiliser Function not Programmed Immobiliser B-009
P1625 Main Relay opens too early B-016
P1815 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-008
P1895 Limp home - Limited Performance B-013
P2147 Injector 1 or 4 Short Circuit C-018
P2147 Injector 1 or 4 Malfunction C-018
P2150 Injector 2 or 3 Short Circuit C-018
P2150 Injector 2 or 3 Malfunction C-018
P2279 Intake Air System Leak Detected B-019
Z12 XEP Z14XEL Z14XEP
P0070 Ambient Air Temperature Sensor Malfunction B-027
P0100 Mass Or Volume Air Flow Circuit High Input C-007
P0100 Mass Or Volume Air Flow Circuit Low Input C-007
P0110 Intake Air Temperature Sensor Circuit High Input C-008
P0110 Intake Air Temperature Sensor Circuit Low Input C-008
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input C-005
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input C-005
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem C-005
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-022
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-022
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-028
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) B-023
P0130 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-023
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) B-012
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-012
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-031
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) B-012
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-026
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-026
P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-029
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-030
P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-030
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) B-013
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) B-013
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) B-013
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-032
P0170 Fuel Trim Malfunction (Bank 1) B-018
P0201 Cylinder 1 Injector Circuit High B-011
P0201 Cylinder 1 Injector Circuit Low B-011
P0201 Cylinder 1 Injector Circuit Open B-011
P0202 Cylinder 2 Injector Circuit High B-011
P0202 Cylinder 2 Injector Circuit Low B-011
P0202 Cylinder 2 Injector Circuit Open B-011
P0203 Cylinder 3 Injector Circuit High B-011
P0203 Cylinder 3 Injector Circuit Low B-011
P0203 Cylinder 3 Injector Circuit Open B-011
P0204 Cylinder 4 Injector Circuit High B-011
P0204 Cylinder 4 Injector Circuit Low B-011
P0204 Cylinder 4 Injector Circuit Open B-011
P0219 Engine Overspeed Condition C-028
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input C-005
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input C-005
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem C-005
P0230 Fuel Pump Primary Circuit High B-010
P0230 Fuel Pump Primary Circuit Low B-010
P0300 Random/Multiple Cylinder Misfire Detected B-024
P0301 Cylinder 1 Misfire Detected B-024
P0302 Cylinder 2 Misfire Detected B-024
P0303 Cylinder 3 Misfire Detected B-024
P0304 Cylinder 4 Misfire Detected B-024
P0313 Misfire Detected at Low Fuel Level B-024
P0325 Knock Sensor 1 Circuit High Input (Bank 1 Or Single Sensor) B-025
P0325 Knock Sensor 1 Circuit Low Input (Bank 1 Or Single Sensor) B-025
P0335 Crankshaft Sensor Incorrect Signal C-002
P0335 Crankshaft Sensor Circuit Range/Performance C-002
P0340 Camshaft Position Sensor Circuit High Input C-009
P0340 Camshaft Position Sensor Circuit Low Input C-009
P0340 Camshaft Position Sensor Circuit Open C-009
P0340 Camshaft Position Sensor Circuit Range/Performance C-009
P0340 Camshaft Position Sensor Circuit Malfunction C-009
P0403 Exhaust Gas Recirculation Circuit Low Voltage B-015
P0403 Exhaust Gas Recirculation Circuit High Voltage B-015
P0403 Exhaust Gas Recirculation Circuit Malfunction B-015
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-019
P0443 Fuel Tank Ventilation Valve Voltage High B-014
P0443 Fuel Tank Ventilation Valve Voltage Low B-014
P0443 Fuel Tank Ventilation Open Circuit B-014
P0500 Vehicle Speed Signal Range/Performance B-026
P0501 Vehicle Speed Signal Range/Performance B-026
P0520 Engine Oil Pressure Sensor/Switch Circuit Range/Performance IPC (Instrument) C-018
P0607 Knock Control Module; Replace ECU B-025
P0607 Knock Sensor Circuit Malfunction B-025
P1112 Port Deactivation Solenoid Valve Actuation Error C-010
P1112 Port Deactivation Position Sensor Circuit Low Voltage C-010
P1112 Port Deactivation Position Sensor Circuit High Voltage C-010
P1113 Port Deactivation Position Sensor Circuit High Voltage C-010
P1113 Port Deactivation Position Sensor Circuit Low Voltage C-010
P1113 Port Deactivation Solenoid Valve Circuit High Voltage B-016
P1113 Port Deactivation Solenoid Valve Circuit Malfunction B-016
P1113 Port Deactivation Solenoid Valve Circuit Low Voltage B-016
P1120 Accelerator Pedal Position Sensor 1 High Input C-004
P1120 Accelerator Pedal Position Sensor 1 Low Input C-004
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-004
P1122 Accelerator Pedal Position Sensor 2 High Input C-004
P1122 Accelerator Pedal Position Sensor 2 Low Input C-004
P1230 Main Relay Malfunction C-001
P1405 Exhaust Gas Recirculation Valve Feedback Signal Malfunction B-015
P1405 Exhaust Gas Recirculation Circuit High Voltage B-015
P1405 Exhaust Gas Recirculation Circuit Low Voltage B-015
P1405 Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal B-015
P1405 Exhaust Gas Recirculation Valve Stuck B-015
P1500 Electronic Throttle Control Malfunction C-006
P1523 Throttle Actuator Control Return Performance C-006
P1526 Throttle Control Lower Position not Learned C-006
P1565 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-006
P1600 Engine Torque not plausible C-001
P1606 Engine Torque not plausible C-001
P1814 Invalid Signal from ECC (Electronic Climate Control) ECC/SAC (Electronic Climate Control) B-032
Z20LEL Z20LER Z20LEH
P0070 Ambient Air Temperature Sensor Malfunction B-025
P0100 Mass Or Volume Air Flow Circuit Malfunction C-007
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-019
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-019
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-026
P0130 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-021
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) B-021
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-029
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-023
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-023
P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-027
P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-028
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-028
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-030
P0170 Fuel Trim Malfunction (Bank 1) B-016
P0219 Engine Overspeed Condition C-025
P0235 Boost Pressure Sensor Circuit Low Input C-031
P0235 Boost Pressure Sensor Circuit High Input C-031
P0243 Boost Pressure Valve High Voltage C-032
P0243 Boost Pressure Valve Low Voltage C-032
P0243 Boost Pressure Valve Circuit Open C-032
P0300 Random/Multiple Cylinder Misfire Detected B-022
P0301 Cylinder 1 Misfire Detected B-022
P0302 Cylinder 2 Misfire Detected B-022
P0303 Cylinder 3 Misfire Detected B-022
P0304 Cylinder 4 Misfire Detected B-022
P0313 Misfire Detected at Low Fuel Level B-022
P0325 Knock Sensor 1 Circuit High Input (Bank 1 Or Single Sensor) B-023
P0325 Knock Sensor 1 Circuit Low Input (Bank 1 Or Single Sensor) B-023
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-017
P0441 Evaporative Emission Control System Incorrect Purge Flow B-014
P0500 Vehicle Speed Signal Range/Performance B-024
P0501 Vehicle Speed Signal Range/Performance B-024
P0607 Knock Control Module; Replace ECU B-023
P0607 Knock Sensor Circuit Malfunction B-023
P0650 Malfunction Indicator (MI) Circuit Malfunction IPC (Instrument) B-008
P1105 Barometric Pressure Sensor Circuit Low Input C-030
P1105 Barometric Pressure Sensor Circuit High Input C-030
P1106 Boost Pressure Sensor Circuit Range/Performance B-018
P1230 Main Relay Malfunction Power Supply and Communication C-013
P1243 Turbocharger Bypass Solenoid Valve Circuit High Voltage C-033
P1243 Turbocharger Bypass Solenoid Valve Circuit Low Voltage C-033
P1243 Turbocharger Bypass Solenoid Valve Circuit Open C-033
P1243 Turbocharger Bypass Valve Range/Performance C-033
P1490 Additional Coolant Pump Circuit High Voltage B-015
P1490 Additional Coolant Pump Circuit Low Voltage B-015
P1490 Additional Coolant Pump Circuit Open B-015
P1600 Engine Torque not plausible B-031
P1606 Engine Torque not plausible B-031
P1811 Torque Signal Malfunction (CAN) ABS/TC/ESP (Vehicle Dynamic System) C-011
Z16XE1 Z16XEP
P0105 Manifold Absolute Pressure Sensor Circuit High Voltage C-007
P0105 Manifold Absolute Pressure Sensor Circuit Open or Low Voltage C-007
P0115 Engine Coolant Temperature Circuit Intermittent Engine Cooling B-010
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance B-022
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input B-017
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input B-017
P0120 Throttle Position Sensor 1-2 Correlation B-017
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-024
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-024
P0130 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) C-024
P0130 O2 Sensor - Too Few Rich/Lean And Lean/Rich Switches (Bank 1 Sensor 1) C-024
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-024
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) B-031
P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-026
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) B-030
P0171 Fuel Trim System Lean B-019
P0172 Fuel Trim System Rich B-019
P0201 Cylinder 1 Injector Malfunction B-024
P0202 Cylinder 2 Injector Malfunction B-024
P0203 Cylinder 3 Injector Malfunction B-024
P0204 Cylinder 4 Injector Malfunction B-024
P0219 Engine Overspeed Condition C-030
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input B-017
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input B-017
P0230 Fuel Pump Primary Circuit High B-024
P0230 Fuel Pump Primary Circuit Low B-028
P0300 Random/Multiple Cylinder Misfire Detected B-025
P0301 Cylinder 1 Misfire Detected B-025
P0302 Cylinder 2 Misfire Detected B-025
P0303 Cylinder 3 Misfire Detected B-025
P0304 Cylinder 4 Misfire Detected B-025
P0314 Single Cylinder Misfire Detected B-025
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 Or Single Sensor) B-020
P0335 Crankshaft Position Sensor "A" Circuit Range/Performance C-003
P0335 Crankshaft Position Sensor "A" Circuit Malfunction C-003
P0340 Camshaft Position Sensor Circuit Malfunction B-018
P0351 Ignition Coil Cylinder 1 Circuit Malfunction B-023
P0352 Ignition Coil Cylinder 2 Circuit Malfunction B-023
P0353 Ignition Coil Cylinder 3 Circuit Malfunction B-023
P0354 Ignition Coil Cylinder 4 Circuit Malfunction B-023
P0400 Exhaust Gas Recirculation Circuit Range/Performance (Open Valve) B-032
P0400 Exhaust Gas Recirculation Circuit Range/Performance (Closed Valve) B-032
P0400 Exhaust Gas Recirculation Flow Excessive Detected B-032
P0420 Catalyst System Efficiency Below Threshold (Bank 1) C-029
P0443 Fuel Tank Ventilation Valve Voltage High B-029
P0443 Fuel Tank Ventilation Valve Voltage Low B-029
P0501 Vehicle Speed Sensor Malfunction ABS/TC/ESP (Vehicle Dynamic System) B-011
P0607 Knock Sensor Circuit Malfunction B-020
P1112 Port Deactivation Solenoid Valve Circuit High Voltage B-027
P1112 Port Deactivation Solenoid Valve Circuit Open or Low Voltage B-027
P1112 Port Deactivation Solenoid Valve Actuation Error at Low Temperature B-027
P1112 Port Deactivation Solenoid Valve Actuation Error B-027
P1113 Port Deactivation Position Sensor Circuit High Voltage C-020
P1113 Port Deactivation Position Sensor Circuit Low Voltage C-020
P1115 Radiator Outlet Coolant Temperature Sensor Circuit High Voltage Engine Cooling B-011
P1115 Radiator Outlet Coolant Temperature Sensor Circuit Open or Low Voltage Engine Cooling B-011
P1116 Coolant Thermostat Valve Circuit High Voltage Engine Cooling B-013
P1116 Coolant Thermostat Valve Circuit Low Voltage Engine Cooling B-005
P1120 Accelerator Pedal Position Sensor 1 High Input B-016
P1120 Accelerator Pedal Position Sensor 1 Low Input B-016
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio B-016
P1122 Accelerator Pedal Position Sensor 2 High Input B-016
P1122 Accelerator Pedal Position Sensor 2 Low Input B-016
P1217 Coolant Flow Through Radiator Low Engine Cooling B-014
P1300 Misfire Detected at Low Fuel Level B-025
P1405 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High B-032
P1405 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low B-032
P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-012
P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-012
P1483 Fan Control 3 Circuit High Voltage Engine Cooling B-012
P1500 Throttle Control Malfunction B-021
P1526 Throttle Control Lower Position not Learned B-021
P1550 Electronic Throttle Control Power Management C-032
P1550 Electronic Throttle Control Reduced Power C-032
P1550 Electronic Throttle Control Forced Idle C-032
P1550 Electronic Throttle Control Engine Stop C-032
P1606 Engine Torque not plausible B-026
P1612 Immobiliser No Or Wrong Signal Immobiliser B-008
P1620 5V Reference Circuit 1 Malfunction C-001
P1635 5V Reference Circuit 2 Malfunction C-002
P1699 Hardware/Software Not Compatible Hard- and Software B-015
P1700 Service Vehicle Soon Request from Transmission Control Module MTA (Easytronic) (F13-5MTA/F17-5MTA) B-029
U2106 Invalid Data from TCM (Transmission Control Module) MTA (Easytronic) (F13-5MTA/F17-5MTA) B-029
U2108 Invalid Data from ABS (Anti-Lock Brake System) ABS/TC/ESP (Vehicle Dynamic System) B-018
Z18XE
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-016
P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) B-017
P0100 Mass Or Volume Air Flow Circuit High Input B-013
P0100 Mass Or Volume Air Flow Circuit Low Input B-013
P0110 Intake Air Temperature Sensor Circuit High Input C-007
P0110 Intake Air Temperature Sensor Circuit Low Input C-007
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input B-030
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input B-030
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem B-030
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-020
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-020
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-020
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-020
P0134 O2 Sensor Failed C-020
P0134 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) C-020
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) B-016
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-016
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-016
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-022
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-022
P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) C-022
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-022
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) B-017
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) B-017
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-017
P0170 Fuel Trim System Rich B-014
P0170 Fuel Trim System Lean B-014
P0201 Cylinder 1 Injector Circuit High B-018
P0201 Cylinder 1 Injector Circuit Low B-018
P0201 Cylinder 1 Injector Circuit Open B-018
P0202 Cylinder 2 Injector Circuit High B-019
P0202 Cylinder 2 Injector Circuit Low B-019
P0202 Cylinder 2 Injector Circuit Open B-019
P0203 Cylinder 3 Injector Circuit High B-020
P0203 Cylinder 3 Injector Circuit Low B-020
P0203 Cylinder 3 Injector Circuit Open B-020
P0204 Cylinder 4 Injector Circuit High B-021
P0204 Cylinder 4 Injector Circuit Low B-021
P0204 Cylinder 4 Injector Circuit Open B-021
P0219 Engine Overspeed Condition C-026
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input B-030
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input B-030
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem B-030
P0230 Fuel Pump Primary Circuit High B-032
P0230 Fuel Pump Primary Circuit Low B-032
P0301 Cylinder 1 Misfire Detected B-041
P0302 Cylinder 2 Misfire Detected B-041
P0303 Cylinder 3 Misfire Detected B-041
P0304 Cylinder 4 Misfire Detected B-041
P0325 Knock Sensor 1 Circuit Range/Performance (Bank 1 Or Single Sensor) C-017
P0335 Crankshaft Position Sensor Signal Range/Performance C-002
P0335 Crankshaft Sensor Open Circuit B-040
P0340 Camshaft Position Sensor Circuit Open B-031
P0340 Camshaft Position Sensor Circuit Range/Performance B-031
P0351 Ignition Coil Cylinder 1 Circuit High Voltage B-025
P0351 Ignition Coil Cylinder 1 Circuit Range/Performance B-025
P0352 Ignition Coil Cylinder 2 Circuit High Voltage B-026
P0352 Ignition Coil Cylinder 2 Circuit Range/Performance B-026
P0353 Ignition Coil Cylinder 3 Circuit High Voltage B-027
P0353 Ignition Coil Cylinder 3 Circuit Range/Performance B-027
P0354 Ignition Coil Cylinder 4 Circuit High Voltage B-028
P0354 Ignition Coil Cylinder 4 Circuit Range/Performance B-028
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-034
P0443 Fuel Tank Ventilation Valve Voltage High B-015
P0443 Fuel Tank Ventilation Valve Voltage Low B-015
P0443 Fuel Tank Ventilation Open Circuit B-015
P0460 Fuel Level Sensor Circuit Low Input IPC (Instrument) B-013
P0460 Fuel Level Sensor Circuit High Input IPC (Instrument) B-013
P0460 Invalid Data from REC (Rear Electrical Centre) IPC (Instrument) B-013
P0500 Vehicle Speed Signal Range/Performance B-037
P0501 Vehicle Speed Sensor Malfunction B-037
P0530 A/C Pressure Sensor Circuit Open Heating, Ventilation and Air Conditioning System C-009
P0565 Cruise Control "On" Signal Malfunction CRC (Electronic Cruise Control) B-008
P0566 Cruise Control "Off" Signal Malfunction CRC (Electronic Cruise Control) B-008
P0567 Cruise Control "Resume" Signal Malfunction CRC (Electronic Cruise Control) B-008
P0568 Cruise Control "Set" Signal Malfunction CRC (Electronic Cruise Control) B-008
P0571 Brake Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0571 Cruise Control/Brake Switch "A" Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0650 Malfunction Indicator (MI) Circuit Low Voltage B-033
P0650 Malfunction Indicator (MI) Circuit High Voltage B-033
P0650 Malfunction Indicator (MI) Circuit Malfunction B-033
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. AF 17-4 Electronic 4-Speed Automatic Transmission B-024
P1110 Intake Manifold Solenoid Valve 1 Circuit High Voltage B-022
P1110 Intake Manifold Solenoid Valve 1 Circuit Low Voltage B-022
P1110 Intake Manifold Solenoid Valve 1 Circuit Open B-022
P1120 Accelerator Pedal Position Sensor 1 High Input B-029
P1120 Accelerator Pedal Position Sensor 1 Low Input B-029
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio B-029
P1122 Accelerator Pedal Position Sensor 2 High Input B-029
P1122 Accelerator Pedal Position Sensor 2 Low Input B-029
P1170 System Too Lean (Bank 1) B-014
P1170 System Too Rich (Bank 1) B-014
P1230 Main Relay Malfunction B-024
P1326 Knock Control Maximum Spark Level Cylinder 1 B-038
P1327 Knock Control Maximum Spark Level Cylinder 2 B-038
P1328 Knock Control Maximum Spark Level Cylinder 3 B-038
P1329 Knock Control Maximum Spark Level Cylinder 4 B-038
P1372 Crankshaft Sensor Segment Error C-002
P1372 Crankshaft Sensor Adaption Malfunction C-002
P1484 Fan Control 4 Circuit Low Voltage Engine Cooling B-004
P1484 Fan Control 4 Circuit High Voltage Engine Cooling B-004
P1500 Throttle Control Motor Malfunction B-030
P1520 Powerstage Currentless B-030
P1525 Throttle Control Malfunction B-030
P1526 Lower Limit Adaption Error B-030
P1526 Throttle Position Adaption Error B-030
P1526 Limp Home Adaption Error B-030
P1526 Throttle Position Signal Malfunction B-030
P1550 Electronic Throttle Control Reduced Power B-030
P1550 Electronic Throttle Control Forced Idle B-030
P1550 Electronic Throttle Control Power Management B-030
P1550 Electronic Throttle Control Engine Stop B-030
P1551 Engine Torque Request Signal Range/Performance B-012
P1555 Load/Throttle Position not plausible B-030
P1650 Service Vehicle Soon Telltale Low Voltage B-039
P1650 Service Vehicle Soon Telltale High Voltage B-039
P1700 Service Vehicle Soon Request from Transmission Control Module AF 17-4 Electronic 4-Speed Automatic Transmission B-024
P1812 Invalid Signal from ACC (Adaptiv Cruise Control) CRC (Electronic Cruise Control) B-006
P1813 Invalid Signal from TCM (Transmission Control Module) AF 17-4 Electronic 4-Speed Automatic Transmission B-024
Z13DTH
P0030 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-027
P0030 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-042
P0070 Ambient Air Temperature Sensor Malfunction B-020
P0088 Rail Pressure High Pressure B-047
P0090 Rail Pressure Control Valve Voltage High C-022
P0090 Rail Pressure Control Valve Voltage Low C-022
P0093 High Pressure Diagnosis Malfunction C-022
P0095 Charge Air Temperature Sensor Low Input C-015
P0095 Charge Air Temperature Sensor High Input C-015
P0095 Charge Air Temperature Sensor Malfunction B-053
P0100 Mass Air Flow Sensor Voltage Low B-043
P0100 Mass Air Flow Sensor Circuit Low Input B-043
P0100 Mass Air Flow Sensor Voltage High B-024
P0100 Mass Air Flow Sensor Circuit High Input B-025
P0106 Barometric Pressure not plausible with Boost Pressure B-031
P0107 Boost Pressure Low Pressure B-027
P0108 Boost Pressure High Pressure B-028
P0110 Intake Air Temperature Sensor Circuit Malfunction B-052
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-028
P0135 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-050
P0168 Fuel Reduction caused by High Fuel Temperature B-032
P0180 Fuel Temperature Sensor Circuit Low Input C-016
P0180 Fuel Temperature Sensor Circuit High Input C-016
P0180 Fuel Temperature Sensor Circuit Malfunction B-054
P0190 Rail Pressure Sensor Low Input C-020
P0190 Rail Pressure Sensor High Input C-020
P0190 Rail Pressure Range/Performance (Negative Deviation) C-020
P0190 Rail Pressure Range/Performance (Positive Deviation) C-020
P0201 Cylinder 1 Injector Circuit High C-023
P0201 Cylinder 1 Injector Circuit Low C-023
P0201 Cylinder 1 Injector Circuit Open C-023
P0201 Cylinder 1 Injector Malfunction C-023
P0202 Cylinder 2 Injector Circuit High C-024
P0202 Cylinder 2 Injector Circuit Low C-024
P0202 Cylinder 2 Injector Circuit Open C-024
P0202 Cylinder 2 Injector Malfunction C-024
P0203 Cylinder 3 Injector Circuit High C-025
P0203 Cylinder 3 Injector Circuit Low C-025
P0203 Cylinder 3 Injector Circuit Open C-025
P0203 Cylinder 3 Injector Malfunction C-025
P0204 Cylinder 4 Injector Circuit High C-026
P0204 Cylinder 4 Injector Circuit Low C-026
P0204 Cylinder 4 Injector Circuit Open C-026
P0204 Cylinder 4 Injector Malfunction C-026
P0217 Fuel Reduction caused by High Coolant Temperature B-032
P0219 Engine Overspeed Condition C-008
P0230 Fuel Pump Relay Voltage Low C-004
P0230 Fuel Pump Relay Voltage High C-004
P0235 Boost Pressure Sensor Circuit High Input C-012
P0235 Boost Pressure Sensor Circuit Low Input C-012
P0243 Boost Pressure Valve High Voltage C-017
P0243 Boost Pressure Valve Low Voltage B-039
P0243 Boost Pressure Valve Circuit Open B-039
P0243 Boost Pressure Control Circuit Negative Deviation B-055
P0243 Boost Pressure Control Circuit Positive Deviation B-055
P0335 Crankshaft Sensor Circuit Range/Performance C-008
P0380 Glow Device Circuit High Voltage C-032
P0380 Glow Device Circuit Low Voltage B-038
P0380 Glow Device Circuit Open Circuit B-038
P0400 Exhaust Gas Recirculation Valve Malfunction B-051
P0400 Exhaust Gas Recirculation Valve Stuck B-051
P0403 Exhaust Gas Recirculation Circuit Low Voltage C-018
P0403 Exhaust Gas Recirculation Circuit High Voltage C-018
P0403 Exhaust Gas Recirculation Circuit Open C-018
P0500 Vehicle Speed Signal Range/Performance B-030
P0520 Engine Oil Pressure Sensor/Switch Circuit Low Voltage IPC (Instrument) C-018
P0520 Engine Oil Pressure Sensor/Switch Circuit High Voltage IPC (Instrument) C-018
P0565 Cruise Control Switch Malfunction CRC (Electronic Cruise Control) B-006
P0571 Brake Light Switch Circuit Low Input Exterior Lighting/Turn Indicator System B-014
P0622 Generator Field "F" Control Circuit Malfunction B-057
P0638 Electronic Throttle Control Low Voltage B-040
P0638 Electronic Throttle Control Circuit open B-040
P0683 Glow Plug Circuit Low Voltage B-038
P0683 Glow Plug Circuit Open B-038
P0685 Main Relay Circuit High Voltage C-003
P0685 Main Relay Circuit Low Voltage C-003
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. MTA (Easytronic) (M20-6MTA/M32-6MTA) B-025
P1088 Rail Pressure High Pressure B-048
P1093 Fuel System Malfunction C-022
P1105 Barometric Pressure Sensor Circuit Low Input C-011
P1105 Barometric Pressure Sensor Circuit High Input C-011
P1120 Accelerator Pedal Position Sensor 1 High Input C-010
P1120 Accelerator Pedal Position Sensor 1 Low Input C-010
P1120 Accelerator Pedal Position Sensor 1 Malfunction C-010
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-010
P1122 Accelerator Pedal Position Sensor 2 Low Input C-010
P1122 Accelerator Pedal Position Sensor 2 High Input C-010
P1122 Accelerator Pedal Position Sensor 2 Malfunction C-010
P1180 Fuel Filter Heater High Voltage C-034
P1180 Fuel Filter Heater Low Voltage B-037
P1180 Fuel Filter Heater Circuit Open B-037
P1190 Rail Pressure Control Valve Stuck B-047
P1191 Fuel Metering Solenoid Valve Circuit Range/Performance B-048
P1191 Rail Pressure Range/Performance B-049
P1191 Rail Pressure Low Pressure B-049
P1192 Rail Pressure High Pressure B-049
P1264 Water in Fuel Filter Detected B-021
P1564 Battery Circuit Open C-039
P1571 Brake Switch Circuit Low Voltage Exterior Lighting/Turn Indicator System B-014
P1619 Airbag Deployed SDM (Airbag) B-008
P1620 5V Reference Circuit 1 High Voltage C-005
P1620 5V Reference Circuit 1 Low Voltage C-005
P1625 Main Relay Output Voltage Low B-017
P1625 Main Relay Output Voltage High B-017
P1635 5V Reference Circuit 2 High Voltage C-006
P1635 5V Reference Circuit 2 Low Voltage C-006
P1639 5V Reference Circuit 3 Low Voltage C-007
P1639 5V Reference Circuit 3 High Voltage C-007
P1700 Service Vehicle Soon Request from Transmission Control Module MTA (Easytronic) (M20-6MTA/M32-6MTA) B-025
P1814 Invalid Signal from ECC (Electronic Climate Control) ECC/SAC (Electronic Climate Control) C-003
P1900 Limp Home - Particulate Filter Limited Performance B-046
P1900 Particulate Filter Regeneration Cycle Interrupted Several Times B-056
P1901 Particulate Filter Pressure Sensor Low Voltage C-030
P1901 Particulate Filter Pressure Sensor Low Differential Pressure C-030
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-056
P1901 Particulate Filter Pressure Sensor High Voltage C-030
P1901 Particulate Filter Pressure Sensor Range/Performance B-056
P1901 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow C-030
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction C-030
P1902 Exhaust Gas Temperature Sensor Circuit Low Voltage C-029
P1902 Exhaust Gas Temperature Sensor Circuit Open or High Voltage C-029
P1902 Exhaust Gas Temperature Sensor Signal Range/Performance C-029
P2003 Particulate Filter Pressure Sensor Much too High Differential Pressure C-030
P2146 Capacitor Voltage 1 High Voltage C-001
P2146 Capacitor Voltage 1 Low Voltage C-001
P2237 O2 Sensor Pump Current Circuit Malfunction (Bank 1 Sensor 1) C-028
P2244 O2 Sensor Reference Cell Circuit Malfunction (Bank 1 Sensor 1) C-028
P2264 "Water In Fuel" Sensor Circuit Malfunction B-021
P2297 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-050
#2 · (Edited by Moderator)
Engine controls CONT
Z18XER
P0010 Intake Camshaft Phasing Powerstage Circuit High Voltage C-006
P0010 Intake Camshaft Phasing Powerstage Circuit Low Voltage B-035
P0010 Intake Camshaft Phasing Powerstage Circuit Open B-035
P0011 Intake Camshaft Phasing Mechanics Malfunction B-035
P0011 Intake Camshaft Phasing Mechanics Range/Performance (Bank 1) B-035
P0011 Intake Camshaft Phasing Mechanical Reference Position Range/Peformance (Bank 1) B-035
P0013 Exhaust Camshaft Phasing Powerstage Circuit High Voltage C-007
P0013 Exhaust Camshaft Phasing Powerstage Circuit Low Voltage B-036
P0013 Exhaust Camshaft Phasing Powerstage Circuit Open B-036
P0014 Exhaust Camshaft Phasing Mechanics Malfunction B-036
P0014 Exhaust Camshaft Phasing Mechanics Range/Performance B-036
P0014 Exhaust Camshaft Phasing Mechanical Reference Position Range/Performance B-036
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-017
P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) B-018
P0068 Load/Throttle Position not plausible B-031
P0075 Intake Manifold Solenoid Valve 1 Circuit High Voltage B-023
P0075 Intake Manifold Solenoid Valve 1 Circuit Low Voltage B-023
P0100 Mass Or Volume Air Flow Circuit High Input B-014
P0100 Mass Or Volume Air Flow Circuit Low Input B-014
P0105 Manifold Absolute Pressure (MAP) Sensor Voltage Low B-043
P0105 Manifold Absolute Pressure (MAP) Sensor Voltage High B-043
P0105 Manifold Absolute Pressure Sensor Circuit Malfunction B-043
P0110 Intake Air Temperature Sensor Circuit Low Input B-044
P0110 Intake Air Temperature Sensor Circuit High Input B-044
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input B-031
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input B-031
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem B-031
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-027
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-027
P0130 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-027
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-027
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-027
P0134 O2 Sensor Failed C-027
P0134 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) C-027
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) B-017
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-017
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-017
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-029
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-029
P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-029
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-029
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) B-018
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) B-018
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-018
P0170 O2 Sensor Lean Exhaust B-015
P0170 O2 Sensor Rich Exhaust B-015
P0201 Cylinder 1 Injector Circuit High C-020
P0201 Cylinder 1 Injector Circuit Low B-019
P0201 Cylinder 1 Injector Circuit Open B-019
P0202 Cylinder 2 Injector Circuit High C-021
P0202 Cylinder 2 Injector Circuit Low B-020
P0202 Cylinder 2 Injector Circuit Open B-020
P0203 Cylinder 3 Injector Circuit High C-022
P0203 Cylinder 3 Injector Circuit Low B-021
P0203 Cylinder 3 Injector Circuit Open B-021
P0204 Cylinder 4 Injector Circuit High C-023
P0204 Cylinder 4 Injector Circuit Low B-022
P0204 Cylinder 4 Injector Circuit Open B-022
P0219 Engine Overspeed Condition C-031
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input B-031
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input B-031
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem B-031
P0230 Fuel Pump Primary Circuit Low B-033
P0230 Fuel Pump Primary Circuit High C-008
P0301 Cylinder 1 Misfire Detected B-051
P0302 Cylinder 2 Misfire Detected B-051
P0303 Cylinder 3 Misfire Detected B-051
P0304 Cylinder 4 Misfire Detected B-051
P0315 Crankshaft Sensor Segment Error B-037
P0315 Crankshaft Sensor Adaption Malfunction B-037
P0325 Knock Sensor 1 Circuit Range/Performance (Bank 1 Or Single Sensor) B-049
P0335 Crankshaft Sensor Open Circuit B-037
P0335 Crankshaft Position Sensor Signal Range/Performance B-037
P0335 Crankshaft Sensor Incorrect Signal B-037
P0340 Intake Camshaft Position Sensor Circuit Open (Bank 1) B-038
P0340 Intake Camshaft Position Range/Performance (Bank 1) B-038
P0351 Ignition Coil Cylinder 1 Circuit High Voltage C-016
P0351 Ignition Coil Cylinder 1 Circuit Range/Performance B-026
P0352 Ignition Coil Cylinder 2 Circuit High Voltage C-017
P0352 Ignition Coil Cylinder 2 Circuit Range/Performance B-027
P0353 Ignition Coil Cylinder 3 Circuit High Voltage C-018
P0353 Ignition Coil Cylinder 3 Circuit Range/Performance B-028
P0354 Ignition Coil Cylinder 4 Circuit High Voltage C-019
P0354 Ignition Coil Cylinder 4 Circuit Range/Performance B-029
P0365 Camshaft Position Sensor Circuit No Signal B-039
P0365 Camshaft Position Sensor Circuit Range/Performance B-039
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-046
P0443 Fuel Tank Ventilation Valve Voltage High C-025
P0443 Fuel Tank Ventilation Valve Voltage Low B-016
P0443 Fuel Tank Ventilation Open Circuit B-016
P0480 Fan Control 1 Circuit High Voltage Engine Cooling B-004
P0480 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
P0481 Fan Control 2 Circuit High Voltage Engine Cooling B-004
P0481 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
P0482 Fan Control 3 Circuit High Voltage C-041
P0482 Fan Control 3 Circuit Low Voltage C-041
P0500 Vehicle Speed Signal Range/Performance B-048
P0501 Vehicle Speed Sensor Malfunction B-048
P0530 A/C Pressure Sensor Circuit High Input B-040
P0530 A/C Pressure Sensor Circuit Open B-040
P0564 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-006
P0597 Coolant Thermostat Valve Stuck B-032
P0597 Coolant Thermostat Valve Circuit Open B-032
P0597 Coolant Thermostat Valve Circuit High Voltage B-032
P0597 Coolant Thermostat Valve Circuit Low Voltage B-032
P0601 Replace Electronic Control Unit (ECU) B-041
P0650 CAN-Bus Failure - No CAN-Message B-045
P0685 Main Relay Circuit High Voltage B-025
P0685 Main Relay Circuit Low Voltage B-025
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. B-047
P0703 Brake Switch Circuit Low Voltage B-034
P0703 Brake Switch Failure B-034
P0703 Brake Switch Circuit High Voltage B-034
P0703 Brake Switch Circuit Malfunction B-034
P1700 Service Vehicle Soon Request from Transmission Control Module B-050
P2101 Throttle Control Motor Malfunction B-031
P2106 Electronic Throttle Control Reduced Power B-031
P2106 Electronic Throttle Control Forced Idle B-031
P2106 Electronic Throttle Control Power Management B-031
P2106 Electronic Throttle Control Engine Stop B-031
P2118 Powerstage Currentless B-031
P2119 Throttle Control Malfunction B-031
P2120 Accelerator Pedal Position Sensor 1 Voltage High B-030
P2120 Accelerator Pedal Position Sensor 1 Voltage Low B-030
P2120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio B-030
P2125 Accelerator Pedal Position Sensor 2 Voltage High B-030
P2125 Accelerator Pedal Position Sensor 2 Voltage Low B-030
P2176 Throttle Position Signal Malfunction B-031
P2176 Lower Limit Adaption Error B-031
P2176 Limp Home Adaption Error B-031
P2176 Throttle Position Adaption Error B-031
P2176 Battery Voltage Range/Performance B-031
P2176 Engine Speed Signal Range/Performance B-031
P2176 Throttle Relaxer Position Sensor Fault B-031
P2176 Vehicle Speed Sensor Range/Performance B-031
P2176 Intake Air Temperature Circuit Range/Performance Problem B-031
P2182 Engine Coolant Temperature Sensor Open Or Short Circuit Engine Cooling C-002
P2182 Engine Coolant Temperature Sensor Circuit Low Voltage Engine Cooling C-002
P2182 Engine Coolant Temperature Sensor Circuit Range/Performance B-042
P2639 Engine Torque Request Signal Range/Performance B-013
U0402 Invalid Signal from TCM (Transmission Control Module) AF 17-4 Electronic 4-Speed Automatic Transmission B-024
U0405 Invalid Signal from ACC (Adaptiv Cruise Control) CRC (Electronic Cruise Control) B-006
U0415 Torque Signal Malfunction (CAN) ABS/TC/ESP (Vehicle Dynamic System) B-018
U0424 Invalid Signal from ECC (Electronic Climate Control) ECC/SAC (Electronic Climate Control) C-003
Z17DTR Z17DTJ A17DTJ A17DTR
P0001 Fuel Metering Solenoid Valve Circuit High Voltage C-018
P0001 Fuel Metering Solenoid Valve Circuit Low Voltage C-018
P0001 Fuel Metering Solenoid Valve Stuck B-025
P0016 Crankshaft/Camshaft Correlation B-015
P0030 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) B-024
P0030 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) B-024
P0087 Rail Pressure Low Pressure B-025
P0088 Rail Pressure High Pressure B-025
P0093 Rail Pressure High Pressure B-025
P0094 Rail Pressure Range/Performance B-025
P0095 Charge Air Temperature Sensor High Input C-012
P0095 Charge Air Temperature Sensor Low Input C-012
P0100 Mass Or Volume Air Flow Circuit High Input B-021
P0100 Mass Or Volume Air Flow Circuit Low Input B-021
P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance B-021
P0110 Intake Air Temperature Sensor Circuit High Input C-011
P0110 Intake Air Temperature Sensor Circuit Low Input C-011
P0110 Intake Air Temperature Sensor Circuit High Frequency C-011
P0110 Intake Air Temperature Sensor Circuit Low Frequency C-011
P0130 O2 Sensor Ground Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Ground Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Pump Current Circuit High Voltage (Bank 1 Sensor 1) C-028
P0130 O2 Sensor Pump Current Circuit Low Voltage (Bank 1 Sensor 1) C-028
P0168 Fuel Quantity Reduction caused by High Exhaust Gas Temperature B-034
P0180 Fuel Temperature Sensor Circuit High Input C-013
P0180 Fuel Temperature Sensor Circuit Low Input C-013
P0190 Rail Pressure Sensor High Voltage C-006
P0190 Rail Pressure Sensor Low Voltage C-006
P0190 Rail Pressure Range/Performance C-006
P0190 Rail Pressure High Pressure C-006
P0217 Engine Overtemperature Condition Engine Cooling B-008
P0234 Boost Pressure High Pressure B-036
P0235 Boost Pressure Sensor Circuit High Input C-009
P0235 Boost Pressure Sensor Circuit Low Input C-009
P0235 Boost Pressure Sensor Circuit Range/Performance C-009
P0243 Boost Pressure Valve High Voltage B-019
P0243 Boost Pressure Valve Low Voltage B-019
P0299 Boost Pressure Low Pressure B-036
P0299 Intake Air System Leak Detected B-036
P0301 Cylinder 1 Misfire Detected C-019
P0302 Cylinder 2 Misfire Detected C-020
P0303 Cylinder 3 Misfire Detected C-021
P0304 Cylinder 4 Misfire Detected C-022
P0335 Crankshaft Position Sensor Signal Range/Performance C-007
P0335 Crankshaft Position Sensor Circuit Malfunction C-007
P0340 Camshaft Position Sensor Circuit Malfunction C-008
P0380 Glow Device Circuit High Voltage B-016
P0380 Glow Device Circuit Low Voltage B-016
P0400 Exhaust Gas Recirculation Valve Stuck C-015
P0400 Exhaust Gas Recirculation Flow Excessive Detected C-015
P0403 Exhaust Gas Recirculation Circuit Open C-015
P0403 Exhaust Gas Recirculation Circuit Low Voltage or High Voltage C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low C-015
P0409 Exhaust Gas Recirculation (EGR) Valve Feedback Incorrect Signal C-015
P0425 Exhaust Gas Temperature Sensor 1 High Voltage C-025
P0425 Exhaust Gas Temperature Sensor 1 Low Voltage C-025
P0425 Exhaust Gas Temperature Sensor 1 High Temperature C-025
P0425 Exhaust Gas Temperature Sensor 1 Temperature not Plausible B-028
P042A Exhaust Gas Temperature Sensor 2 High Voltage C-026
P042A Exhaust Gas Temperature Sensor 2 Low Voltage C-026
P042A Exhaust Gas Temperature Sensor 2 High Temperature C-026
P042A Exhaust Gas Temp. Sen. 2 not Plausible with Exhaust Gas Temp. Sen. 1 and Intake Air Temp. B-029
P0480 Fan Control 1 Circuit High Voltage Engine Cooling B-005
P0480 Fan Control 1 Circuit Low Voltage Engine Cooling B-005
P0481 Fan Control 2 Circuit High Voltage Engine Cooling B-005
P0481 Fan Control 2 Circuit Low Voltage Engine Cooling B-005
P0482 Fan Control 3 Circuit High Voltage Engine Cooling B-005
P0482 Fan Control 3 Circuit Low Voltage Engine Cooling B-005
P0500 Vehicle Speed Sensor Malfunction ABS/TC/ESP (Vehicle Dynamic System) B-010
P0571 Brake Light Switch Permanently Active Exterior Lighting/Turn Indicator System B-014
P0615 Starter Relay Circuit High Voltage B-023
P0615 Starter Relay Circuit Low Voltage B-023
P0638 Throttle Control Solenoid Valve High Voltage B-017
P0638 Throttle Control Solenoid Valve Low Voltage B-017
P0641 5V Reference Circuit 1 High Voltage C-003
P0641 5V Reference Circuit 1 Low Voltage C-003
P0651 5V Reference Circuit 2 High Voltage C-004
P0651 5V Reference Circuit 2 Low Voltage C-004
P0660 Swirl Level Control Solenoid Valve High Voltage B-018
P0660 Swirl Level Control Solenoid Valve Low Voltage B-018
P0683 Glow Device General Error B-016
P0685 Main Relay Circuit High Voltage C-002
P0685 Main Relay Stuck Closed C-002
P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-011
P1120 Accelerator Pedal Position Sensor 1 High Input C-005
P1120 Accelerator Pedal Position Sensor 1 Low Input C-005
P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-005
P1122 Accelerator Pedal Position Sensor 2 High Input C-005
P1122 Accelerator Pedal Position Sensor 2 Low Input C-005
P1571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P1625 Main Relay Circuit Low Voltage B-020
P1625 Main Relay Stuck Open B-020
P2002 Particulate Filter Regeneration Not Completed B-037
P2146 Cylinder 1 + 4 Injector Circuit Low Voltage C-023
P2146 Cylinder 1 + 4 Injector Circuit High Voltage C-023
P2149 Cylinder 2 + 3 Injector Circuit Low Voltage C-023
P2149 Cylinder 2 + 3 Injector Circuit High Voltage C-023
P2226 Barometric Pressure Sensor Circuit Low Input C-001
P2226 Barometric Pressure Sensor Circuit High Input C-001
P2425 Exhaust Gas Recirculation Cooler Bypass Solenoid Valve Circuit High Voltage B-022
P2425 Exhaust Gas Recirculation Cooler Bypass Solenoid Valve Circuit Low Voltage B-022
P242F Diesel Particulate Filter Overloaded C-027
P2452 Particulate Filter Pressure Sensor High Voltage B-026
P2452 Particulate Filter Pressure Sensor Low Voltage B-026
P2452 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow B-026
P2452 Particulate Filter Pressure Sensor Hose Line Malfunction B-026
P2452 Particulate Filter Pressure Sensor High Pressure B-026
P2620 Throttle Control Malfunction C-017
U0405 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-009
Z16LET
P0070 Ambient Air Temperature Sensor Malfunction B-035
P0100 Mass Or Volume Air Flow Circuit High Input B-025
P0100 Mass Or Volume Air Flow Circuit Low Input B-025
P0100 Mass Or Volume Air Flow Circuit Malfunction B-025
P0110 Intake Air Temperature Sensor Circuit Low Input B-029
P0110 Intake Air Temperature Sensor Circuit High Input B-029
P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling C-001
P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling C-001
P0115 Engine Coolant Temperature Circuit High Input Engine Cooling C-001
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input B-024
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input B-024
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem B-024
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) B-037
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) B-037
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-037
P0130 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-036
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) B-037
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-017
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-012
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) B-038
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) B-038
P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-038
P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-039
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-039
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-013
P0170 Fuel Trim Malfunction (Bank 1) B-022
P0219 Engine Overspeed Condition C-021
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input B-024
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input B-024
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem B-024
P0230 Fuel Pump Primary Circuit Low B-011
P0230 Fuel Pump Primary Circuit High B-011
P0235 Boost Pressure Sensor Circuit Low Input B-028
P0235 Boost Pressure Sensor Circuit High Input B-028
P0243 Boost Pressure Valve High Voltage B-017
P0243 Boost Pressure Valve Low Voltage B-017
P0243 Boost Pressure Valve Circuit Open B-017
P0300 Random/Multiple Cylinder Misfire Detected B-032
P0301 Cylinder 1 Misfire Detected B-032
P0302 Cylinder 2 Misfire Detected B-032
P0303 Cylinder 3 Misfire Detected B-032
P0304 Cylinder 4 Misfire Detected B-032
P0313 Misfire Detected at Low Fuel Level B-032
P0325 Knock Sensor 1 Circuit High Input (Bank 1 Or Single Sensor) B-033
P0325 Knock Sensor 1 Circuit Low Input (Bank 1 Or Single Sensor) B-033
P0335 Crankshaft Sensor Circuit Range/Performance B-027
P0335 Crankshaft Sensor Incorrect Signal B-027
P0340 Camshaft Position Sensor Circuit Low Input B-026
P0340 Camshaft Position Sensor Circuit High Input B-026
P0340 Camshaft Position Sensor Circuit Open B-026
P0340 Camshaft Position Sensor Circuit Range/Performance B-026
P0340 Camshaft Position Sensor Circuit Malfunction B-026
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-023
P0460 Fuel Level Sensor Circuit Range/Performance IPC (Instrument) B-013
P0500 Vehicle Speed Signal Range/Performance B-034
P0501 Vehicle Speed Signal Range/Performance B-034
P0530 A/C Pressure Sensor Circuit High Input Heating, Ventilation and Air Conditioning System C-009
P0530 A/C Pressure Sensor Circuit Low Input Heating, Ventilation and Air Conditioning System C-009
P0571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
P0607 Knock Control Module; Replace ECU B-033
P0607 Knock Sensor Circuit Malfunction B-033
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-010
P1105 Barometric Pressure Sensor Circuit Low Input C-026
P1105 Barometric Pressure Sensor Circuit High Input C-026
P1106 Boost Pressure Sensor Circuit Range/Performance B-028
P1243 Turbocharger Bypass Solenoid Valve Circuit High Voltage C-029
P1243 Turbocharger Bypass Solenoid Valve Circuit Low Voltage B-016
P1243 Turbocharger Bypass Solenoid Valve Circuit Open B-016
P1243 Turbocharger Bypass Valve Range/Performance B-016
P1500 Electronic Throttle Control Malfunction B-015
P1523 Throttle Actuator Control Return Performance B-015
P1526 Throttle Control Lower Position not Learned B-015
P1600 Engine Torque not plausible B-040
P1606 Engine Torque not plausible B-040
Z16XER
P0010 Intake Camshaft Phasing Powerstage Circuit Low Voltage B-033
P0010 Intake Camshaft Phasing Powerstage Circuit Open B-033
P0011 Intake Camshaft Phasing Mechanics Malfunction B-033
P0011 Intake Camshaft Phasing Mechanics Range/Performance (Bank 1) B-033
P0011 Intake Camshaft Phasing Mechanical Reference Position Range/Peformance (Bank 1) B-033
P0013 Exhaust Camshaft Phasing Powerstage Circuit Low Voltage B-034
P0013 Exhaust Camshaft Phasing Powerstage Circuit Open B-034
P0014 Exhaust Camshaft Phasing Mechanics Malfunction B-034
P0014 Exhaust Camshaft Phasing Mechanics Range/Performance B-034
P0014 Exhaust Camshaft Phasing Mechanical Reference Position Range/Performance B-034
P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) B-015
P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) B-016
P0068 Load/Throttle Position not plausible B-029
P0075 Intake Manifold Solenoid Valve 1 Circuit High Voltage B-021
P0075 Intake Manifold Solenoid Valve 1 Circuit Low Voltage B-021
P0105 Manifold Absolute Pressure (MAP) Sensor Voltage High B-040
P0105 Manifold Absolute Pressure (MAP) Sensor Voltage Low B-040
P0105 Manifold Absolute Pressure Sensor Circuit Malfunction B-040
P0110 Intake Air Temperature Sensor Circuit Low Input C-012
P0110 Intake Air Temperature Sensor Circuit High Input C-012
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input B-029
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input B-029
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem B-029
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-025
P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-025
P0130 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-025
P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) C-025
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-025
P0134 O2 Sensor Failed C-025
P0134 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) C-025
P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) B-015
P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-015
P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-015
P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-027
P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-027
P0136 O2 Sensor Circuit Open (Bank 1 Sensor 2) C-027
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) C-027
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) B-016
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) B-016
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-016
P0170 O2 Sensor Lean Exhaust B-013
P0170 O2 Sensor Rich Exhaust B-013
P0201 Cylinder 1 Injector Circuit High C-018
P0201 Cylinder 1 Injector Circuit Low B-017
P0201 Cylinder 1 Injector Circuit Open B-017
P0202 Cylinder 2 Injector Circuit High C-019
P0202 Cylinder 2 Injector Circuit Low B-018
P0202 Cylinder 2 Injector Circuit Open B-018
P0203 Cylinder 3 Injector Circuit High C-020
P0203 Cylinder 3 Injector Circuit Low B-019
P0203 Cylinder 3 Injector Circuit Open B-019
P0204 Cylinder 4 Injector Circuit High C-021
P0204 Cylinder 4 Injector Circuit Low B-020
P0204 Cylinder 4 Injector Circuit Open B-020
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input B-029
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input B-029
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem B-029
P0230 Fuel Pump Primary Circuit Low B-031
P0301 Cylinder 1 Misfire Detected B-045
P0302 Cylinder 2 Misfire Detected B-045
P0303 Cylinder 3 Misfire Detected B-045
P0304 Cylinder 4 Misfire Detected B-045
P0315 Crankshaft Sensor Segment Error B-035
P0315 Crankshaft Sensor Adaption Malfunction B-035
P0325 Knock Sensor 1 Circuit Range/Performance (Bank 1 Or Single Sensor) B-044
P0335 Crankshaft Sensor Open Circuit B-035
P0335 Crankshaft Position Sensor Signal Range/Performance B-035
P0335 Crankshaft Sensor Incorrect Signal B-035
P0340 Intake Camshaft Position Sensor Circuit Open (Bank 1) B-036
P0340 Intake Camshaft Position Range/Performance (Bank 1) B-036
P0351 Ignition Coil Cylinder 1 Circuit High Voltage C-014
P0351 Ignition Coil Cylinder 1 Circuit Range/Performance B-024
P0352 Ignition Coil Cylinder 2 Circuit High Voltage C-015
P0352 Ignition Coil Cylinder 2 Circuit Range/Performance B-025
P0353 Ignition Coil Cylinder 3 Circuit High Voltage C-016
P0353 Ignition Coil Cylinder 3 Circuit Range/Performance B-026
P0354 Ignition Coil Cylinder 4 Circuit High Voltage C-017
P0354 Ignition Coil Cylinder 4 Circuit Range/Performance B-027
P0365 Camshaft Position Sensor Circuit No Signal B-037
P0365 Camshaft Position Sensor Circuit Range/Performance B-037
P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-042
P0443 Fuel Tank Ventilation Valve Voltage High C-023
P0482 Fan Control 3 Circuit High Voltage C-039
P0482 Fan Control 3 Circuit Low Voltage C-039
P0500 Vehicle Speed Signal Range/Performance B-043
P0501 Vehicle Speed Sensor Malfunction B-043
P0530 A/C Pressure Sensor Circuit High Input B-038
P0530 A/C Pressure Sensor Circuit Open B-038
P0564 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-007
P0571 Brake Light Switch Circuit High Input Exterior Lighting/Turn Indicator System B-014
P0597 Coolant Thermostat Valve Stuck B-030
P0597 Coolant Thermostat Valve Circuit Open B-030
P0597 Coolant Thermostat Valve Circuit High Voltage B-030
P0597 Coolant Thermostat Valve Circuit Low Voltage B-030
P0601 Replace Electronic Control Unit (ECU) B-039
P0645 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
P0645 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
P0650 CAN-Bus Failure - No CAN-Message B-041
P0685 Main Relay Circuit High Voltage B-023
P0685 Main Relay Circuit Low Voltage B-023
P0700 Malfunction Indicator (MI) Request from Transmission Control Module (TCM) Range/Perform. B-049
P0703 Brake Switch Circuit Low Voltage B-032
P0703 Brake Switch Failure B-032
P0703 Brake Switch Circuit High Voltage B-032
P0703 Brake Switch Circuit Malfunction B-032
P1610 Immobiliser Malfunction Immobiliser B-009
P1611 Wrong Security Code Entered Immobiliser B-015
P1613 Immobiliser No Or Wrong Signal Immobiliser B-008
P1614 Immobiliser Wrong Signal Received Immobiliser B-008
P1614 Wrong Transponder Key Immobiliser B-008
P1615 ECM (Engine Control Module) Identification Failed Immobiliser B-006
P1616 CIM (Steering Column Module) Wrong Environment Identifier Immobiliser B-006
P1700 Service Vehicle Soon Request from Transmission Control Module B-049
P2101 Throttle Control Motor Malfunction B-029
P2106 Electronic Throttle Control Reduced Power B-029
P2106 Electronic Throttle Control Forced Idle B-029
P2106 Electronic Throttle Control Power Management B-029
P2106 Electronic Throttle Control Engine Stop B-029
P2118 Powerstage Currentless B-029
P2119 Throttle Control Malfunction B-029
P2120 Accelerator Pedal Position Sensor 1 Voltage High B-028
P2120 Accelerator Pedal Position Sensor 1 Voltage Low B-028
P2120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio B-028
P2125 Accelerator Pedal Position Sensor 2 Voltage High B-028
P2125 Accelerator Pedal Position Sensor 2 Voltage Low B-028
P2176 Throttle Position Signal Malfunction B-029
P2176 Lower Limit Adaption Error B-029
P2176 Limp Home Adaption Error B-029
P2176 Throttle Position Adaption Error B-029
P2176 Battery Voltage Range/Performance B-029
P2176 Engine Speed Signal Range/Performance B-029
P2176 Throttle Relaxer Position Sensor Fault B-029
P2176 Vehicle Speed Sensor Range/Performance B-029
P2176 Intake Air Temperature Circuit Range/Performance Problem B-029
P2182 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling C-002
P2639 Engine Torque Request Signal Range/Performance B-012
#3 · (Edited by Moderator)
Chassis Control Codes
ABS/ESP/TC Vehicle Dynamic System
B0946 Sport Mode Switch LED Circuit Low Voltage C-017
B0946 Sport Mode Switch LED Circuit Open Circuit or High Voltage C-017
B1012 Steering Angle Sensor Not Calibrated B-015
B1020 Steering Angle Sensor Angle Range/Performance B-015
B1020 Steering Angle Sensor Angular Velocity Range/Performance C-008
B1020 Steering Angle Sensor Circuit Malfunction C-008
B2795 Sport Mode Switch Circuit Open or High Voltage C-016
B2795 Sport Mode Switch Stuck C-016
C0035 Front Left Wheel Speed Sensor No Signal C-001
C0035 Front Left Wheel Speed Sensor Malfunction C-001
C0035 Front Left Wheel Speed Sensor Range/Performance C-001
C0040 Front Right Wheel Speed Sensor No Signal C-002
C0040 Front Right Wheel Speed Sensor Malfunction C-002
C0040 Front Right Wheel Speed Sensor Range/Performance C-002
C0045 Rear Left Wheel Speed Sensor No Signal C-003
C0045 Rear Left Wheel Speed Sensor Circuit Malfunction C-003
C0045 Rear Left Wheel Speed Sensor Range/Performance C-003
C0050 Rear Right Wheel Speed Sensor No Signal C-004
C0050 Rear Right Wheel Speed Sensor Malfunction C-004
C0050 Rear Right Wheel Speed Sensor Range/Performance C-004
C0060 Front Left Inlet Solenoid Valve Circuit Malfunction C-009
C0065 Front Left Outlet Solenoid Valve Circuit Malfunction C-009
C0070 Front Right Inlet Solenoid Valve Circuit Malfunction C-009
C0075 Front Right Outlet Solenoid Valve Circuit Malfunction C-009
C0080 Rear Left Inlet Solenoid Valve Circuit Malfunction C-009
C0085 Rear Left Outlet Solenoid Valve Circuit Malfunction C-009
C0090 Rear Right Inlet Solenoid Valve Circuit Malfunction C-009
C0095 Rear Right Outlet Solenoid Valve Circuit Malfunction C-009
C0110 Return Pump Circuit Malfunction B-008
C0121 Valve Relay Circuit Malfunction C-009
C0131 Pressure Sensor Circuit Malfunction C-006
C0131 Pressure Sensor Signal Circuit Range/Performance C-006
C0131 Pressure Sensor not Calibrated C-006
C0141 Front Left/Rear Right TC/ESP Primary Solenoid Valve Circuit Malfunction C-009
C0146 Front Left/Rear Right TC/ESP Switchover Solenoid Valve Circuit Malfunction C-009
C0151 Front Right/Rear Left TC/ESP Primary Solenoid Valve Circuit Malfunction C-009
C0156 Front Right/Rear Left TC/ESP Switchover Solenoid Valve Circuit Malfunction C-009
C0161 Brake Light Switch malfunction Exterior Lighting/Turn Indicator System B-014
C0186 Lateral Acceleration Sensor not Calibrated B-016
C0186 Lateral Acceleration Sensor Circuit Malfunction C-007
C0186 Lateral Acceleration Sensor Circuit Range/Performance C-007
C0196 Yaw Rate Sensor Circuit Range/Performance C-007
C0196 Yaw Rate Sensor Circuit Malfunction C-007
C0236 Invalid Data from ECM (Engine Control Module) B-018
C0237 Accelerator Pedal Position Sensor Incorrect Signal B-018
C0240 Invalid Data from ECM (Engine Control Module) B-018
C0241 Engine Torque Request Signal Range/Performance B-018
C0242 Engine Torque Request Signal Range/Performance B-018
C0244 Invalid Data from ECM (Engine Control Module) B-018
C0280 ESP Activation Time Out Of Range C-007
C0287 Longitudinal Acceleration Sensor not Calibrated B-016
C0287 Longitudinal Acceleration Sensor Circuit Malfunction C-007
C0287 Longitudinal Acceleration Sensor Circuit Range/Performance C-007
C0292 Sensor Cluster Power Supply Range/Performance C-007
C0292 Sensor Cluster Malfunction C-007
C0460 Steering Angle Sensor not Calibrated B-015
C0460 Steering Angle Sensor Circuit Malfunction C-008
C0460 Steering Angle Sensor not initialized C-008
C0460 Invalid Data from Steering Angle Sensor C-008
C0460 Steering Angle Sensor Signal Circuit Range/Performance B-015
C0730 Invalid Gear Signal from TCM(Transmission Control Module) B-017
C0736 Invalid Gear Signal from CIM (Steering Column Module) B-017
P0500 Vehicle Speed Signal Range/Performance B-009
U1500 Local CAN-Bus Malfunction C-007
U2142 CAN-Bus No Communication with YRS (Yaw Rate Sensor) C-007
U2143 Steering Angle Sensor not Calibrated B-015
Cruise Control
B3643 Adaptive Cruise Control "Set" Switch Stuck B-007
B3643 Adaptive Cruise Control "Set" Switch Circuit Resistance Range/Performance B-007
B3794 Cruise Control "Set" Switch Circuit Resistance Range/Performance B-007
B3794 Cruise Control "Set" Switch Stuck
Tyre Pressure Monitering System
B2816 TPMS Switch Stuck (Tyre Pressure Monitoring System) C-005
B2816 TPMS Switch Circuit Open or High Voltage (Tyre Pressure Monitoring System) C-005
C0558 Tyre Pressure Sensors IDs Not Learned C-002
C0750 Front Left Pressure Sensor Circuit Range/Performance C-006
C0750 Pressure Sensor Module A Malfunction C-004
C0755 Front Right Pressure Sensor Circuit Range/Performance C-007
C0755 Pressure Sensor Module B Malfunction C-004
C0760 Rear Left Pressure Sensor Circuit Range/Performance C-008
C0760 Pressure Sensor Module C Malfunction C-004
C0765 Rear Right Pressure Sensor Circuit Range/Performance C-009
C0765 Pressure Sensor Module D Malfunction C-004
C0785 One Tyre Pressure Sensor Battery Low Voltage C-002
C0785 One Tyre Pressure Sensor Malfunction C-002
C0786 Two Tyre Pressure Sensors Battery Low Voltage C-002
C0786 Two Tyre Pressure Sensors Malfunction C-002
C0787 Three Tyre Pressure Sensors Battery Low Voltage C-002
C0787 Three Tyre Pressure Sensors Malfunction C-002
C0788 Four Tyre Pressure Sensors Battery Low Voltage C-002
C0788 Four Tyre Pressure Sensors Malfunction C-002
U2117 Invalid Data from DIS (Display) B-006
U2139 Invalid Data from CIM (Steering Column Module) B-006
U2140 Invalid Data from UEC (Underhood Electrical Centre) B-006
U2149 Invalid Signal from TPMS (Tyre Pressure Monitoring System) B-006
Steering
C1512 Electronic Control Unit (ECU) Fault - Temperature C-001
C1526 Motor Malfunction C-001
C1527 Motor Circuit High Current C-001
C1531 Motor Lock Protection Active C-002
U2105 Generator Malfunction C-001
U2105 CAN-Bus CIM Message Range/Performance B-009
U2139 Airbag Deployed B-010
U2139 CAN-Bus ECM Message Range/Performance
Suspension
C0000 Damper Mode Switch Information Via CAN-Bus Incorrect Signal B-012
C0035 Front Left Wheel Speed Sensor Incorrect Signal B-011
C0040 Front Right Wheel Speed Sensor Incorrect Signal B-011
C0045 Rear Left Wheel Speed Sensor Incorrect Signal B-011
C0050 Rear Right Wheel Speed Sensor Incorrect Signal B-011
C0131 Brake Pressure Sensor Malfunction B-013
C0161 Brake Switch Circuit Malfunction B-014
C0244 Invalid Data from ECM (Engine Control Module) C-014
C0460 Steering Angle Sensor Incorrect Signal B-008
C0570 Front Left Damper Valve Circuit Low Voltage C-007
C0570 Front Left Damper Valve Circuit Malfunction C-007
C0570 Front Left Damper Valve Circuit Open C-007
C0570 Front Left Damper Valve Circuit High Voltage C-007
C0575 Front Left Damper Valve Circuit Low Voltage C-007
C0575 Front Left Damper Valve Circuit Open C-007
C0575 Front Left Damper Valve Circuit Malfunction C-007
C0580 Front Right Damper Valve Circuit Malfunction C-008
C0580 Front Right Damper Valve Circuit Low Voltage C-008
C0580 Front Right Damper Valve Circuit Open C-008
C0580 Front Right Damper Valve Circuit High Voltage C-008
C0585 Rear Left Damper Valve Circuit Low Voltage C-009
C0585 Rear Left Damper Valve Circuit Malfunction C-009
C0585 Rear Left Damper Valve Circuit Open C-009
C0585 Rear Left Damper Valve Circuit High Voltage C-009
C0590 Rear Right Damper Valve Circuit Low Voltage C-010
C0590 Rear Right Damper Valve Circuit Malfunction C-010
C0590 Rear Right Damper Valve Circuit Open C-010
C0590 Rear Right Damper Valve Circuit High Voltage C-010
C0595 Front Left Body Acceleration Sensor Circuit Low Voltage B-010
C0595 Front Left Body Acceleration Sensor Circuit High Voltage B-010
C0595 Front Left Body Acceleration Sensor Circuit Voltage Range/Performance B-010
C0600 Front Right Body Acceleration Sensor Circuit Low Voltage B-010
C0600 Front Right Body Acceleration Sensor Circuit High Voltage B-010
C0600 Front Right Body Acceleration Sensor Circuit Voltage Range/Performance B-010
C0605 Rear Body Acceleration Sensor Circuit Low Voltage B-010
C0605 Rear Body Acceleration Sensor Circuit High Voltage B-010
C0605 Rear Body Acceleration Sensor Circuit Voltage Range/Performance B-010
C0670 Front Left Wheel Acceleration Sensor Circuit Low Voltage B-010
C0670 Front Left Wheel Acceleration Sensor Circuit High Voltage B-010
C0670 Front Left Wheel Acceleration Sensor Circuit Voltage Range/Performance B-010
C0675 Front Right Wheel Acceleration Sensor Circuit Low Voltage B-010
C0675 Front Right Wheel Acceleration Sensor Circuit High Voltage B-010
C0675 Front Right Wheel Acceleration Sensor Circuit Voltage Range/Performance B-010
C0895 Sensors Power Supply Circuit Low Voltage C-001
C0895 Sensors Power Supply Circuit High Voltage C-001
C0905 Vehicle Speed Signal Range/Performance B-011
C0910 Wheel Acceleration Sensor Circuit Malfunction B-015
C0915 Body Acceleration Sensor Circuit Malfunction B-016
C1690 Damper Mode Request Range/Performance C-013
C1690 Invalid Damper Mode Request via Can Bus C-013
#4 · (Edited by Moderator)
Airbag Codes
All Cars NOT TWIN TOP
B0012 Driver Airbag Squib Circuit (Stage 1) High Voltage C-002
B0012 Driver Airbag Squib Circuit (Stage 1) Low Voltage C-002
B0012 Driver Airbag Squib Circuit (Stage1) Open C-002
B0012 Driver Airbag Squib Circuit (Stage1) High Resistance C-002
B0012 Driver Airbag Squib Circuit (Stage1) Low Resistance B-009
B0012 Driver Airbag Squib Circuit (Stage 1) Shorted With Other Squib Circuit C-003
B0013 Driver Airbag Squib Circuit (Stage 2) High Voltage C-004
B0013 Driver Airbag Squib Circuit (Stage 2) Low Voltage C-004
B0013 Driver Airbag Squib Circuit (Stage2) Open C-004
B0013 Driver Airbag Squib Circuit (Stage 2) High Resistance C-004
B0013 Driver Airbag Squib Circuit (Stage 2) Low Resistance B-009
B0013 Driver Airbag Squib Circuit (Stage 2) Shorted With Other Squib Circuit C-005
B0014 Driver Side Airbag Squib Circuit High Voltage C-006
B0014 Driver Side Airbag Squib Circuit Low Voltage C-006
B0014 Driver Side Airbag Squib Circuit Open C-006
B0014 Driver Side Airbag Squib Circuit High Resistance C-006
B0014 Driver Side Airbag Squib Circuit Low Resistance B-009
B0014 Driver Side Airbag Squib Circuit Shorted With Other Squib Circuit C-007
B0015 Driver Pretensioner Circuit High Voltage C-008
B0015 Driver Pretensioner Circuit Low Voltage C-008
B0015 Driver Pretensioner Circuit Open C-008
B0015 Driver Pretensioner Circuit High Resistance C-008
B0015 Driver Pretensioner Circuit Low Resistance B-009
B0015 Driver Pretensioner Circuit Shorted With Other Squib Circuit C-009
B0016 Driver Curtain Airbag Squib Circuit High Voltage C-010
B0016 Driver Curtain Airbag Squib Circuit Low Voltage C-010
B0016 Driver Curtain Airbag Squib Circuit Open C-010
B0016 Driver Curtain Airbag Squib Circuit High Resistance C-010
B0016 Driver Curtain Airbag Squib Circuit Low Resistance B-009
B0016 Driver Curtain Airbag Squib Circuit Shorted With Other Squib Circuit C-011
B0019 Passenger Airbag Squib Circuit (Stage 1) High Voltage C-012
B0019 Passenger Airbag Squib Circuit (Stage 1) Low Voltage C-012
B0019 Passenger Airbag Squib Circuit (Stage1) Open C-012
B0019 Passenger Airbag Squib Circuit (Stage1) High Resistance C-012
B0019 Passenger Airbag Squib Circuit (Stage1) Low Resistance B-009
B0019 Passenger Airbag Squib Circuit (Stage 1) Shorted With Other Squib Circuit C-013
B0020 Passenger Airbag Squib Circuit (Stage 2) High Voltage C-014
B0020 Passenger Airbag Squib Circuit (Stage 2) Low Voltage C-014
B0020 Passenger Airbag Squib Circuit (Stage2) Open C-014
B0020 Passenger Airbag Squib Circuit (Stage 2) High Resistance C-014
B0020 Passenger Airbag Squib Circuit (Stage 2) Low Resistance B-009
B0020 Passenger Airbag Squib Circuit (Stage 2) Shorted With Other Squib Circuit C-015
B0021 Passenger Side Airbag Squib Circuit High Voltage C-016
B0021 Passenger Side Airbag Squib Circuit Low Voltage C-016
B0021 Passenger Side Airbag Squib Circuit Open C-016
B0021 Passenger Side Airbag Squib Circuit High Resistance C-016
B0021 Passenger Side Airbag Squib Circuit Low Resistance B-009
B0021 Passenger Side Airbag Squib Circuit Shorted With Other Squib Circuit C-017
B0022 Passenger Pretensioner Circuit High Voltage C-018
B0022 Passenger Pretensioner Circuit Low Voltage C-018
B0022 Passenger Pretensioner Circuit Open C-018
B0022 Passenger Pretensioner Circuit High Resistance C-018
B0022 Passenger Pretensioner Circuit Low Resistance B-009
B0022 Passenger Pretensioner Circuit Shorted With Other Squib Circuit C-019
B0023 Passenger Curtain Airbag Squib Circuit High Voltage C-020
B0023 Passenger Curtain Airbag Squib Circuit Low Voltage C-020
B0023 Passenger Curtain Airbag Squib Circuit Open C-020
B0023 Passenger Curtain Airbag Squib Circuit High Resistance C-020
B0023 Passenger Curtain Airbag Squib Circuit Low Resistance B-009
B0023 Passenger Curtain Airbag Squib Circuit Shorted With Other Squib Circuit C-021
B0051 Squib Circuits Activated (Crash) B-006
B0052 Passenger Airbag Locked by SOD (Seat Occupied Detection) B-006
B0053 Deployment Commanded With Troublecodes in Squib Circuits Present B-006
B0054 Passenger Side Airbag Locked by SOD (Seat Occupied Detection) B-006
B0055 Side Airbag Activated B-006
B0058 Passenger Pretensioner Locked by SOD (Seat Occupied Detection) B-006
B0081 SPPD Sensor Not Connected (Simple Passenger Presence Detection) C-022
B0081 SOD PPD Sensor Malfunction (Seat Occupied Detection) (Passenger Presence Detection) C-022
B0082 SOD CSD Sensor Malfunction (Seat Occupied Detection) (Child Seat Detection) C-022
B0083 Left Or Middle EFS Not Programmed (Electronical Front Impact Sensor) B-007
B0083 Left Or Middle EFS Circuit High Voltage (Electronical Front Impact Sensor) C-023
B0083 Left Or Middle EFS Circuit Low Voltage (Electronical Front Impact Sensor) C-023
B0083 Replace Left Or Middle EFS (Electronical Front Impact Sensor) C-023
B0083 Incorrect Left Or Middle EFS Installed (Electronical Front Impact Sensor) C-023
B0083 Invalid Data From Left Or Middle EFS (Electronical Front Impact Sensor) C-023
B0085 Driver SIS Not Programmed (Side Impact Sensor) B-007
B0085 Driver SIS Circuit High Voltage (Side Impact Sensor) C-024
B0085 Driver SIS Circuit Low Voltage (Side Impact Sensor) C-024
B0085 Replace Driver SIS (Side Impact Sensor) C-024
B0085 Incorrect Driver SIS Installed (Side Impact Sensor) C-024
B0085 Invalid Data From Driver SIS (Side Impact Sensor) C-024
B0086 Passenger SIS Not Programmed (Side Impact Sensor) B-007
B0086 Passenger SIS Circuit High Voltage (Side Impact Sensor) C-025
B0086 Passenger SIS Circuit Low Voltage (Side Impact Sensor) C-025
B0086 Replace Passenger SIS (Side Impact Sensor) C-025
B0086 Incorrect Passenger SIS Installed (Side Impact Sensor) C-025
B0086 Invalid Data From Passenger SIS (Side Impact Sensor) C-025
B0099 Communication Malfunction Between Airbag And Telematic Unit C-026
B0670 Airbag Telltale Circuit Malfunction IPC (Instrument) C-009
B0975 CSD Telltale Circuit Malfunction (Child Seat Detection) IPC (Instrument) C-009
B1000 Electronic Control Unit Not Reusable C-001
B1000 Trouble Code Memory Full C-027
U1327 Seat Occupied Detection System Voltage Low B-008
U2050 SOD Not Programmed (Seat Occupied Detection) B-007
U2050 SOD Circuit High Voltage (Seat Occupied Detection) C-022
U2050 SOD Circuit Low Voltage (Seat Occupied Detection) C-022
U2050 Invalid Data from SOD (Seat Occupied Detection) C-022
Twin Top
B0012 Driver Airbag Squib Circuit (Stage1) Low Resistance B-007
B0013 Driver Airbag Squib Circuit (Stage 2) Low Resistance B-007
B0014 Driver Side Airbag Squib Circuit Low Resistance B-007
B0015 Driver Pretensioner Circuit Low Resistance B-007
B0019 Passenger Airbag Squib Circuit (Stage1) Low Resistance B-007
B001C Left Rollover Bar Squib Circuit High Voltage C-010
B001C Left Rollover Bar Squib Circuit Low Voltage C-010
B001C Left Rollover Bar Squib Circuit Open C-010
B001C Left Rollover Bar Squib Circuit High Resistance C-010
B001C Left Rollover Bar Squib Circuit Low Resistance B-007
B001C Left Rollover Bar Squib Circuit Shorted With Other Squib Circuit C-011
B001D Right Rollover Bar Squib Circuit High Voltage C-020
B001D Right Rollover Bar Squib Circuit Low Voltage C-020
B001D Right Rollover Bar Squib Circuit Open C-020
B001D Right Rollover Bar Squib Circuit High Resistance C-020
B001D Right Rollover Bar Squib Circuit Low Resistance B-007
B001D Right Rollover Bar Squib Circuit Shorted With Other Squib Circuit C-021
B0020 Passenger Airbag Squib Circuit (Stage 2) Low Resistance B-007
B0021 Passenger Side Airbag Squib Circuit Low Resistance B-007
B0022 Passenger Pretensioner Circuit Low Resistance B-007
B0051 Squib Circuits Activated (Crash) B-008
B0052 Passenger Airbag Locked by SOD (Seat Occupied Detection) B-008
B0053 Deployment Commanded With Troublecodes in Squib Circuits Present B-008
B0054 Passenger Side Airbag Locked by SOD (Seat Occupied Detection) B-008
B0055 Side Airbag Activated B-008
B0058 Passenger Pretensioner Locked by SOD (Seat Occupied Detection) B-008
B0083 Left Or Middle EFS Not Programmed (Electronical Front Impact Sensor) B-006
B0085 Driver SIS Not Programmed (Side Impact Sensor) B-006
B0086 Passenger SIS Not Programmed (Side Impact Sensor) B-006
U1327 Seat Occupied Detection System Voltage Low B-009
U2050 SOD Not Programmed (Seat Occupied Detection) B-006
Door Locking Codes
B2976 Driver Door Switch Circuit Open or High Voltage B-009
B2991 Passenger Door Switch Circuit Open or High Voltage B-010
B2996 Rear Left Door Switch Circuit Open or High Voltage B-011
B3001 Rear Right Door Switch Circuit Open or High Voltage B-012
B3011 Trunk Switch Circuit Open or High Voltage C-006
B3109 Remote-Key 1 System Voltage Low Voltage Immobiliser C-002
B3110 Remote-Key 2 System Voltage Low Voltage Immobiliser C-002
B3111 Remote-Key 3 System Voltage Low Voltage Immobiliser C-002
B3112 Remote-Key 4 System Voltage Low Voltage Immobiliser C-002
B3113 Remote-Key 5 System Voltage Low Voltage Immobiliser C-002
B3114 Remote-Key 1 Not Synchronized Immobiliser C-002
B3115 Remote-Key 2 Not Synchronized Immobiliser C-002
B3116 Remote-Key 3 Not Synchronized Immobiliser C-002
B3117 Remote-Key 4 Not synchronized Immobiliser C-002
B3118 Remote-Key 5 Not Synchronized Immobiliser C-002
B3130 Doors Unlock Circuit Malfunction B-013
B3135 Doors Lock Circuit Malfunction B-013
B3150 Central Door Lock Switch Stuck C-007
B3265 Trunk Release Switch Stuck C-008
B3265 Trunk Release Circuit Malfunction B-014
B3797 Doors Deadlock Circuit Malfunction B-013
B3803 Windows Comfort Closing Circuit Malfunction C-011
B3803 Comfort Closing Circuit Low Voltage C-017
B3803 Comfort Closing Circuit High Voltage C-017
Head Lamps Leveling AHL/AFL
B0997 Right Power Light Module Malfunction C-012
B0997 Right Power Light Module Signal Range/Performance B-010
B1020 Left Power Light Module Malfunction C-011
B1020 Left Power Light Module Signal Range/Performance B-010
B1454 Left Dynamic Curve Light Position Sensor Circuit Malfunction C-005
B1455 Right Dynamic Curve Light Position Sensor Circuit Malfunction C-006
B1461 Left Dynamic Curve Light Stepper Motor Circuit Malfunction C-007
B1461 Left Dynamic Curve Light Stuck C-015
B1462 Right Dynamic Curve Light Stepper Motor Circuit Malfunction C-008
B1462 Right Dynamic Curve Light Stuck C-016
B2667 Servomotor Circuit High Voltage B-019
B2667 Servomotor Circuit Low Voltage B-019
B3415 Front/Rear Car Level Sensor Voltage Supply Low Voltage C-002
B3415 Front/Rear Car Level Sensor Voltage Supply High Voltage C-002
B3420 Rear Car Level Sensor Signal Circuit Low Voltage C-002
B3420 Rear Car Level Sensor Signal Circuit Open or High Voltage C-002
B3420 Rear Car Level Sensor Signal Circuit Range/Performance C-002
B3435 Left Servomotor Circuit Malfunction C-003
B3440 Right Servomotor Circuit Malfunction C-004
U1112 No Communication with Left Power Light Module B-018
U1113 No Communication with Right Power Light Module B-018
U2108 ABS (Anti-Lock Brake System) Wheel Speed Signal Circuit Range/Performance B-022
U2143 CAN-Bus No Communication with SAS (Steering Angle Sensor) B-016
U2143 Steering Angle Sensor Model Wrong B-016
U2143 Invalid Data from SAS (Steering Angle Sensor) B-016
Anti Theft (alarm)
B1001 Pane Breakage Calibration Not Learned C-003
B1342 Alarm Siren Power Supply Malfunction B-017
B2923 Pane Breakage Sensor 1 Circuit Open or High Voltage C-003
B2955 Ultrasonic Module Malfunction C-004
B2955 Invalid Data from Ultrasonic Module B-013
B3078 Anti Theft Warning System Horn Signal Circuit Malfunction C-005
B3089 Pane Breakage Sensor Rear Window Heater Circuit Open or High Voltage C-002
B3916 Alarm Siren Battery Voltage Low C-006
B3916 Alarm Siren Circuit Malfunction C-006
B3916 No Communication With Alarm Siren C-006
Wipers/Washers
B1020 No Communication with Rain Sensor B-016
B1020 Invalid Data from Rain Sensor B-016
B3637 Rear Washer Switch Stuck C-003
B3638 Front Washer Switch Stuck C-003
B3639 Wiper Switch Up (F1) Stuck C-003
B3640 Wiper Switch Up (F2) Stuck C-003
B3641 Wiper Switch Down (F1) Stuck C-003
B3642 Wiper Switch Down (F2) Stuck C-003
B3810 Headlamp Washer Pump Relay Circuit Malfunction B-015
B3811 Rear Window Washer Pump Relay Circuit Malfunction B-014
B3873 Windscreen Washer Pump Relay Circuit Malfunction B-014
B3874 Front Wiper On/Off Relay Circuit Malfunction B-012
B3875 Front Wiper Low/High Speed Relay Circuit Malfunction B-012
B3876 Front Wiper Park Switch Signal not Plausible B-012
B3970 Rear Wiper Motor Circuit Voltage Low B-013
B3970 Rear Wiper Motor Circuit Malfunction B-013
#5 · (Edited by Moderator)
Body Control Codes Cont
Exterior Lighting
B0525 Front Right Turn Indicator Circuit Malfunction C-032
B0525 Rear Right Turn Signal Malfunction C-034
B0525 Right Turn Signal Circuit Open or High Voltage B-059
B0525 Right Turn Signal Circuit Low Voltage B-059
B0530 Front Left Turn Indicator Circuit Malfunction C-031
B0530 Rear Left Turn Signal Malfunction C-033
B0530 Left Turn Signal Circuit Open or High Voltage B-059
B0530 Left Turn Signal Circuit Low Voltage B-059
B0655 Brake Light Switch Circuit Incorrect Signal C-001
B1456 Automatic Light Switch Circuit Open C-005
B2501 Horn Switch Stuck C-043
B2530 Front Fog Light Circuit Low Voltage C-022
B2530 Front Fog Light Circuit Malfunction C-022
B2535 Rear Fog Light Circuit Malfunction C-023
B2545 Rear Left Reverse Light Circuit Malfunction C-012
B2575 Left Low Beam Circuit Low Voltage C-018
B2575 Left Low Beam Circuit Open or High Voltage C-018
B2580 Left High Beam Circuit Low Voltage C-020
B2580 Left High Beam Circuit Open C-020
B2585 Front Left Parking Lamp Circuit Malfunction C-014
B2662 Parking Lamps Switch Circuit Open or High Voltage C-003
B2699 Right Low Beam Circuit Low Voltage C-019
B2699 Right Low Beam Circuit Open C-019
B2740 Front Fog Lights Switch Circuit Open or High Voltage C-007
B2740 Front Fog Lights Switch stuck C-007
B2743 Rear Fog Light Switch Circuit Open or High Voltage C-008
B2743 Rear Fog Light Switch stuck C-008
B3445 Rear Left Brake Light Circuit Malfunction C-009
B3445 Brake Light Circuit Open or High Voltage B-056
B3445 Brake Light Circuit Low Voltage B-056
B3596 Hazard Warning Switch stuck C-039
B3634 Left Turn Signal Switch (F1) Stuck C-030
B3635 Right Turn Signal Switch (F2) Stuck C-030
B3636 Left Turn Signal Switch (F2) Stuck C-030
B3650 Highbeam Switch Stuck C-006
B3651 Headlamp Flasher Switch Stuck C-006
B3652 Right Turn Signal Switch (F1) Stuck C-030
B3795 Hazard Warning Switch Telltale Output Low Voltage C-040
B3795 Hazard Warning Switch Telltale Output Circuit Open or High Voltage C-040
B3795 Hazard Warning Switch Telltale Malfunction C-040
B3840 Wrong Stalk Switch Configuration B-063
B3866 Right High Beam Circuit Low Voltage C-021
B3866 Right High Beam Circuit Open C-021
B3867 Front Right Parking Lamp Circuit Malfunction C-015
B3868 Left Side Repeater Circuit Malfunction C-035
B3869 Right Side Repeater Circuit Malfunction C-036
B3878 Rear Right Brake Light Circuit Malfunction C-010
B3878 Right Brake Light Circuit Open or High Voltage C-010
B3878 Rear Right Brake Light Circuit Low Voltage C-010
B3880 Rear Right Reverse Light Circuit Malfunction C-013
B3881 Left Tail Light Circuit Malfunction C-016
B3881 Tail Light Circuit Open or High Voltage B-053
B3881 Tail Light Circuit Low Voltage B-053
B3882 Right Tail Light Circuit Malfunction C-017
B3883 Licence Plate Light Circuit Malfunction C-024
B3884 Centre Brake Light Circuit Low Voltage C-011
B3884 Centre Brake Light Circuit Open or High Voltage C-011
B3885 Left Trailer Tail Light Circuit Malfunction C-027
B3886 Right Trailer Tail Light Circuit Malfunction C-028
B3887 Left Trailer Turn Signal Circuit Malfunction C-037
B3888 Right Trailer Turn Signal Circuit Malfunction C-038
B3889 Trailer Brake Light Circuit Malfunction C-025
B3890 Trailer Reverse Light Circuit Malfunction C-026
B3891 Trailer Fog Light Circuit Malfunction C-029
B3909 Low Beam Switch Circuit Open or High Voltage C-004
U1307 No Communication with Trailer Electronic Module C-045
Interior Lighting
B2570 Trunk Lamp Circuit Malfunction C-007
B2610 Instrument Dimming Bulb Output Circuit Low Voltage C-008
B2610 Instrument Dimming Bulb Output Circuit High Voltage C-008
B2652 Inadvertent Load Circuit Low Voltage C-001
B2652 Interior Lights Cut-Off Circuit Malfunction C-001
B2652 Instrument Dimming LED Output Circuit Low Voltage C-002
B2652 Instrument Dimming LED Output Circuit High Voltage C-002
B2657 Illumination Circuit Malfunction C-017
B3600 Dimmed Illumination Switch Circuit High Voltage C-009
B3600 Dimmed Illumination Switch Circuit Low Voltage C-009
Immobiliser
B1319 Immobiliser Receiver Circuit Malfunction C-001
B2910 ESCL (Electromechanical Steering Column Lock) Security Code Not Learned B-010
B3055 Transponder Key Problem B-022
B3055 Wrong Transponder Key B-022
B3056 No Transponder Key Programmed C-002
B3057 Security Code Not Programmed B-005
B3077 Wrong Transponder Type detected C-002
B3755 No Transponder Key Programmed C-002
B3899 No Environment Identifier Learned B-007
B3900 No Immobiliser Identifier Learned B-007
B3901 Wrong Environment Identifier Received B-007
B3902 Wrong Immobiliser Identifier Received B-007
B3925 Wrong Environment Identifier Received IPC (Instrument) B-017
B3928 Wrong Environment Identifier Received TU (Telematic Unit) B-016
B3929 Wrong Environment Identifier Received REC (Rear Electrical Centre) B-018
B3977 Wrong Environment Identifier Received UEC (Underhood Electrical Centre) B-019
IPC (dials)
B0575 Fuel Level Sensor Low Voltage C-016
B0575 Fuel Level Sensor Circuit Open or High Voltage C-016
B0670 Airbag Telltale Circuit Malfunction C-001
B0967 Parking Assist System Switch Circuit Open or High Voltage PAS (Park Pilot) C-007
B0967 Park Pilot Switch stuck PAS (Park Pilot) C-007
B0968 Park Pilot Switch Telltale Circuit Low Voltage PAS (Park Pilot) C-008
B0968 Park Pilot Switch Telltale Circuit Open or High Voltage PAS (Park Pilot) C-008
B0969 Rear Window Heating Switch Telltale Circuit High Voltage Heating, Ventilation and Air Conditioning System B-014
B0969 Rear Window Heating Switch Telltale Circuit Low Voltage Heating, Ventilation and Air Conditioning System B-014
B0975 Child Seat Detection Telltale Circuit Malfunction C-001
B2128 Trip Reset Button Stuck C-001
B3743 Rear Window Heating Switch Stuck Heating, Ventilation and Air Conditioning System C-005
P0115 Engine Coolant Temperature Signal Range/Performance B-019
P0460 Fuel Level Sensor Circuit Range/Performance B-013
P0550 Mileage Circuit Range/Performance C-001
P0654 Engine Speed Signal Range/Performance C-001
P0705 Automatic Transmission Gear Signal Range/Performance C-001
U2139 Invalid Signal from CIM (Steering Column Module) C-003
U2140 Invalid Data from UEC (Underhood Electrical Centre) C-004
U2141 Invalid Data from REC (Rear Electrical Centre) C-005
HEATING EEC SAC (climate control)
B0165 Compartment Temperature Sensor Circuit Low Voltage C-006
B0166 Compartment Temperature Sensor Circuit High Voltage C-006
B0175 Air Outlet Temperature Sensor Interior Circuit Low Voltage C-018
B0176 Air Outlet Temperature Sensor Interior Circuit High Voltage C-018
B0180 Air Outlet Temperature Sensor Footwell Circuit Low Voltage C-017
B0181 Air Outlet Temperature Sensor Footwell Circuit High Voltage C-017
B0185 Solar Sensor Circuit Low Voltage C-007
B0186 Solar Sensor Circuit High Voltage C-007
B0195 Blower Motor Circuit Low Voltage B-014
B0196 Blower Motor Circuit High Voltage C-012
B0225 Recirculation Flap Motor Circuit Low Voltage C-016
B0226 Recirculation Flap Motor Circuit High Voltage C-016
B0227 Recirculation Flap Motor Circuit Open C-016
B0234 Air Distribution Flap Calibration Malfunction B-031
B0235 Air Distribution Flap Motor Low Voltage C-014
B0236 Air Distribution Flap Motor High Voltage C-014
B0237 Air Distribution Flap Motor Circuit Open C-014
B0283 Key Stuck C-023
B0290 Coil Compressor Stroke Control Circuit Low Voltage B-024
B0291 Coil Compressor Stroke Control Circuit High Voltage B-024
B0318 Key Stuck C-023
B0323 Key Stuck C-023
B0333 Key Stuck C-023
B0358 Key Stuck C-023
B0368 Key Stuck C-023
B0410 Blending Flap Motor Circuit Low Voltage C-013
B0411 Blending Flap Motor Circuit High Voltage C-013
B0412 Blending Flap Motor Circuit Open C-013
B1445 Stepper Motors Supply Low Voltage C-013
B2930 Anti-Theft Warning System Disable Failed Anti-Theft Warning System B-015
B3843 Air Quality Sensor Circuit Low Voltage B-013
B3843 Air Quality Sensor Circuit Open or High Voltage B-013
P1532 Evaporator Temperature Sensor Circuit Low Voltage B-023
P1533 Evaporator Temperature Sensor Circuit High Voltage B-023
Parking Sensors
B0952 Loudspeaker Circuit High Voltage C-006
B0952 Loudspeaker Circuit Open or Low Voltage C-006
B0958 Park Pilot Sensor Rear Left Outer Circuit Open or Low Voltage C-002
B0958 Park Pilot Sensor Rear Left Outer Circuit Malfunction C-002
B0958 Park Pilot Sensor Rear Left Outer Acoustically Blocked C-002
B0959 Park Pilot Sensor Rear Left Middle Circuit Open or Low Voltage C-003
B0959 Park Pilot Sensor Rear Left Middle Circuit Malfunction C-003
B0959 Park Pilot Sensor Rear Left Middle Acoustically Blocked C-003
B0960 Park Pilot Sensor Rear Right Middle Circuit Open or Low Voltage C-004
B0960 Park Pilot Sensor Rear Right Middle Circuit Malfunction C-004
B0960 Park Pilot Sensor Rear Right Middle Acoustically Blocked C-004
B0961 Park Pilot Sensor Rear Right Outer Circuit Open or Low Voltage C-005
B0961 Park Pilot Sensor Rear Right Outer Circuit Malfunction C-005
B0961 Park Pilot Sensor Rear Right Outer Acoustically Blocked C-005
B1000 Loudspeaker Voltage Supply Low Voltage C-006
B1350 Park Pilot Sensor Voltage Supply Low Voltage C-001
B1350 Park Pilot Sensor Voltage Supply High Voltage C-001
U2116 Invalid Data from IPC (Instrument) B-009
U2117 Invalid Data from DIS (Display) B-010
U2139 Invalid Data from CIM (Steering Column Module) B-011
U2140 Invalid Data from UEC (Underhood Electrical Centre) B-012
U2141 Invalid Data from REC (Rear Electrical Centre) B-013
Open And Start (keyless entery)
B0655 PEPS (Open&Start) No Communication With ECM (Engine Control Module) B-010
B1011 Error Information Stored in CIM C-003
B1272 Antenna Control Low Frequency B-012
B1272 Antenna High Current B-012
B1272 Antenna High Voltage B-012
B1272 Antenna Low Voltage B-012
B1395 Driver Door Approach Sensor Supply Voltage Circuit High Voltage C-014
B1395 Driver Door Approach Sensor Supply Voltage Circuit Low Voltage C-014
B1405 Front Passenger Door Approach Sensor Supply Voltage Circuit High Voltage C-015
B1405 Front Passenger Door Approach Sensor Supply Voltage Circuit Low Voltage C-015
B1440 Ignition Circuit Short To Ground C-001
B1449 ESCL (Electromechanical Steering Column Lock) Circuit High Voltage C-003
B1449 ESCL (Electromechanical Steering Column Lock) Circuit Low Voltage C-003
B1449 CIM (Steering Column Module) Power Supply Circuit Low Voltage C-003
B1534 Rear Left Door Handle Switch Circuit Low Voltage C-006
B1535 Rear Right Door Handle Switch Circuit Low Voltage C-007
B2511 Driver Door Approach Sensor Circuit Low Voltage C-014
B2512 Front Passenger Door Approach Sensor Circuit Low Voltage C-015
B2517 Door-Opener Motor Driver Door Circuit Open C-016
B2518 Door-Opener Motor Front Passenger Door Circuit Open C-017
B2519 Door-Opener Motor Rear Right Circuit Open C-019
B251A Any Door-Opener Motor Circuit High Voltage B-013
B251A Any Door-Opener Motor Circuit Low Voltage B-013
B2520 Door-Opener Motor Rear Left Circuit Open C-018
B2897 Electromechanical Steering Column Lock Circuit High Voltage C-003
B2897 Electromechanical Steering Column Lock Circuit Low Voltage B-008
B2910 ESCL (Electromechanical Steering Column Lock) Overtemperature C-003
B2910 ESCL (Electromechanical Steering Column Lock) Blocked C-003
B2910 ESCL (Electromechanical Steering Column Lock) Circuit Malfunction C-003
B2910 Vehicle Speed Too High for Start/Stop Switch Activation B-014
B2910 Wrong ESCL (Electromechanical Steering Column Lock) C-003
B2961 Ignition/Start/Stop Switch Timeout C-002
B2966 Driver Door Handle Switch Low Voltage C-004
B2981 Front Passenger Door Handle Switch High Voltage C-005
B3106 Wrong PEPS (Open&Start) C-023
B3119 Driver Side Outside Antenna Circuit Open C-009
B3120 Passenger Side Outside Antenna Circuit Open C-010
B3121 Trunk Outside Antenna Circuit Open C-011
B3122 Front Inside Antenna Circuit Open C-012
B3123 Rear Inside Antenna Circuit Open C-013
B3618 Trunk Handle Switch Circuit Low Voltage C-008
Electric Roof (twintop)
B129A Frame Latch Contact Switch Circuit Open or High Voltage C-024
B129A Frame Latch Contact Switch Circuit Low Voltage C-024
B129B Luggage Protection Sensor Circuit High Voltage C-011
B129B Luggage Protection Sensor Circuit Open or Low Voltage C-011
B129B Luggage Protection Sensor Signal Range/Performance C-011
B129C Left Parcel Shelf Flap Motor Circuit Malfunction C-035
B129C Left Parcel Shelf Flap Motor Current not Plausible with Sensor Position C-035
B129C Left Parcel Shelf Flap Motor Circuit Open or Relay Stuck C-035
B129D Right Parcel Shelf Flap Motor Circuit Malfunction C-036
B129D Right Parcel Shelf Flap Motor Current not Plausible with Sensor Position C-036
B129D Right Parcel Shelf Flap Motor Circuit Open Relay Stuck C-036
B1300 Contact Switch 'Hardtop Closed' Circuit Open or High Voltage C-023
B1300 Contact Switch 'Hardtop Closed' Circuit Low Voltage C-023
B1301 'Frame Open' Sensor Circuit High Voltage C-012
B1301 'Frame Open' Sensor Circuit Open or Low Voltage C-012
B1301 'Frame Open' Sensor Signal Range/Performance C-012
B1302 'Front Latch Locked' Contact Switch Circuit Open or High Voltage C-022
B1302 'Front Latch Locked' Contact Switch Circuit Low Voltage C-022
B1308 Hydraulic Unit Relay 1 Circuit High Voltage C-028
B1309 Hydraulic Unit Relay 2 Circuit High Voltage C-029
B130A Easy Pack Switch Circuit Open or High Voltage C-008
B130A Easy Pack Switch Circuit Low Voltage C-008
B130B Trunk Lid Latch Motor Circuit Open or Relay Stuck C-032
B130C Trunk Lid Latch Movement Too Slow C-039
B130D Trunk Lid Contact Switch 'Closed' Circuit Open or High Voltage C-025
B130D Trunk Lid Contact Switch 'Closed' Circuit Low Voltage C-025
B130E Trunk Lid Contact Switch 'Open' Circuit Open or High Voltage C-025
B130E Trunk Lid Contact Switch 'Open' Circuit Low Voltage C-025
B130E Trunk Lid Contact Switches 'Open' and 'Closed' Not Plausible C-038
B130F Trunk Lid Switches Not Plausible C-038
B131A Easypack Contact Switch Circuit Open or High Voltage C-026
B131A Easypack Contact Switch Circuit Low Voltage C-026
B131B Parcel Shelf Movement Too Slow C-039
B131C 'Parcel Shelf Up' and 'Parcel Shelf Down' Sensor Not Plausible C-001
B131D Trunk Lid Movement Too Slow C-039
B131E Trunk Lid Position Malfuntion C-001
B131F Motor Trunk Lid Arrester Circuit Open or Relay Stuck C-037
B132A 'Parcel Shelf Up' Sensor Circuit High Voltage C-019
B132A 'Parcel Shelf Up' Sensor Circuit Open or Low Voltage C-019
B132A 'Parcel Shelf Up' Sensor Signal Range/Performance C-019
B132B 'Parcel Shelf Down' Sensor Circuit High Voltage C-020
B132B 'Parcel Shelf Down' Sensor Circuit Open or Low Voltage C-020
B132B 'Parcel Shelf Down' Sensor Signal Range/Performance C-020
B132C Left Trunk Lid Flap Motor Circuit Malfunction C-033
B132C Left Trunk Lid Flap Motor Current not Current Not Plausible with Sensor Position C-033
B132C Left Trunk Lid Flap Motor Circuit Open or Relay Stuck C-033
B132D Right Trunk Lid Flap Motor Circuit Malfunction C-034
B132D Right Trunk Lid Flap Motor Current Not Plausible with Sensor Position C-034
B132D Right Trunk Lid Flap Motor Circuit Open or Relay Stuck C-034
B132E Easypack Movement Too Slow C-039
B132F Easypack Position Malfunction C-001
B138A Supply Voltage Output Circuit Low Voltage or Signal Range/Performance C-009
B1405 Ground Output Circuit High Voltage C-010
B1405 Ground Output Circuit Low Voltage C-010
B249A 'Open All Windows' Switch Circuit Open or High Voltage C-007
B249A 'Open All Windows' Switch Circuit Low Voltage C-007
B3011 'Trunk Lid Open' Sensor Circuit High Voltage C-013
B3011 'Trunk Lid Open' Sensor Circuit Open or Low Voltage C-013
B3011 'Trunk Lid Open' Sensor Signal Range/Performance C-013
B3611 'Open Hardtop' Switch Circuit Open or High Voltage C-006
B3611 'Open Hardtop' Switch Circuit Low Voltage C-006
B3612 'Close Hardtop' Switch Circuit Open or High Voltage C-006
B3612 'Close Hardtop' Switch Circuit Low Voltage C-006
B3670 Pump Temperature Sensor Circuit Open or High Voltage C-021
B3670 Pump Temperature Sensor Circuit Low Voltage C-021
B3670 Pump Temperature Sensor Signal Range/Performance C-021
B3674 Solenoid Valve 1 Circuit High Voltage C-030
B3675 Solenoid Valve 2 Circuit High Voltage C-031
B3680 Hydraulic Pump High Temperature (Level 1) C-027
B3680 Hydraulic Pump High Temperature (Level 2) C-027
B368A Left Trunk Lid Flap Sensor Circuit High Voltage or Motor Blocked C-015
B368A Left Trunk Lid Flap Sensor Circuit Open or Low Voltage C-015
B368B Right Trunk Lid Flap Sensor Circuit High Voltage or Motor Blocked C-016
B368B Right Trunk Lid Flap Sensor Circuit Open or Low Voltage C-016
B368C Left Parcel Shelf Flap Sensor Circuit Open C-017
B368C Left Parcel Shelf Flap Circuit High Voltage or Motor Blocked C-017
B368D Right Parcel Shelf Flap Sensor Circuit High Voltage or Motor Blocked C-018
B368D Right Parcel Shelf Flap Sensor Circuit Open C-018
B368E Left Trunk Lid Flap Motor or Parcel Shelf Flap Motor Circuit High Voltage B-009
B368E Left Trunk Lid Flap or Parcel Shelf Flap Motor Circuit Low Voltage B-009
B368E Left Trunk Lid Flap Motor or Parcel Shelf Flap Motor Circuit High Current B-009
B368F Right Flap or Trunk Lid Arrester Motor Circuit High Voltage B-009
B368F Right Flap or Trunk Lid Arrester Motor Circuit Low Voltage B-009
B368F Right Flap or Trunk Lid Arrester Motor Circuit High Current B-009
B369A Contact Switches Malfunction C-038
B369A Hardtop Movement Too Slow C-039
B3803 'Close All Windows' Switch Circuit Open or High Voltage C-007
B3803 'Close All Windows' Switch Circuit Low Voltage C-007
B3972 'Hardtop Open' Sensor Circuit High Voltage C-014
B3972 'Hardtop Open' Sensor Circuit Open or Low Voltage C-014
B3972 'Hardtop Open' Sensor Signal Range/Performance C-014
B3972 'Hardtop Open' and 'Hardtop Closed' Malfunction C-014
#6 · (Edited by Moderator)
Radio Group
EHU (radio)
B0000 Vehicle Speed Signal, Malfunction C-028
B1021 SIM Card Malfunction C-003
B1023 Key Stuck C-010
B1025 Front Left Loudspeaker Circuit Low Voltage C-004
B1025 Front Left Loudspeaker Circuit Shorted C-004
B1025 Front Left Loudspeaker Circuit Open C-004
B1035 Front Right Loudspeaker Circuit Low Voltage C-005
B1035 Front Right Loudspeaker Circuit Shorted C-005
B1035 Front Right Loudspeaker Circuit Open C-005
B1045 Rear Left Loudspeaker Circuit Low Voltage C-006
B1045 Rear Left Loudspeaker Circuit Shorted C-006
B1045 Rear Left Loudspeaker Circuit Open C-006
B1055 Rear Right Loudspeaker Circuit Low Voltage C-007
B1055 Rear Right Loudspeaker Circuit Shorted C-007
B1055 Rear Right Loudspeaker Circuit Open C-007
B1065 Front Centre Loudspeaker Circuit Low Voltage C-008
B1065 Front Centre Loudspeaker Circuit Shorted C-008
B1065 Front Centre Loudspeaker Circuit Open C-008
B1075 Subwoofer Out Signal Circuit Low Voltage C-009
B1075 Subwoofer Out Signal Circuit Shorted C-009
B1075 Subwoofer Out Signal Circuit Open C-009
B1075 Tweeter FL Malfunction C-004
B1085 Tweeter FR Malfunction C-005
B1095 Tweeter RL Malfunction C-006
B1105 Tweeter RR Malfunction C-007
B1235 Amplifier High Temperature C-002
B1240 CD Mechanism Malfunction C-024
B1245 CD-Changer Malfunction C-026
B1245 CD-Changer Loading Sledge Malfunction C-026
B1246 CD-Changer Track Read Error C-026
B1247 CD-Changer High Temperature C-002
B1249 CD-Changer Table of Contents Read Error C-026
B1264 Output Terminal "AA" Circuit Low Voltage C-011
B1264 Output Terminal "AA" Circuit Open C-011
B1272 Antenna FM/AM Signal Circuit Low Voltage C-014
B1272 Antenna FM/AM Signal Circuit Open C-014
B1272 FM/AM Antenna Malfunction C-014
B1273 Twin Audio Remote Control Circuit Low Voltage C-015
B1273 Twin Audio Remote Control Circuit Open or High Voltage C-015
B1273 Twin Audio Remote Control Key Stuck C-016
B1278 DAB audio input signal malfunction C-031
B2455 Microphone Circuit Malfunction C-022
B2460 Antenna GPS Signal Circuit Low Voltage C-023
B2460 Antenna GPS Signal Circuit Open C-023
B2462 GPS communication malfunction C-001
B2464 Navigation Drive Read Error C-025
B2469 GSM phone communication malfunction C-001
B2470 Antenna GSM Signal Circuit Low Voltage C-021
B2470 Antenna GSM Signal Circuit Open C-021
B2471 OnStar-Numbers not Programmed Hard- and Software B-044
B2479 Airbag Deployment Signal Malfunction C-032
DIS (radio display ALL)
B1000 System High Voltage Counter Overrun (System Locked) C-001
B3562 Mode Key Stuck C-001
B3567 Set Key Stuck C-001
U1500 Graphical Interface Communication Malfunction B-023
U2116 Invalid Data from IPC (Instrument) C-004
U2139 Invalid Data from CIM (Steering Column Module) C-005
U2140 Invalid Data from UEC (Underhood Electrical Centre) C-002
U2141 Invalid Data from REC (Rear Electrical Centre) C-003
U2147 Invalid Data from AHS (Add On Heater) C-006
DAB
B1272 Antenna Signal Circuit Low Voltage C-002
B1272 Antenna Signal Circuit Open C-002
UHP (mobile phone)
B1272 Antenna Signal Circuit Low Voltage C-001
B1272 Antenna Signal Circuit Open C-001
B1273 Mobile Phone Portal Low Voltage C-002
B1273 Mobile Phone Portal open circuit C-002
B2455 Microphone Circuit Low Voltage C-003
B2455 Microphone Circuit Open C-003
B2469 Line Out Circuit Low Voltage C-004
Status
Not open for further replies.
You have insufficient privileges to reply here.
