sorry if this is duplicated but i have found similar posts but nothing that answers my problem! i bought my astra hatchback sri cdti 150bhp a month ago, its still under warranty but got a little issue that has got both vauxhall, and the garage I bought it from quite stumped! every now and again the emission light comes on and a slight loss of power is noticeable. Fault code P2279 is shown, after 2 days of diagnostics vauxhall have changed the egr for the sake of doing something, it was ok for a week but have had the same symtoms on at least 4 occasions in the last week. It happens completely randomly and clears itself, usually overnight. swirl pot valves seem fine.
i want to get it sorted cause really love the car when its behaving! Any ideas greatly appreciated! i have access to diagnostic equipment.
check for any unusual sooty deposits in or around the EGR/Intake manifold or along the EGR piping from the exhaust manifold, as that would be a solid indication of where the leak is, all the EGR pipework is situated to the right of the engine.
A split vacuum hose was found, they decided to cut the split out and reattached it and all was fine.........until I pick the car up and the light comes back on within 5 mins!! Im starting to think its me!!!!
They're replacing the damaged hose when they get the part in. One thing that was noticed was that when they removed the egr valve, the soot around that area was 'wet'! Any thoughts would be appreciated even if it is just 'Sell the blooming thing'!!
you havent got dodgy oxygen sensors have you, i had this on my petrol astra this time last year, exactly the same symptoms the light flickering then soon as was reset the light would come back on after 5-10 miles
hold you pedals in and do the pedal test see how many codes are stored. you might see ecn 013042/003608 and i cant quite remember the 3rd think it was 013011. i had 3 numbers flash up
Make sure the boost sensor is cleaned if you had a clogged egr. I serviced my egr and was still a little flat. Checked boost sensor and it was completely caked in black sooty sludge. Quick blast of carb cleaner and good to go. Well, actually, it caked again as the car cleared itself but been fine since, and very little soot on hard acceleration.
The peddle test just comes up with one code 227956 which is the air intake code, so say they've already swapped the sensors with known working ones for diagnosis! Back in today so hopefully will be a short and sweet trip this time as they're running out of things to change!
apparently the last time it was in they repaired a split hose, this time they replaced the hose and all seems great! 150 miles without a flicker of the dreaded light!
thanks all for your suggestions and advice!
Related Threads
Astra Owners Network
2.8M posts
60K members
Since 2003
